Old 04-06-2011, 07:28 PM   #501
Flite-Metal
"Look Of The Real Thing"
Flite-Metal's Avatar
Club: Fort Bend R/C
Scratchbuilders Award
Default CNC Milling With ShopBot
I invite you to visit ShopBot's forum wherein you will find many CNC milling projects which might be of interest to you...
like this one: http://www.talkshopbot.com/forum/showthread.php?t=12801
Desktop Specifications
  • XYZ Movement: 24" x 18" x 4" (610mm x 460mm x 102mm)
  • Cutting Volume: 24” x 18” x 2” (610mm x 460mm x 51mm) [e.g. with 2" long cutter]
  • Footprint with Router: 35” x 28” (890mm x 711mm)
  • Footprint with Spindle: 37.5" x 28” (953mm x 711mm) [Spindle VFD fits to right side of gantry]
  • Weight: 102 lbs [without router/spindle]
  • Frame: Welded aluminum, precision ground guide surfaces
  • Deck: Aluminum "T" slot extrusion [removable]
  • Linear Bearings: Fully supported precision linear guides and blocks on each axis [THK]
  • Drive System: Motors with integral, precision-coated lead screw with anti-backlash technology on each axis [Haydon-Kirk]
  • Integral guard and dustskirt
  • Cut Speed: 4 inches per second (100mm/sec)
  • Jogging Speed: 6 inches per second (150mm/sec)
  • Resolution: 0.00025” (.00635mm)
  • Electrical System Requirements: 120V @ 20Amps [router or spindle]
  • Includes PartWorks CAD/CAM Design Software [created for ShopBot by Vectric]
  • Includes simple, quick-start set-up and ready-to-cut samples [see bit kit]
Download your free evaluation copy of Aspire 3D design software...
http://www.vectric.com/WebSite/Vectr...d_products.htm
Aspsire tutorials: http://www.vectric.com/WebSite/Vectr...torials_v3.htm
There is a lot to learn, a lot being learned, and a lot to save from what's being learned... :^)
http://www.vectric.org/video/aspire3...rview-web.html
http://www.vectric.org/video/aspire3...(STL)-web.html
Ed Clayman
"Flite-Metal For The Look Of The Real Thing"
Flite-Metal is offline
Old 04-07-2011, 06:52 PM   #502
Flite-Metal
Club: Fort Bend R/C
Default Wrapping Up The Beginning...
I will take a moment to share where we are in addition to auditing. Above I introduced Aspire and ShopBot's DeskTop
X, Y, Z, CNC mill. For many this may not immediately appear to be relative to scratch building for fear of having to
learn CAD programs.
As my intention has been since starting this thread I want to share traditional tasks and how these are effected by
technology. This without having to go to the moon...to cross the street.
Again, here are the current fuselage "cross" sections: http://004edc4.netsolhost.com/B47/B4...ersJMaster.jpg
Here I share how you can "cross" the steet...without going to the moon.
Ed Clayman
Old 04-08-2011, 04:46 PM   #503
Flite-Metal
Club: Fort Bend R/C
Default On To The Middle Phase...
You are invited to pick this project up and ask your questions here: http://www.wattflyer.com/forums/showthread.php?t=60561
Ed Clayman
Old 05-27-2011, 04:32 PM   #504
Flite-Metal
Club: Fort Bend R/C
Default Auditing Tools
Mike Wilson's maintenance manuals have provided valuable resources with which to audit. Below are a couple of extremely valuable audit files.
These were contained in the reop manual for replacement of formers after the internal ATO damaged the fuselage. The station
declarations on these have been validated...
The drawing below was scanned as a left and right half. As is the case with any printed drawing, it is subject to shrinkage. When
this happens it is not distributed evenly across the drawing. Additional abbaration occurs if the drawing is not perfectly flat on the
scanner bed when scanned.
In order to utilize the drawing below the top half of the right half has to be increased to match the balance of the perspective.
This is not difficult to do. I show it here in its raw form prior to being scaled properly.
Name:	B-47 Structural Index.jpg
ID:	148752   Click image for larger version
Name:	B-47 Structural Index2.jpg
Ed Clayman
Old 06-09-2011, 07:31 PM   #505
Flite-Metal
Club: Fort Bend R/C
Default Final Dims: Forthcoming
This image was lost in an edit of the server. Look to the "In The Middle" thread of this project for
the last dim index.
Ed Clayman
Old 07-11-2011, 02:53 PM   #506
michaelsuder
Default CAD Scale Drawings of B-47
My father flew these jets back in the day so I have always been quite interested in them.
Many years ago (late 90's) I order CAD scale drawings from a guy in England. If there is any interest in seeing these, then contact me...
Michael
michaelsuder is offline
Old 07-11-2011, 03:18 PM   #507
Flite-Metal
Club: Fort Bend R/C
Default Laste 90's CAD File
Originally Posted by michaelsuder View Post
My father flew these jets back in the day so I have always been quite interested in them. Many
Cheers, Michael
Michael,
Thank you for offering the CAD files. Yes, I would like to utilize them as another audit tool. I assume these are probably .dwg or
.dxf format thought there are many others we have the ability to work with.
Bob is doing an excellent job as he works "across" missing cross sections between what I created. A model this large mandates
as many cross sections across the virtual-terra-scape.
When 3D cut files are created as a result of my drawings they need to have the best uninterrupted slope... :^) I was amazed to
see abaritions created from what I considered minute differentials in my analog files.
With Aspire our process changes because the railing process resolves the issue of creating additional cross sections prior to Bob
receiving files.
Yes, we would like to obtain a copy of your B-47 CAD files. Please send them as an attachment to: scaleaero@gmail.com .
Just goes to show its never too late in a project for resources! Thanks for your contribution!
Ed
Ed Clayman
Old 07-11-2011, 03:31 PM   #508
Flite-Metal
Club: Fort Bend R/C
Michael,
(1) Your father piloted B-47's from when to when?
(2) Where was he stationed?
(3) Did he retain any personal memoriablia?
Unlike today's pilots, back-in-the-day pilots tended to make it a career and collected what could be considered a museum of
artifacts. These are documentation resource for scale modelers...especially with respect to the B-47 and WB-47.
Most resources I have acquired were classified until the late 70's to mid 80's. If it weren't for personal photos and recollections
it would have been exceptionally skinny.
Ed Clayman
Old 07-11-2011, 03:45 PM   #509
michaelsuder
Default Problem w/ Email....
Ed, I sent a test message to the email address you provided and got the following:
Delivery has failed to these recipients or distribution lists:
The recipient's e-mail address was not found in the recipient's e-mail system. Microsoft Exchange will not try to redeliver this message for you. Please check the e-mail address and try resending this message, or provide the following diagnostic text to your system administrator.
The following organization rejected your message: mx.google.com.
Old 07-11-2011, 04:38 PM   #510
Flite-Metal
Club: Fort Bend R/C
Default Gmail Address Error
Delivery has failed to these recipients or distribution lists: The recipient's e-mail address was not found in the recipient's e-mail system.
I corrected the address above.... I mistyped it.
Ed Clayman
Old 08-03-2011, 07:25 PM   #511
Flite-Metal
Club: Fort Bend R/C
Remember, you will find the remaining portion of this B-47E thread by clicking below:
Ed Clayman
Old 09-22-2011, 08:36 PM   #512
Flite-Metal
Club: Fort Bend R/C
I received a CD with complete stenciling for all versions of the B-47 today from the USAF.
Next task is to scale each properly for our model.
Ed Clayman
Old 10-21-2011, 10:27 PM   #513
Flite-Metal
Club: Fort Bend R/C
Ed Clayman
Old 10-24-2011, 03:38 AM   #514
Flite-Metal
Club: Fort Bend R/C
Default Salon Quality Dry Transfers.... :^)
No, I am not about to dump on you the way that DYI does. I promise I will post the proper product code aka barcode identity
of the transparency, gel, and hair spray. The above DYI needed to be explicit with respect to brand...and product. Unless the
product identity is known these retail items tend to change packaging and often the actual name of the sold-as-product.
I will set up a test bed of stencils transfered to a Flite-Metal covered surface....photograph it and post it back here for you to
judge for yourself how well the above process works.
Ed Clayman
Old 12-10-2011, 03:19 PM   #515
Flite-Metal
Club: Fort Bend R/C
I have this Russian magazine in inventory now.
Thanks ! ! ! Three additional drawings proved to be of value.
Ed Clayman
Old 12-18-2011, 08:37 PM   #516
Flite-Metal
Club: Fort Bend R/C
Default YoooooooooooooooHoooooooooooooo
Have A Very Merry Christmas & Happy Holiday Season where ever you may be this December.
http://www.scaleaero.com/HolidayGreeting11.htm
Ed Clayman
Old 12-19-2011, 01:38 AM   #517
Hircflyer
Hircflyer's Avatar
Club: Aloha State RC Club
Globetrotter Pilot
As a former B47 Crew Chief Plattsburgh AFB 1958-1963 I want to say how much I appreciate your project.
Merry Christmas to you and yours from a getting older but still RCing and still remembering wonderful times working on and being a part of aviation history.
Lifelong RC Pilot
Still 'passing gas' flying nitro and gas too!
Hircflyer is offline
Old 12-31-2011, 02:02 PM   #518
Flite-Metal
Club: Fort Bend R/C
Default We Now See In 3D... Check out the "In The Middle" thread
Hircflyer,
Glad you are enjoying this project. We now have 3D printing capability after Santa delivered our latest project tools.
Ed Clayman
Old 01-25-2012, 05:18 PM   #519
Flite-Metal
Club: Fort Bend R/C
The next section of our 1/8.6 B-47 projects is here: http://www.wattflyer.com/forums/showthread.php?t=60561
Ed Clayman
Old 02-08-2012, 02:47 PM   #520
Flite-Metal
Club: Fort Bend R/C
While I am not wanting to be seen as a sales agent for the North American distributor of the UP3D ABS
3D printer, I want to share the wealth with those who envision the value of adding a 3D printer to your
scale modeling toolbox...and only held back from doing this by about $1000 USD.
Note: v.1.0 and v.1.1 revs, aka versions of this printer are being offered in this sale.
To ORDER please go to the UP! USA Store @ www.up3Dusa.com. CLICK the golden padlock and enter promo code FCS10188
February Clearance Sale Hours 9:00am - 2:30pm, M-F while quanities last.
2012 x object Inc. | |The UP! USA Store | www.up3Dusa.com | 232 Third St. E105 | Brooklyn | NY | USA | 11215
You can also forward to a friend.
Ed Clayman
Old 03-06-2012, 01:12 PM   #521
Flite-Metal
Club: Fort Bend R/C
Default 3-03-2012 Dims
Our audited dims as of 3-03-2012
Ed Clayman
Old 03-08-2012, 04:53 PM   #522
Flite-Metal
Club: Fort Bend R/C
Default You are invited to join us at: B-47 1:8.7669th/1/9th Scale, Boeing Stratojet...In The
You are invited to join us at: B-47 1:8.7669th/1/9th Scale, Boeing Stratojet...In The Middle
Ed Clayman
Old 03-08-2012, 08:37 PM   #523
Flite-Metal
Club: Fort Bend R/C
Default B-47E Parting Points
Ed Clayman
Old 05-06-2012, 09:39 PM   #524
Flite-Metal
Club: Fort Bend R/C
Default Stencil & Placarding
The stencil and placarding index is coming along well...
Ed Clayman
Old 05-21-2012, 02:51 PM   #525
Flite-Metal
Club: Fort Bend R/C
Default Flipp'n Flaps Redoux
Sam is assembling the revised flap mechanism. Below is the inboard flap:
Pick up on the lastest here... http://www.wattflyer.com/forums/showthread.php?t=60561
ID:	160171   Click image for larger version
ID:	160172   Click image for larger version
ID:	160173   Click image for larger version
ID:	160175   Click image for larger version
Ed Clayman
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Boeing 747? CygnusX1 Electric Ducted Fan Jets 12 05-30-2009 03:56 AM
Need 3 View Of Boeing B-9 Bomber Tucson Don Foamies 3 02-24-2008 03:45 PM
BOEING 777 AIRBUS by Dragonfly?! reyes ParkFlyers 6 04-26-2007 03:21 PM
Airliner Plans Boeing 727 CarreraGTSCS Airplanes - Electric For Sale & WTB 1 06-21-2006 04:35 AM
Boeing 314 clipper mc2th Seaplanes E-Powered 5 04-01-2006 11:54 PM
Page generated in 1.00732 seconds with 79 queries
