Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Sport Planes (Formerly I/C & Gas Conversion)
Old 09-28-2006, 09:06 AM   #1
Taylorcraft_ASEL
Club: Falcons of Lake Dallas
Default Quickie 500 Racer
Folks,
I posted this on that "other" group but thought I'd do it here as well. Several years ago my son and I built a quickie 500 racer(Gyro 500 by Bridi). We framed it and never installed an engine or radio. The airplane was built for glow and at the time, we never thought about electrics. A while back I pulled it out of the attic and covered it with Monokote. We installed an Eflite 25 and 3s2p 2000 (4000 total) packs from Common Sense. A full size radio system was installed (regular receiver, standard servos). The only effort we made to lighten the plane was the addition of Lite wheels. After completion, the plane weighed 3 pounds w/o battery.
On the first flight, the plane rolled about 10 feet and began to climb like a rocket. After several seconds, my son (Jerry) said, "Dad it's getting kinda small". This plane flys like it is on rails and is a blast to fly! Vertical is not unlimited, but it will go straight up for a LONG time before falling off. Flying times run around 15 minutes(we don't fly our batteries "dry").
This was an extremely cheap and easy conversion, had we built it with electrics in mind I'm sure we could have shaved several more ounces from the airframe alone. Using smaller servos would save a few more ounces.
Anyone looking for an easy conversion of a so-called ".40 size" plane might want to look into one of these racers...they make great sport flyers.
Ken
W4SWK
Taylorcraft_ASEL is offline
Old 10-04-2006, 01:38 AM   #2
enrique1123
Landing is not optional
Nce, very nice. I really like the airplane's colors too.
I crash better than anybody else
enrique1123 is offline
Old 10-04-2006, 03:07 AM   #3
Dereck
Hi Ken
Back in the prehistoric days when the Astro Cobalts were the hottest motors in the galaxy and electricity was derived from the SCRC 1700, there were a few conversions of Q500s done using 10 cells - flew pretty good on the whole. The weights and numbers of these babies are spot on for what you used, and the weight and shape of a flatty battery are much better for their somewhat cramped fuselages - at least by electric standards.
Yours looks nicer than average - those high wingers with no dihedral and next to no vertical tails may go faster, but they are really ugly. That low winged one you have nearly looks attractive Good to hear you're enjoying her.
Wouldn't happen to have any really high resolution digitals of your conversion, by any chance?
Regards
Dereck
Who's all in favour of simple, small models with unique colour schemes!
Dereck is offline
Old 10-04-2006, 03:26 AM   #4
Taylorcraft_ASEL
Default Quickie 500
Dereck and Enrique,
Thanks for the very kind words. I do have a fairly hi-res (2240x1680)...about 3.5M. If you would like a copy just let me know where to send it. Thanks again for the compliment, I will pass it on to my son (Jerry), he built most of it when he was about 10...he's 17 now.
I have 2 boys (17 abd 16) and we still build and fly together...and yes, I am the luckiest father in the world!
Thanks,
Ken
W4SWK
Old 11-15-2008, 03:27 PM   #5
I Marauderer
GOC
TC, did you have to offset the motor any to get it to track or did you leave it a 0/0? Update on the plane and is it still around?
Barry...go fast turn left!!
I Marauderer is offline
Old 11-15-2008, 06:22 PM   #6
Taylorcraft_ASEL
Yes, the plane is still around and flyable although it has not been in the air for several months now. My son actually built the airframe around 1997 or 1998 to use an I/C .40 engine. Our club raced quickie 500 in a "club" sort of way...not real screaming competition. The firewall was set to 0/0.
Converting it to electric was really an afterthought. Additionally, my son suggested that we use the opportunity to demonstrate that electric airplanes didn't actually require special equipment to fly well. Hence, the reason for using standard radio equipment...no mini servos or receivers.
If I were to do it again, I would try the following:
1. Use mini servos (HS-81 has all the torque needed)
2. In framing the plane, I'm sure MUCH weight could be saved in wood substitution ( we used 8 oz. glass cloth with epoxy on the center section about 6 inches wide...way overkill!)
3. Use a lighter covering...we used Monokote (great stuff but there are lighter coverings available)
4. Cut down on the lipo size (sacrifice shorter flying time for lighter weight...we went for longer times to "impress" our glow buddies)
Whatever you do, look for ways to keep the plane light. Don't fall into that trap of "wow, it flies so fast but that's because it came out "heavy". (I guess that's why all the professional racers spend thousands of dollars looking for ways to make their planes "heavier"!!!)
If I can help, let me know.
Good Luck,
Ken
Old 11-15-2008, 07:35 PM   #7
I Marauderer
GOC
Thanks Ken, I use to fly F1 and 500's back in the mid seventies. You validated everything I thought needed to be done. I is very hard to find anything today. Kits are ANE (almost non existent ) and finding plans are just as difficult unless you want a composite whatever @ $500+. I don't see how some are able to afford to fly today. Anyway I digress, sorry about that. I am looking for plans for a Spickler Q 500 or derivative. I would like a low wing with slight dihedral and a conventional tail. I have found a Pit Bull by Matney Models that is the closest I have found to what I am looking for. I don't have three posts so I cant send a link the next post will have the link.
Any comments or suggestions would help.
Old 11-15-2008, 07:35 PM   #8
I Marauderer
GOC
Here is the link.
http://www.matneymodels.com/q500.html
Old 11-15-2008, 08:02 PM   #9
Taylorcraft_ASEL
Wow! Sounds as if we may be of the same "vintage"! As a matter of fact, I was taught to fly by a guy you may have heard of....Dave Shadel (with help from Steve Helms). I have built many of Glen Spicklers' kits (almost brings a tear just thinking back). I was living in Ca. at the time and we always called him "the man". The racer that we converted was a Gyro 500 from Bridi Kits... all machine cut (like Spickler) and fit together well. A company by the name of Bluejay is running the Bridi kits now and they don't show the Gyro 500 on their site. Maybe a phone call will reveal a few kits hiding in the closet or maybe they will sell plans. As I recall, the kit was around 50.00. RCM is also still carrying plans and they have a few listed for Quickies.
I agree times have changed but I can just close my eyes and go back to flying my Kraft radio (brown/white flag), Bridi Kaos (machine cut parts), and K&B engine (Perry carb.). These are memories that no high dollar radios or super composite ARFs' will ever replace.
Ken
Old 11-15-2008, 08:25 PM   #10
I Marauderer
GOC
Brown and White. 72.080, that was my frequency. I was the only one on Oahu, Hawaii flying on it. I had both Kraft transmitters and my Proline transmitter tuned to all six of my flight packs two kraft and four Cannon. My neighbor was my radio repair guy. He had a dual trace scope and inter tuned everything for me. The new 2.4 systems are great. I have started with the Spektrum DX7 and will go from there.
Old 04-16-2016, 08:45 PM   #11
pbs_rudder
Taylorcraft ASEL (Ken)
I was just given a Quickie 500 racer called the EDGE by Tom Strom and Tony Huber. Came with no plans. I want to make it a sport electric and your post got my eye. First is there dihedral in the wing? The Kit came with foam core wings and 3/32 planking no landing gear. your idea of mini servos is great. the kit has a fiber glass fuselage and some hardware. I was thinking of extending the fuse in front about 2" to keep from adding weight to the nose, and using alum landing gear in front of wing, plank with 1/16, and generally keep the plane as light as I can, any more ideas on how to make lighter would be great. I have fond memories of the Kraft Radios I belonged to the Indianapolis RC Club in the 50's been flying for a long time.
Ron
pbs_rudder is offline
Old 04-18-2016, 03:59 AM   #12
Taylorcraft_ASEL
Wow! My 10 year old post just got a response! Things have changed since I converted the Quickie...these days we don't "convert", just bolt on a motor and go! For sport flying I would put about an inch of dihedral under each tip...servos similar to HS81's would be great. I used an Eflite 25 but there are much better choices now (and cheaper). 4s lipo around 3500 should give about 8 or 9 minutes of good flight time.
Keep me posted!
Ken
P.S. I still have the original Quickie...in great flying condition!
Ron
quickie 500 conversion? jessejoe23 Sport Planes (Formerly I/C & Gas Conversion) 6 11-15-2008 03:22 PM
Quickie 500 Plans Urbangorilla Hi-Performance and Sailplanes 1 09-30-2007 02:05 AM
Quickie 500 Plans Urbangorilla ParkFlyers 0 09-25-2007 08:50 PM
Keith Rider Racer -- R-6 Eight Ball NIB Kit!! 400 Size Racer!!! paranoia Airplanes - Electric For Sale & WTB 2 09-05-2007 09:47 PM
Page generated in 0.16600 seconds with 44 queries
