Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Delta & Flying Wings
Old 10-15-2012, 08:15 PM   #2426
Ben D wing
Ben D wing's Avatar
View Ben D wing's Gallery50
Club: Leek and Moorlands Model Gliding Association.
Hi to you too, not much happening in this thread any more is there?
Here's an update on my latest Funjet installation: I'm now using a carbon spar instead of the supplied (heavy!) GRP version, and I've found a really cheap, lightweight motor that gives excellent performance for it's size. It's a HobbyKing outrunner and at less than $10 it's a steal! http://www.hobbyking.com/hobbyking/s...tor_250w_.html
This is hooked up to an APC 6'' x 4'' sport (ic) prop, 30A ESC and 1000mAh 4s LiPo, again from HobbyKing. http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
The motor is drawing 19.4A @ 287W (in), and with the AUW of the model at 410g (14.4 ozs) it has a very healthy PWR of 319W/Lb. This combination enables the plane to be flown very slowly, but open the taps and it accelerates extremely quickly with a respectable top speed, circa 80MPH.
Incidentally, I have junked the heavy plastic jetpipe and replaced it with a rolled 1/64th ply tube, and also used a 1/8th'' liteply motor bulkhead let into the rear of the model as these small motors don't need much to hold them in place. The decals are a custom set from Modell-Bau Guru in Germany and are far lighter and thinner than the MPX decals supplied with the Ultra. They ain't cheap and you have to go to Germany to buy 'em!
ID:	163457 Lightweight Funjet & Funjet Ultra
The original Dead-Stick Dummy!
Ben D wing is offline
Old 02-05-2013, 04:20 AM   #2427
Robio
So after two years of getting some stick time and looking at the FJ in its box I'm going to put it to the sky... I have two options for power systems. An Axi 2808/16 1850kv 30a esc or a HiMaxx 2825 2700kv 60a esc. What can I expect from either? Thought the lighter setup will be more versatile from what I've read.. Guess I'm behind the curve with the FJ Ultra being out but I'm sure the original will be a blast as well.
Rob........
Robio is offline
HELP no fun w/ fun jet sheldo78 Pusher Park Jets 15 10-14-2008 05:27 AM
funjet jabba1 Pusher Park Jets 5 10-11-2008 12:54 PM
Funjet-Jet Fun... Elfwreck Delta & Flying Wings 6 03-25-2008 11:20 PM
Funjet Help wolftg Delta & Flying Wings 1 04-27-2007 12:25 PM
What's fun? and/or when does the fun begin? rocket_jim Beginners 76 07-16-2006 11:29 PM
Page generated in 0.25099 seconds with 24 queries
