Old 12-19-2012, 04:49 PM   #1
BroncoSquid
Workin on it...
BroncoSquid's Avatar
Club: Bill G fan club!
Default Epoxy storage?
I have some 5min epoxy I bought 6 months ago. Used it twice, consuming about 10% of it. Slowly the resin in the bottle has started to harden and is all clumpy. The hardener is fine. Is this usual? Storage is on the workbench in the garage. Temp range 85-45 deg. Is there a storage trick of should I buy smaller bottles every 4 months?
I'm either going to get good at flying em, or get good at fixin em!
BroncoSquid is offline
Old 12-19-2012, 05:36 PM   #2
gyrocptr
Put it in a bath of hot water for a few minutes, and it will usually de-crystallize.
gyrocptr is offline
Old 12-19-2012, 08:51 PM   #3
slipstick
Outstanding Contributor Award
Epoxy does that a lot. I just zap it in the microwave for a few seconds (20-30 sec....DON'T overdo it ).
slipstick is offline
Old 12-19-2012, 10:02 PM   #4
road king 97
old hat
road king 97's Avatar
Club: joliet rc club rt 66
Scratchbuilders Award  Outstanding Contributor Award
Friends: (13)
LOL i have two bottels of 5 min stuff sitting on my bench for 2 years now with no lids at all and used the last of it 2 days ago. joe
road king 97 is offline
Old 12-19-2012, 10:18 PM   #5
oem flyer
I believe that exposure to air or at least moist air may be the cause. I had two 4.5 oz bottles do that. One was 5min. the other was 30. I now buy my epoxy in the tandem syringe containers. Once you get the initial air out of them their is nothing but epoxy in the tubes. Haven't had a problem since.
oem flyer is offline
Old 12-20-2012, 03:38 PM   #6
BroncoSquid
Workin on it...
Thank you for all the replies. I will try heating it up a little. Nothing to loose.
Old 12-20-2012, 03:41 PM   #7
Rodneh
I have had epoxy stay usable for well over 5 years and part of that time in a garage that got very hot over the summers. As long as you keep the two components separated, you should not have any problem. Exposure to air has never been a problem with any of mine. As mentioned above, if any of it does crystallise, just immerse it in hot water for a bit. I'd steer away from any microwave as, if you over do it, you can wind up with an almost unclean-able mess.
Rodneh is offline
Old 12-20-2012, 03:55 PM   #8
slipstick
Microwave was recommended to me by an adhesives chemist who worked for Ciba-Geigy (manufacturers of Araldite) at the time. But you're right it's only the warmth it needs so if you're feeling nervous hot water will work perfectly well....not quite so rapidly though .
Old 12-20-2012, 04:29 PM   #9
road king 97
old hat
Friends: (13)
When putting fiberglass cloth on the middle section of a wing i smear 15 minute epoxy over it then hit it with my covering hot air gun and the epoxy turns to water . I then take a old credit card and wipe the excess off . After you hit it with the gun its drying time goes from 15 min to around 4 . I found out its nice to do it this way because it gets a great bond by soaking into the wood a little and filling the weave. Happy Holidays guys / joe
Old 12-20-2012, 11:33 PM   #10
Dennis V
Friends: (16)
Yeah, years ago a fellow worker made the mistake of putting some circuit board coating type epoxy resin and hardener into two foam drinking cups, and went home.
That stuff dissolved the foam, and went all over his desk, and onto the floor. They had to replace the desk. (FYI after quite a few more boneheaded things like this, the company replaced that technician!)
DennyV
Old 12-21-2012, 03:24 PM   #11
BroncoSquid
Workin on it...
That is a great tip, thanks, I will have to remember that one. Crap... now I have to go out and get a heat gun.
Old 12-21-2012, 03:27 PM   #12
BroncoSquid
Workin on it...
I learned that one trying to use Testors plastic model cement on a foam glider 30 years ago.
Old 12-21-2012, 05:32 PM   #13
road king 97
old hat
Friends: (13)
Your welcome ,you can also dabb it with foam or tissue to get most the the excess off and to keep it as light as posible but still strong. A heat gun is always great when covering a plane or fixing the covering on one. So to a neat job without and wrinkles i use a trim iron for tight spots a reg iron for the edges and my heat gun to shrink all the middle of my parts . You can also heat up the covering while you pull it around round wing tips for a smooth finish but i use some gloves to pull with so i dont burn my fingers all up ,or two pieces of balsa glued to some plyers to pull with. joe
Old 12-21-2012, 06:42 PM   #14
Dennis V
Friends: (16)
Yeah, I've done that for decades, it works very well. You might want to consider proper ventilation doing that though, don't think epoxy fumes are really good for your lungs.
Also, don't try this with 5 minute epoxy, it sets real fast under heat. (Don't ask)
DennyV
Old 12-26-2012, 03:25 PM   #15
BroncoSquid
Workin on it...
The hot water bath worked excellent! Just used hot tap water. Mixed better too. Saved me from throwing away perfectly good epoxy. Thanks again.
Old 12-27-2012, 01:26 AM   #16
xuzme720
c'mere Monkey
xuzme720's Avatar
Send a message via Yahoo to xuzme720
Friends: (8)
I did the same thing, but it was the foam part on a model of one of those Battlestar Galactica's fighters...I can't even remember what they were called now.
Just call me X! (or Gary works, too.)
Another signature landing! Somebody help me find all the pieces...
xuzme720 is offline
Old 12-29-2012, 02:19 PM   #17
dgholmes59
The resin is the problem in my experience. It happens to opened and unopened containers. Not sure why. I pulled out a brand new unopened package of Great Planes 30-minute epoxy from my closet this week and the resin had hardened a little. Looks like honey that has crystalized. Unless you want it to get real hot, don't microwave it too long. a few seconds is all it usually takes to liquify it again.
dgholmes59 is offline
Old 12-29-2012, 06:25 PM   #18
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (86)
I build sailboats (40+years) and use it by the 55 gal drum,, resin has an infinite shelf life and the slow and fast hardener have a shelf life of a minimum of 1 year in a closed container., hope this helps, bubsteve
ID:	165238 my own boat,, thre years to build
Monkey Minion'air
stevecooper is offline
Old 12-30-2012, 03:51 AM   #19
FlyWheel
Tekton Ochroma Pyramidale
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
Nice! I'll have to remember that one.
I have never had any trouble with the resin hardening on it's own, so long as the hardener doesn't touch it - and I mean not even the vapors. What I do is dispence the resin first, seal it's bottle then dispense the hardener and mix it. This insures the resin stays completely uncontaminated.
Vipers (Colonial) or Raiders (Cylon)
Flying: AeroCraft Skimmer "2212"; Tom Hunt Miss Stik Sr.
On the shelf: AeroCraft 1913 Eastbourne
Waiting until the day I become worthy: Dave Thornton Bird of Time.
FlyWheel is offline
storage mode touche Batteries & Chargers 10 03-04-2012 02:24 AM
Lipo storage icarus46 Batteries & Chargers 4 01-09-2012 04:28 PM
Placing batteries in storage mode KeninAZ Batteries & Chargers 15 12-30-2011 08:38 PM
NiCd Battery storage RightFly Batteries & Chargers 9 12-24-2011 06:22 PM
Batt Storage FlyingBrick50 General Electric Discussions 10 11-18-2011 02:18 PM
Page generated in 0.38758 seconds with 62 queries
