Old 01-03-2007, 01:48 AM   #1
Sky Sharkster
Sky Sharkster's Avatar
View Sky Sharkster's Gallery11
Globetrotter Pilot
Friends: (20)
Here's The "A" through "L" Listing, A little farther down will be "M" through "Z". Hope you find what you're looking for!
Feel free to add comments, suggestions or note any non-working links.
On the "Info" categories I've tried to put the most basic link first and added an "X" to the link that seems to be the easiest introduction to the subject.
Ron
General Interest Links
http://homepages.ihug.co.nz/~atong/ Alan Tong's site, 1000+ Links. Kinda' like this page only 5 times bigger!)
http://homepage.mac.com/kmyersefo/ (Great links and descriptions from one of the true pioneers of Electric flight)
http://www.pldaniels.com/flying/balsa/index.html
http://www.eflight101.com/
http://www.flyelectric.ukgateway.net/index.htm
http://www.ezonemag.com/pages/faq/index.shtml Thanks, Ron!
Adhesives
http://www.airfieldmodels.com/inform.../adhesives.htm (Info, All Types)(X)
http://www.pldaniels.com/flying/balsa/glues-guide.html (Info, All Types)
http://www.hobby-lobby.com/adhesive.htm
http://www.greatplanes.com/accys/adhesives.html
http://www.mercuryadhesives.com/MercuryFAQ.htm (Info, CA)
http://www.westsystem.com/ (Epoxy)
http://www.jperkinsdistribution.co.u...&Navmain=Glues (UK)
http://www.zapglue.com/
http://findarticles.com/p/articles/m...03/ai_n8841950 (M.A.N. Article, Adhesives)
Aerial Photography (Also see FPV, Flight Data)
http://www.rcapa.net/home.htm (Remote Control Aerial Photography Association)
http://www.rc-soar.com/tech/dwaerialphoto.htm
http://www.hicam.com.au/
http://astrocam.aea6.k12.ia.us/
http://www.rc-helicopters.net/remote...elicopters.htm
http://www.boostervision.com/cart/sc...?idCategory=36
Aerobatics + 3D (Thanks, Fred!)
http://www.rc-airplane-world.com/bas...erobatics.html
http://www.mini-iac.com/DesktopDefault.aspx
http://www.personal.psu.edu/faculty/...3_document.htm
http://www.geistware.com/rcmodeling/...vers/index.htm (Thanks, Tom!)
http://www.scootworks.com/rdrc/aerobat.html
http://plawner.net/6/events/aerobatics_list.html (Thanks, Frank!)
http://www.3dhobbyshop.com/HowToFly3DVids.htm (3D Videos)
Aerodynamics, Airfoils, Model Design
http://www.airfieldmodels.com/inform...sign/index.htm (X)
http://www.profili2.com/eng/default.htm
http://www.mh-aerotools.de/airfoils/index.htm
http://www.rcadvisor.com/guest
http://sky.prohosting.com/air2/index2.htm
http://www.lems.brown.edu/vision/peo.../Ch6_wing.html (Airfoil + Wing Design)
http://www.grc.nasa.gov/WWW/K-12/airplane/short.html
http://www.eskimo.com/~billb/wing/airfoil.html
http://www.desktopaero.com/appliedae...e/welcome.html (Full-Scale Aerodynamics)
http://tracfoil.free.fr/airfoils/indexE.html (Sailplane Airfoils)
http://www.rexresearch.com/klinfogl/klinfogl.htm#ultim (Kline/Folleman KF Airfoil)
http://www.lecun.org/hobby/dzepron.html (Jedelsky Airfoil From Depron Foam)
http://www.jimbobwan.com/scalcalc.htm (Scale Conversion Calculator, Thanks, Frank!)
http://www.djaerotech.com/dj_askjd/d...tail_coef.html (Tail Volume Coefficient)
http://en.wikipedia.org/wiki/Longitu...atic_stability (Longitudinal Stability)
http://www.rcfctoronto.ca/Washout.html (Washout-Explained)
http://www.airfieldmodels.com/inform...ng_loading.htm (Wing Loading Chart)
http://www.palosrc.com/instructors/basicdes.pdf (Basic Model Design Parameters) Thanks, JetPlaneFlyer!
Ailerons; See Control Systems
Airbrushes, Parts
http://h1072147.hobbyshopnow.com/ser...tBy=ProdNumAsc
http://www.modelflight.com.au/accessories_airbrush.htm (AU)
Antenna; See Radio Control Transmitters, Receivers, Accessories
AutoGyros
http://www.autogyro-rc.com/Kits.html
http://www.icare-rc.com/rainbow.htm
Autopilots; See Gyros, Autopilots, Failsafe Devices
Balsa Suppliers, Plywood, Spruce, Information
http://www.airfieldmodels.com/inform...ding/balsa.htm (X)
http://www.pldaniels.com/flying/bals...roperties.html
http://www.midwestproducts.com/catal...d=15&sa2_id=25
http://www.specializedbalsa.com/products/index.php
http://www.freeflightsupplies.co.uk/ (UK)
http://www.kits4models.com/BALSA.htm (UK)
http://www.lonestar-balsa.com/index.php (Thanks, Frank!)
http://www.sigmfg.com/
http://www.nationalbalsa.com/balsa.htm (Thanks, Pburt!)
http://www.balsausa.com/ (Thanks, Tom!)
http://www.balsacentral.com/epages/a...s/balsacentral (AU. Thanks, Huffy!)
http://www.aircraftspruce.com/ (Aircraft Spruce, Balsa) Thanks, Possum!
Battery, Basics
http://www.redrockethobbies.com/RC_A...sics_s/263.htm (X)
http://www.maxamps.com/lipo-care.php (LiPoly Safety Precautions, Info)
http://www.srbatteries.com/eftindex.htm
http://www.batteryuniversity.com/
http://adamone.rchomepage.com/guide3.htm
http://www.fmadirect.com/tech_data/index.htm
Battery Chargers, Balancers, Test Equipment; Voltmeters, Wattmeters
http://www.astroflight.com/
http://www.fmadirect.com/products.htm?cat=45&nid=4
http://www.medusaproducts.com/Power-...rs/PA-Main.htm
http://www.e-flight.co.uk/shopdisplaysubcat.asp?id=161 (UK)
http://www.thunderpower-batteries.co...dBalancers.htm
http://www.icare-rc.com/chargers.htm
http://www.electrifly.com/chargers/gpmm3153.html
http://robotbirds.com/catalog/index.php? (UK)
http://www.puffinmodels.com/category.php?dept=225 (UK)
http://www.skyhooks.ca/WES.htm#chargers (Micro)
http://www.aeromicro.com/Catalog/aux...7_products.htm
http://www.e-flight.co.uk/shopdispla...cts.asp?id=175 (UK)
http://www.allerc.com/index.php?cPat...er&filter_id=3 (Battery Charger Balance Connectors, Harness, Accessories)
http://www.marcee.org/Articles/PCPowerSupply.htm (12V Power Supply From Old PC) Thanks, Chellie!
http://www.wattflyer.com/forums/showthread.php?t=39393 (12V Power Supply Links)
Battery Eliminator Circuitry (BEC), Battery Voltage Regulators
Low Voltage Cut-OFF (LVC)
http://www.stefanv.com/rcstuff/qf200312.html (X)
http://www.medusaproducts.com/BECs/BEC%20Main.htm
http://www.hobby-lobby.com/ubec.htm
http://www.azarr.com/speed_controls.htm
http://www.radicalrc.com/shop/?shop=...174886&cat=154
Batteries, Suppliers
http://www.srbatteries.com/rc.htm
http://www.fmadirect.com/category.htm?id=3
http://www.puffinmodels.com/category.php?dept=165 (UK)
http://www.e-flight.co.uk/lipo-battery-packs.asp (UK)
http://www.thunderpower-batteries.com/
http://www.maxamps.com/categories.php?cat=8
http://www.rcaccessory.com/index.asp...TS&Category=54 (A123 Packs, Charger)
http://www.hobby-lobby.com/lithium-polymer.htm
http://www.cheapbatterypacks.com/?si...an=PRC&cat=P20
http://www.all-battery.com/index.asp (Single Cells + Packs, LiPo, NiMh, Nicad)
Battery Voltage Regulator (RX Battery)
http://radicalrc.secure-mall.com/sho...86&cart=518447
http://www.fmadirect.com/products.htm?cat=58&nid=38
http://www.allerc.com/advanced_searc...ulator&x=6&y=9
http://www.dionysusdesign.com/produc...d6f370f0bf14c7 (Voltage Isolator)
BEC, UBEC See Battery Eliminator Circuity
Beginners, Basic R/C Also See Glossary
http://adamone.rchomepage.com/guide.htm (X)
http://www.geistware.com/rcmodeling/...er_1/index.htm
http://www.in-miniature.co.uk/aircraft.asp
http://www.easyrc.com/radiosystems/index.html (Radio Systems, Explained)
http://www.rc-airplane-world.com/rad...trol-gear.html (R/C Transmitter, Receiver, Servos, Frequencies, TX Modes, Explained)
http://www.rc-airplane-world.com/electric-rc.html (Wiring ESC, Rx, Servos)
Books
http://www.samsmodels.com/ (, Home Page, See Section "M". UK)
http://www.modelaircraft.org/museum/booklist.asp
http://www2.towerhobbies.com/cgi-bin/wti0093p.pgm?C=ZAJ
http://www.peck-polymers.com/html/books/miscbooks.htm
http://www.hrunway.com/
http://www.airfieldmodels.com/inform..._materials.htm
Building, Articles, Links, Books: See Scratch Building
Building Supplies; See Tools
Bungee Launcher See Flying Site Equipment
Calcs; See Electric Motor Calculators
Canopies, Pilot Figures, Scale Details
http://www2.towerhobbies.com/cgi-bin...Q2130&C=ATDGPM (Canopies)
http://www.wattflyer.com/forums/show...d=1#post430099 (Heat-shaping Canopies From Plastic Bottles)
http://www.world-war-2-airplane-model.com/canopies.html (Masking + Painting Canopies)
http://www.wattflyer.com/forums/showthread.php?t=8769 Coloring And Tinting Canopies)
http://www.sigmfg.com/cgi-bin/dpsmar...FV4.html?E+Sig (Click On "Aircraft Accessories" Then "Scale Accessories"; Canopies, Pilot Figures, Scale Instruments, Dummy Engines, Cowls)
http://www.hobby-lobby.com/pilots.htm (Pilot Figures)
http://www.wingmfg.com/Pages/Wac2.html (1/7th, 1/8th Pilot Figures)
http://findarticles.com/p/articles/m...10/ai_n9430401 (M.A.N. Article, DIY Canopies)
http://www.horizonhobby.com/Search/D...tId=APD&Page=1 (Pilot Figures, Decal, Insignia Sheets)
http://www.darehobby.com/accessories-pilots.htm (Pilot Figures)
http://www.rc-warbirds.com/index.php/cPath/71 (Pilot Figures)
http://www.warbirds-rc.com/Store/sa-pf.html (Pilot Figures)
http://www.easybuiltmodels.com/spare.htm (Pilot Figures, 1/10. 1/12, 1/14, 1/15, 1/16, 1/17, 1/19, 1/20. All Military.
http://www.justpilots.ca/ (Pilot Figures, Thanks, Dave!)
http://www.jethangar.com/ (" " ")
http://www.clubhobbies.com/index.php...th=184_185_198 (Pilot Figures, Decals, Scale Insignia)
http://parkflyerplastics.com/cart/in...ort=20a&page=1 (Pilot Figures, Bombs, Missles, Engines)
Carbon Fiber See Composites
Catapult Launcher See Flying Site Equipment
Center Of Gravity (C.G., C of G) Information Also See Aerodynamics, Flight Trimming
http://www.bakehead.com/rc_cg.htm
http://sky.prohosting.com/air2/cg_calc.htm
Center Of Gravity (G.G., C of G) Testers See Tools
Combat (R/C Aircraft Combat)
http://www.rccombat.com/ (Glow + Electric Powered Combat)
http://www.fatlion.com/sailplanes/combat.html (Slope Combat, Links)
http://www.combatwings.com/catalog/main.php
http://aerofoam.com/
Composites, Information
http://www.pldaniels.com/flying/bals...op-howtos.html (X)
http://www.rcfoam.com/cart.php?page=...ts___densities (Foam Densities, Weights)
http://www.sciencemaster.com/columns..._composite.php
http://www.cstsales.com/tutorials.html
http://home.fuse.net/ryan/download.htm
http://members.fortunecity.co.uk/slmohr/rcinterest2.htm (Hot Wire Foam Cutting Tutorial)
http://www.flyelectric.ukgateway.net/matter.htm
http://www.airplane-model.com/tech-built-up-d-box.html (D-Box Composite Tutorial) (X)
http://home.fuse.net/ryan/foamwing.htm (Balsa-Sheeting Foam Wings)
http://webpages.charter.net/rcfu/Con.../FoamWing.html (" " ")
http://www.nasascale.org/howtos/pro-bond.htm (" " ")
Composites, Suppliers
http://www.acp-composites.com/home.php
http://www.foamfly.com/home.php?cat=32
http://www.goodwindskites.com/merch/...?cat=framework
http://www.cstsales.com/products.html
http://www.da-graphite.com/index.html
http://composite-laminates.com/g10.htm (G10, G11 Sheets)
http://www.freeflightsupplies.co.uk/hitech.htm (UK)
http://www.kits4models.com/BALSA.htm (Depron, Polystyrene, Blue foam, CNC foam wing cutting, Carbon rod, strip, cloth, tow. UK)
http://2dogrc.com/ecommerce/os/catal...ber-c-120.html (Carbon Fiber Rods, Strips, Landing Gear, Servo Arms)
http://www.graphtechrcshop.com/main.sc (Composite Parts; Main Landing Gear, Spinners, Rods, Tailwheel Assemblies, Flat Panels)
http://www.pratthobbies.com/proddeta...?prod=SL1%2D20 (Kevlar Thread)
http://www.apogeerockets.com/shock_cord.asp (Kevlar Thread, Shock Cord)
http://www.slofly.com/cart/
http://www.expresscomposites.com/
http://www.robotcombat.com/marketplace_metals.html
http://www.flyingfoam.com/
http://www.compufoamcore.com/ (Custom Foam Cutting)
http://hotwirefoamfactory.com/home.php (Foam Cutting Tools)
http://www.instructables.com/id/Hot-wire-foam-cutter/ (DIY Foam Cutter)
http://www.eflightwiki.com/eflightwi...e_foam_cutting (Hot Wire Cutting Info, Links
http://club.cycom.co.uk/hotwire/Hot_...rene_foam.html (DIY Foam Cutter)
http://www.mwcores.com/servlet/StoreFront (Foam wing cores, pre-cut. Many sizes and shapes)
http://steelheadproducts.com/wingcores.htm (Foam Wing Cores) Thanks, vstar2007!
Connectors, Wiring-Electrical
http://www.hobby-lobby.com/connectors.htm
http://www.robotcombat.com/marketplace_connectors.html
http://www.jperkinsdistribution.co.u.../C%20equipment (UK)
http://www.powerwerx.com/
http://www.fmadirect.com/products.htm?cat=56&nid=18
http://www.wsdeans.com/products/index.html
http://www.ecubedrc.com/connectors.htm
http://www.3dhobbyshop.com/SearchRes...?CategoryID=23 (EC3, Bullet, Deans Micro, 3-Pin, 4-Pin, Ultra, Banana, JST, Tamiya)
Control Line Flying (U-Control)
http://dkd.net/clmodels/links.html (World-Wide Links)
http://home.att.net/~philbrown36641s5/clhomepage.html (Orgs, Clubs, Links)
http://www.aeromaniacs.com/historyofcl.htm (History)
http://www.aeromaniacs.com/Suppliers.html (Links to Suppliers)
http://stunthanger.com/smf/index.php
http://www.pennvalleyhobbycenter.com/ (Kits, Accessories, Finishing Materials)
http://www.horizonhobby.com/Products...ProdID=EFLA172 (Timer for Electric Control Line)
Control Systems, Information
http://users.colfax.com/dhart/prr/Ri...2003/Mar03.htm (Hinges; Types, Uses, Adhesives)
http://www.wattflyer.com/forums/showthread.php?t=34600 (Making Hinges From Iron-On Material)
http://www.blackflight.com/intro_rc/intro_rc_radio.asp (Terms; Flaperons, Spoilerons, Crow Mixing, Elevons, Modes, Dual Rates, Exponential "V" Tail) (X)
http://www.fatlion.com/sailplanes/vtail.html ("V" Tail)
http://www.wattflyer.com/forums/showthread.php?t=35181 (Aileron Torque Rods + Differential, Photos + Text)
http://www.wattflyer.com/forums/showthread.php?t=54912 (Pushrod and control surface connections, explained) Thanks Chellie + Aeronerd!
http://www.marcee.org/Articles/ControlArms.html (Pull Pull)
http://www.mindspring.com/~rellis2/rcpattrn/ppull.htm (Pull Pull) (X)
http://www.rcgroups.com/forums/showt...=615748&page=3 (Pull Pull)
http://members.cox.net/bdfelice/Ackerman/ackerman.htm (Ackerman Effect For Pull-Pull) Thanks, Rodneh!
Control Systems, Supplies Also See Gyros, Autopilots, Mixers
http://www2.towerhobbies.com/cgi-bin...7p?CATEGORY=QF (Control Arms, Pushrods, Cable, Linkage)
http://www.motrolflyusa.com/html/accessories.html (Blenderm Tape)
http://www.robart.com/ (Hinges, Control Horns)
http://searchrc.horizonhobby.com/ind...500&N=5035+816 (Sullivan Pushrods, Clevis')
http://www.hobbypeople.net/prdcls/pushrd01.asp (Pushrods, Clevis, Control Horns, Torque Rod Sets)
http://www.irfmachineworks.com/rds/ (Rotary Driver System, RDS)
Covering and Finishing, Information
http://www.rc-airplane-advisor.com/h...-covering.html (X)
http://www.wowplanes.com/How_to.htm (Foam) (X)
http://www.wattflyer.com/forums/showthread.php?t=51697 (Types of covering, Tutorials on covering types. Iron-On, Silk, airbrushing, etc.)
http://www.rcgroups.com/forums/showthread.php?t=711624
http://pldaniels.com/flying/balsa/fi...yurethane.html (X) (Water-Based Polyurathane (WBP) Over Fiberglass Cloth)
http://www.coverite.com/accys/covr2700.html (Temperature Settings For Covering, popular Brands)
http://winshiprc.tripod.com/painting_techniques.htm
http://www.wattflyer.com/forums/showthread.php?t=23638 (Lettering, Numbers From Iron-On Material)
http://www.wattflyer.com/forums/showthread.php?t=20546 (Silk over Balsa, Thanks, Paul!)
http://www.wattflyer.com/forums/show...t=23572&page=2 (Japanese Tissue over Balsa, "")
http://www.wattflyer.com/forums/showthread.php?t=22327 (Silk With Polycryllic over Foam, "")
http://www.wattflyer.com/forums/showthread.php?t=21972 (Patching Film Coverings, "")
http://www.smoothair.rchomepage.com/...ithSolite1.htm
http://www.wattflyer.com/forums/showthread.php?t=10443 (Weights of Covering Materials)
http://www.modelflight.com/chemical.html
Covering And Finishing, Materials
http://www2.towerhobbies.com/cgi-bin...p?&L=COVR.html
http://www.wowplanes.com/product_inf...roducts_id=101 (Coating For Foam Finishes)
http://www.skyhooks.ca/covers.htm#RM
http://www.stevensaero.com/shop/home.php?cat=305
http://www.atlantahobby.com/shopdisp...ring+Materials
http://www.hobby-lobby.com/covering_...ls_158_ctg.htm (PolyCover, LiteSpan, SuperFabric, SuperKote)
http://www.jperkinsdistribution.co.uk/index.php (UK)
http://www.solarfilm.co.uk/
http://www.pennvalleyhobbycenter.com/ (Tissue, Silkspan Dope)
http://www.fast-pack.com/colored_tape.html (Colored Sealing Tape)
Decals, Decal Paper, Graphics;
http://www.callie-graphics.com/index.php
http://www.mcgpaper.com/decals.html
http://www.supercaldecals.com/super1.html
http://www.beldecal.com/inkjet-instructions.html
http://www.cajunrc.com/Cajun_Graphic...cial/index.htm (Graphics)
http://www.ultimatedecals.com/?gclid...FSUmYAodpXzxtQ (Decals)
http://www.davidleftleygraphics.com/ (Graphics, UK)
http://www.pro-mark.com/ (Graphics)
http://homepage.ntlworld.com/y.j/shop/ (Decals, UK)
http://www.aerographix.biz/index.htm (Graphics)
http://vinylgraphicsbygreg.com/Model..._aircraft.html (Vinyl Graphics, Decals)
Differential: See Control Systems
DIY Brushless Motors
http://www.flyelectric.ukgateway.net/motors.htm (Photo-Illustrated Tutorial On DIY Motors) (X)
http://groups.yahoo.com/group/lrk-torquemax/
http://www.torcman.de/peterslrk/index_eng.html Thanks, Ron!
http://www.rcgroups.com/forums/showthread.php?t=240993 (DIY Tips and Tricks) Thanks, Ron!
http://www.micronradiocontrol.co.uk/ (UK)
http://www.komodohobby.com/
http://www.gobrushless.com/shop/inde...brushless+kits
http://www.strongrcmotors.com/
http://www.aero-nuts.com/index.php?c...4edc4f0037b8ad
http://aircraft-world.com/shopdispla...%2DROM+and+Acc
Electric Ducted Fans (EDF)
http://www.ductedfans.com/propulsion.html
http://www.rcuniverse.com/magazine/a...article_id=982 (EDF Info, Links)
http://www.storacingproducts.com/rc-.../198/index.htm (AU)
http://www.shredair.com/fan.html
http://www.rbckits.com/
http://www.electricjetfactory.com/
http://www.jethangar.com/Ducted%20Fans/df.html
http://www.tamjets.com/index.php
http://aeromicro.com/catalog/ducted_...9_products.htm
http://www.airpowernet.com/twe/index...1127f5ba7dd797 (Taiwan, R.O.C,)
http://www.jperkinsdistribution.co.u...flight%20items (UK)
Electric Motors, Basics
http://adamone.rchomepage.com/guide5.htm (X)
http://www.slewin.clara.net/elec/tmotor.htm (Brushed vs Brushless, Explained)
http://www.gobrushless.com/kb/index....01_-_Chapter_1
http://www.modelflight.com.au/electr...ess_motors.htm
http://www.wattflyer.com/forums/showthread.php?t=24238 (Choosing An Electric Power System For Your Model)
http://www.rcgroups.com/forums/showt...ght=peter+khor (Re-Timing Brushed Electric Motors. Photos and Text)
http://www.wattflyer.com/forums/show...?t=5788&page=2 (Water Break-In, Brushed Motors)
http://www.wattflyer.com/forums/showthread.php?t=35216 (Testing Brushless Motors) Thanks, Ron!
http://www.elektromodellflug.de/ (Electrical Connectors, Tests. Site In German, translation via' Babblefish http://babelfish.yahoo.com/) " "
Electric Motor, Calculators
http://brantuas.com/ezcalc/dma1.asp (Free)
http://www.adamone.rchomepage.com/calc_motor.htm (Free)
http://www.badcock.net/ (Power Train ****ysis, Free)
http://www.motocalc.com/
http://www.slkelectronics.com/ecalc/index.htm
http://www.drivecalc.de/
http://www.rcgroups.com/forums/showthread.php?t=606703 (Complilation of Calculators) Thanks, Ron!
Electric Motor, Accessories (Also See Geardrives, Electronic Speed Controllers, Propellers, Motor Mounts)
http://www.allerc.com/index.php?cPat...1e96b0b70e3947
http://www.aeromicro.com/Catalog/gea...9_products.htm
http://www.micronradiocontrol.co.uk/gearbox.html (UK)
http://www.skyhooks.ca/WES.htm#brushless (Micro)
http://aircraft-world.com/default.asp?id=18
Electric Motors, Manufacturers + Distributors
(Moved to "Power Systems" Forum) Go here;
http://www.wattflyer.com/forums/show...528#post457528
Electronic Speed Controllers (ESC)
http://www.rcgroups.com/forums/showthread.php?t=444961 (X)
http://www.rcgroups.com/forums/showthread.php?t=140454 (ESC DIY Design, Brushless) Thank, Ron!
http://www.rcgroups.com/forums/showt...hreadid=157193 (ESC Diy Design, Brushed) " "
http://www.skyhooks.ca/WES.htm#esc (Micro)
http://www.castlecreations.com/products.html
http://www.fmadirect.com/products.htm?cat=2&nid=15
Elevator, Elevons: See Control Systems
Fiberglass See Composites
Flaps: See Control Systems
Flight Data, Inflight Recording Devices, Telemetry (Also see FPV, Aerial Photography
http://www.eagletreesystems.com/
http://www.rcreporter.com/products.html
http://www.hexpertsystems.com/zlog/index.html
http://www.hyperflight.co.uk/product...ic+%26+gliders (UK)
http://home.epix.net/~rcbrust/
http://www.aerotelemetry.com/
http://www.intelligentflight.com/store/
Flight Simulators See Simulators
Flight Trimming
http://www.geistware.com/rcmodeling/...tics/setup.htm (X)
http://members.aol.com/bentleyflyers/trimmingchart.html
http://www.nsrca.org/trimA.htm
http://www.rcplanetalk.com/trim.html
http://www.palosrc.com/instructors/trim-chrt.htm
http://www.willingtons.com/mymac/model_trimming.htm
http://www.greatplanes.com/accys/field-equipment.html (Flight Box, Electric)
http://www.ripmax.com/7index.asp?cat...electedtab=080 (Flight Boxes, UK)
http://www.aerospectra.com/ (Frequency Scanner)
http://www.jperkinsdistribution.co.u...ld%20equipment (Bungee, UK)
http://www.grasshopperwinch.com/ (Glider Winch)
http://irfmachineworks.com/lbwinch/ (Glider Winch)
http://www.tdmsoftware.com/TDMmodels/ (Plans For DIY Catapult Launcher)
http://www.rbckits.com/shop/index.ph...&productId=139 (Bungee Launcher)
http://aerofoam.com/hosemonster.html (Bungee Launcher)
http://www.pylonworld.com/rc_pylon/rc_pylon.htm (DIY Pylons For Racing)
http://www.radarguns.com/bushnell-ra...ns-101900.html (Radar Gun-Airspeed)
http://www.compactappliance.com/xq/J...3Ejumpstarters (Portable 12V Power Supplies)
Foam See Composites, Covering And Finishing Techniques, Covering And Finishing Materials
FPV (R/C Video Piloting)
http://www.hobby-lobby.com/fpv.htm
http://www.rangevideo.com/
http://www.headplay.com/
http://www.blackwidowav.com/
http://www.gowiththeshark.com/index.html
http://www.rcgroups.com/video-piloting-fpv-rpv-469/ (Info, Links)
Free Flight
http://www.faimodelsupply.com/
http://www.freeflight.org/index.htm
http://www.kpaero.com/ProductReport....gory1=electric (Timers + Power Systems For E-Free Flight) UK
http://www.ualberta.ca/~khorne/
http://w-hobby.com/?p=News (F.A.I. Competition Free Flight Kits and Built Models, F1A, F1B, F1C, F1E, F1J. Circle-Towhooks, Towline, Composite Material, more)
http://www.glidetek.com/ (F.A.I. Competition models, Accessories, Tools)
http://www.aalmps.com/
http://www.arizonamodels.com/
http://www.smallflyingarts.com/
http://www.pensacolafreeflight.org/p...p?pageid=13152 (Club Site, Great Articles!)
Frequency Scanner See Flying Site Equipment
Gearboxes, Geardrives
http://www.stefanv.com/rcstuff/qf200003.html (X)
http://www.icare-rc.com/gearboxes.htm
http://www.nesail.com/categories.php...1d18c455134793 (Mega, MP Jet, Permax, PKZ, Promaxx, VK Geardrives)
http://www.electrifly.com/motors/gearboxes.html
http://www.hobby-lobby.com/gear400.htm
http://www.e-flightline.com/gearboxes.htm (Cobri, Inner Demon Geardrives)
http://www.bsdmicrorc.com/index.php?...ID=48&offset=0 (Micro)
Gliders See Soaring
Glossary, model Aviation Terms
http://www.airfieldmodels.com/inform...sary/index.htm
http://www.greatplanes.com/glossary.html
http://www.bmfa.org/resources/glossary.html
http://www.rcuniverse.com/community/...s=0&sort=1&key
Graphite; See Composites
Gyros, Autopilots, Failsafe Devices, Mixers
http://www.futaba-rc.com/faq/faq-gyros.html#q340 (Gyro FAQs)
http://www.fmadirect.com/products.htm?cat=20&nid=6 (Flight Stabilization Systems)
http://www.micropilot.com/ (Autopilot)
http://www.futaba-rc.com/radioaccys/futm0999.html (Autopilot)
http://www.aero-nuts.com/index.php?c...ea39f0f56bb7cf
http://www.radicalrc.com/shop/?shop=...7&cart=1387015 (V-Tail, Elevon Mixer)
http://www.maxxprod.com/mpi/mpi-6.html (Gyros, Low Battery Warning, Failsafe)
http://www.mikes-models.co.uk/index....ex&cPath=31_54 (failsafe, UK)
http://www.voltmagic.com/index.htm (Airborne Systems Monitor)
http://www.hobby-lobby.com/gyros.htm (Gyros)
Hardware (Nuts, Bolts, Screws, etc)
http://www.microfasteners.com/
http://rtlfasteners.com/RC/index.html
http://www.greatplanes.com/accys/gpmq3300.html
Helicopters
http://www.ircha.org/ (International Radio Controlled Helicopter Association)
http://www.rchelimag.com/forum/
http://www.redrockethobbies.com/RC_H..._Shop_s/13.htm
http://www.hobbytron.com/RCHelicopters.html
http://www.heliguy.com/
http://www.rc-helicopters.net/index.html
http://www.electric-rc-helicopter.com/
High Start See Flying Site Equipment
Hinges See Control Systems
Hotliners (F5B)
http://www.mh-aerotools.de/airfoils/f5b_models.htm (A Typical F5B Model)
Indoor Flying See Micro + Indoor Models
Jetex, Rapier Jet
http://jetex.org/history/rebirth.html (History of Jetex, Links)
http://www.shortysbasement.com/
http://www.samsmodels.co.uk/ (UK)
http://www.easybuiltmodels.com/jx.htm
http://www.smallflyingarts.com/Archi...ex/jetex_2.htm
http://www.freeflightsupplies.co.uk/jetex.htm (UK)
Kevlar See Composites
Kits
http://www.wattflyer.com/forums/showthread.php?t=14868
Landing Gear, Wheels, Retracts, Skids, Skis, Floats
http://www.greatplanes.com/accys/gpmq1800.html
http://www.hobby-lobby.com/landinggear.htm
http://www.tntlandinggear.com/
http://www.jperkinsdistribution.co.u...in=Accessories (UK)
http://www.jetmodelproducts.com/landing.htm
http://millenniumrc.com/X-Gear.html (Upgraded "Slow Stick" L.G.)
http://www.graphtechrcshop.com/category.sc?categoryId=2 (Composite Landing Gear, Many Sizes)
http://www.rc-warbirds.com/index.php/cPath/71_82 (Micro Air Retracts)
http://www.atlantahobby.com/shopdisp...Wheels%2FSkids
http://findarticles.com/p/articles/m...08/ai_n8820443 (M.A.N. Article, Skis + Floats)
http://www.hobby-lobby.com/floats.htm (Floats)
http://www.greatplanes.com/accys/gpmq1870.html (Floats, Wood Kits)
http://www.classicaero.com/main.php (Floats, Wood Kits. 4 Sizes)
http://www.allerc.com/product_info.php?products_id=675 (GWS Floats)
http://www.seacommander.com/ (Floats)
Laser Cutting
http://www.manzanolaser.com/id3.html
http://www.litkoaero.com/model_aircr...tting_indv.php
http://www.fxmodels.com/lasercutter.shtml
http://www.jtechlaser.com/
http://www.topnotchkits.com/index_files/slide0001.htm (Thanks, Big Johnny!)
Lighting Systems, Night Flying
http://www.rc-cam.com/led_info.htm (DIY Lighting)
http://www.allerc.com/product_info.php?products_id=1596
http://www.rc-lights.com/
http://robotbirds.com/catalog/index.php?cPath=41
http://www.ramrcandramtrack.com/rclights.html
http://www.electrifly.com/miscproducts/gpmm9000.html
Sky Sharkster is offline
Old 01-03-2007, 01:54 AM   #2
gsk11740
I'm outta here!
Cool! Keep them coming!
gsk11740 is offline
Old 01-05-2007, 07:18 PM   #3
WingTips24
Mr. ExperiMENTAL
150mph Speed Demon
Nice set of links I will have to go through these and find the goodies, thanks
Tips
WingTips24 is offline
Old 01-09-2007, 03:53 AM   #4
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Builders Links, M through Z
Here's the rest, may take a few days!
Ron
http://www.smallflyingarts.com/index.html (Online Site, Micro Forum)
http://www.cloud9rc.com/index.asp (Online Site, Micro Forum)
http://www.indoorflyingmodel.com/index.html (Online Site, Micro forum)
http://www.hippocketaeronautics.com/hpa_forum/index.php (Online site, FF, C/l, R/C, Micro Forum)
http://forums.radiocontrolzone.com/a....php/f-61.html (Indoor Flying Links)
http://www.bphobbies.com/view.asp?id...6&pid=D1438410 (DVD by Bob Aberle, Indoor + Micro Models)
http://www.goldenagereproductions.com/home
http://skyhooks.ca/
http://www.falconmodels.uk.com/ (UK)
http://www.indoorflyer.co.uk/index.asp (UK)
http://www.atomicworkshop.co.uk/catalog/index.php UK)
http://www.kenwaymicroflight.com/misc_supplies.htm
http://www.dumasestore.com/catalog/specials.php
http://www.plantraco.com/hobbies/index.html
http://www.toddsmodels.com/
http://www.homefly.com/
http://2dogrc.com/ecommerce/os/catal...26_88_136.html
http://www.samsmodels.com/site/index.html (UK)
http://www.lightflightrc.com/
http://www.airmidimicros.com/
http://www.tailspinaviation.com/index.html
http://pageproducer.acninc.net/dielsengr/index.html
http://www.dpcmodels.homestead.com/
http://www.freeflightmodels.com/
http://www.aalmps.com/ (Plans)
http://www.rockytopmodels.com/
http://www.gravityhobby.com/home.php?cat=263 (Micro Warbirds, foam ARF)
Modeling Organizations and Special Interest Groups
http://www.fai.org/ Federation Aeronautique Internationale (FAI)
http://www.modelaircraft.org/ Academy Of Model Aeronautics (AMA)
http://www.towerhobbies.com/rcwairclubint.html International Clubs and Organizations
http://www.towerhobbies.com/rcwairclub.html U.S. Clubs, Organizations and Special Interest Groups
http://www.ivyandmartin.demon.co.uk/page2.htm (World-Wide Modeling Orgs, Links, Clubs and Vendors)
Motor Mounts
http://www.wattflyer.com/forums/showthread.php?t=39483 (Info, Tips)
http://www.aeromicro.com/Catalog/mot...6_products.htm
http://www.allerc.com/index.php?cPath=55
http://www.atlantahobby.com/shopdisp...t=Motor+Mounts
http://www.hobby-lobby.com/motor-mount.htm
http://www.hobby-lobby.com/motormt.htm
http://www.gobrushless.com/shop/inde...f=MOTOR+MOUNTS
http://www.newcreations-rc.com/Produ...e=I&catlevel=2
http://www.puffinmodels.com/category.php?dept=191 (UK)
http://www3.towerhobbies.com/cgi-bin/wti0093p?&C=GHK
https://www.unitedhobbies.com/UNITED...6&ParentCat=58
Ornithopters, RC
http://www.flyabird.com/rc.html
http://www.ornithopter.org/build.shtml
http://www.ornithopter.org/links.shtml (Links)
http://ovirc.free.fr/ (French Orni Site. Translation Available)
http://www.tailspinaviation.com/html/ornithopters.html Free Flight Orni Kit)
Plans, 3-Views, Scale Details and References
http://airwar.ru/other/drawe.html (3-Views, Warbirds)
http://www.eflight101.com/design/freeplans/ (16 Links to More Links, All Free Plans)
http://www.bellimelgroup.com/products.htm (Northrop + Horten Flying Wings, Plans)
http://www.beuliland.com/ (3-Views)
http://www.bhplans.com/ (Plans)
http://www.clevelandairline.com/default.asp (plans)
http://www.donsmithplans.com/ (Plans)
http://www.freeflightmodels.com/homepage.htm (Plans)
http://www.geocities.com/dmlivesay/a.htm (Reference For 3-Views in U.S. Magazines)
http://www.geocities.com/ivansplans/?200629 (Plans)
http://www.modelairtech.com/ (Plans)
http://www.palmerplans.com/index.html (Plans)
http://www.parkjets.com/free-plans.html (Plans, Free)
http://www.profili2.com/eng/default.htm (3-Views, Plans, Free)
http://www.willingtons.com/mymac/Plans_Download.htm (Free)
http://www.rcstore.com/rs/index.asp (Plans From Model Airplane News)
http://rc.tomhe.net/ (Plans For Depron Pusher Prop Jets, Free. Thanks, Pat!)
http://www.sbslopers.org/index.php?pid=7 (Foam Slope Glider Plans and 3-views, Free)
http://richard.ferriere.free.fr/3vues/3vues.html (3-Views)
http://www.suurland.com/ (Click on "Blueprints", free 3-views. Thanks, Grubbyjeans!)
http://scaleaero.com/jbpstage.htm (Plans)
http://www.simmerspaintshop.com/forums/cat3.html (Markings, Warbirds)
http://www.starcadplans.net/index.ph...=gallery;cat=2 (Free Plans, but site requires registration to download. No charge)
http://www.uknets.co.uk/rcplansguide/plans.htm (Links to More Plans!)
http://www.traplethouse.com/ (Plans)
http://www.turnkeyrc.com/ (Plans)
http://wingermodels.rchomepage.com/ (Plans)
http://wp.scn.ru/en/markings (Scale Markings, Warbirds)
http://www.rcgroups.com/forums/showthread.php?t=359029 (Scale Markings, Insignia, Logos)
http://www.xlistplans.demon.co.uk/ (Plans From Aeromodeller + Scale Aircraft magazines)
Propellers, Fixed
http://www.stefanv.com/rcstuff/qf200203.html (Basics) (X)
http://www.ampaviators.com/index.php...d=66&Itemid=27 (Basics; Thanks, Flydiver!)
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=QBG (Prop Balancers)
http://www.hobby-lobby.com/balancer.htm (Prop Balancer)
http://www.hobby-lobby.com/spinners.htm (Spinners)
http://www.hobby-lobby.com/eflight.htm
http://www.apcprop.com/index.html
http://www.masterairscrew.com/
http://www.bollyprops.com/carbonprops.html
http://www.eastrc.org/estoreprops.htm
http://www.chiefaircraft.com/rcmsec/...XOARProps.html (Large props, glow and electric)
https://www.electricwingman.com/power/propellers.aspx (Fixed + Folding, UK)
http://www.megamotorusa.com/ (Fixed + Folding)
http://www.ductedfans.com/accessories_propellers.html (Fixed + Folding)
http://www.electricprops.com/
http://www.modelflight.com.au/access...propellers.htm (AU)
http://www.e-flightline.com/varioprop.htm (Variable-Pitch)
http://www.motrolflyusa.com/html/accessories.html (Wobbly Adaptors, "O" Rings, Deans Style, Bullet Connectors)
Propellers, Folding
http://www.icare-rc.com/propellers_folding.htm
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=QBE
http://www.e-flight.co.uk/shopdispla...cts.asp?id=215 (UK)
http://www.hobby-lobby.com/camfold.htm
https://www.unitedhobbies.com/UNITED...=1&v=&sortlist= (Folding Props, Spinners, Hubs, Adapters. Hong Kong)
Pylon Racing, Electric (F5D)
http://www.pylonworld.com/rc_electri...tric_pylon.htm
http://www.fortunecity.com/marina/tidal/192/links.htm (Links)
http://www.f5d.co.uk/ (UK)
http://www.espritmodel.com/index.asp...S&Category=556
http://www.soaringusa.com/products/s...ategory_id=265
http://www.matneymodels.com/ (Electric + Glow Pylon ARFs, F/G + Foam)
Radio Control, Transmitters, Receivers, Accessories
http://www.fatlion.com/sailplanes/radios.html (Info) (X)
http://www.rc-airplane-world.com/rc-...ter-modes.html (TX Control Modes, Explained. Also Has Heli Modes)
http://www.dynmodel.com/ (Books on Computer Radios)
http://www.rc-cam.com/ant_exp.htm (Experiments With Shortening + Wrapping Rx Antenna, Thanks, Flydiver!)
http://www.airtronics.net/ATX_aircraft.htm
http://www.hitecrcd.com/
http://www.jrradios.com/
http://www.multiplexusa.com/product_fs.htm
http://www.horizonhobby.com/Stores/P...=R&BrandId=SPM
http://www.castlecreations.com/products/berg.html (Receivers, Castle Creations Berg)
http://www.fmadirect.com/category.htm?id=11 (Receivers, 72Mhz)
http://sombralabs.com/ (Recievers, 72Mhz)
http://www.vampowerpro.com/store/Receivers.htm (Receivers)
http://www.aurorra.co.uk/shop/home.php?cat=271 (Receivers, FMA Direct) UK
http://newcreations-rc.com/ProductLi...e=G&catlevel=2 (Receivers, Alpex, Berg, Castle Creations Berg, Cirrus, Hitec, JR, MPI, Spektrum, Pico)
http://www.modellhaus.co.uk/acatalog/Receivers.html (Receivers, Schulze, Delta, FMA Direct) UK
http://www.xtremepowersystems.net/ (2.4 GHz For All Radios. Thanks, Pat!)
http://www.wattflyer.com/forums/showthread.php?t=1588 (DIY TX Tray)
http://www2.towerhobbies.com/cgi-bin...TXM2015&L=RDAC
http://www.ecubedrc.com/antennas.htm (Micro Rx Antenna)
http://www.smileyantenna.com/product...products_id=86 (Tx "Power Duck" Antenna)
http://www.allerc.com/product_info.php?products_id=1158 (Tx "Rubber Duck" Antenna)
http://www.hobby-lobby.com/antennas.htm (Rx, Tx, Antenna)
http://www.horizonhobby.com/Products...ProdId=RVO1010 (Tx Base-Loaded Whip Antenna)
http://www.gravesrc.com/RVO1010_RVO_..._p/rvo1010.htm (Tx Base-Loaded Whip Antenna)
Retracts (See Landing Gear)
Sailplanes (See Soaring)
Scale Details (See Canopies, Pilot Figures, Scale Details)
Scratch Building, Articles, Links, Books
http://www.ffscale.co.uk/page4.htm
http://www.ffscale.co.uk/comper.htm
http://www.hobbylinc.com/htm/man/man2012.htm (Book)
http://www.antiquemodeler.org/Buildabomber.htm
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZ875 (Books)
http://www.pldaniels.com/flying/inde...?page=articles
http://www.rcscalebuilder.com/Default.asp (Pat Tritles' Scale Builders Page)
Thanks, Mike!
http://www.hippocketaeronautics.com/hpa_forum/index.php (Scratch Builders Forum. C/L, FF, R/C)
Servos
http://www.geocities.com/BourbonStre...rvobasics.html
http://www.fatlion.com/sailplanes/servochart.html (Specs For Most Servos)
http://www.hobbylisting.com/html/ser..._frameset.html (Servo Specs, 2007)
http://progressiverc.com/Servo.html (Servo Specs)
http://www.servocity.com/index.html
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
http://www.servoshop.co.uk/index.php...936de5018f56da (Servos, UK)
http://www.micronradiocontrol.co.uk/servos.html (Servos) UK
http://www.fmadirect.com/category.htm?id=12
http://www.dionysusdesign.com/index.php?cPath=29 (Servo Accessories)
Simulators (Flight Sims)
http://n.ethz.ch/student/mmoeller/fms/index_e.html (Free)
http://www.astro.ku.dk/~norup/vertigo/fly_links.html 20+ Free Sims)
http://www.geocities.com/preflight3d/ (Free)
http://www.rowlhouse.co.uk/sss/index.html (Slope Soaring Sim)
http://www.realflight.com/
http://www.dbproducts.com/
http://www.fabricated-reality.com/
http://rcflightsim.com/
http://www.modelrectifier.com/rc-pro...simulators.asp
http://www.hobby-lobby.com/flightsim.htm
http://www.modelrectifier.com/rc-pro...s-features.asp
http://www.bphobbies.com/view.asp?id...25&pid=W022984
http://www.tti-us.com/sim/products.html (Interface Cables, Adapters)
Soaring Info R/C Gliders
http://www.fai.org/aeromodelling/rcsoaring/
http://www.silentflight.org/ (League Of Silent Flight)
http://rc-soar.com/links/index.htm
http://www.soaringissa.org/ (International Scale Soaring Association)
http://www.slopeflyer.com/
http://home.att.net/~items/DHL/index.htm (DLG Links, Info)
http://www.rcsoaring.com/clubs.shtml
http://www.rc-soar.com/ (UK)
http://www.pssaonline.co.uk/
http://www.sloperacing.com/ (American Slope Racing Organization, F3F)
http://www.apogeerockets.com/educati...g_thermals.asp (Thermal Detection)
http://www.f4bscale.worldonline.co.uk/Thermals.htm (Thermals)
http://www.quicktechhobby.com/articl...20part%201.htm (Thermals, Pt. 1)
http://www.quicktechhobby.com/articl...20part%202.htm (Thermals, Pt. 2)
http://tracfoil.free.fr/airfoils/indexE.html (Airfoils for Sailplanes)
Soaring Supplies (Also See Flying Site Equipment)
http://www.rcsail.com/manufacturers.html (World-Wide Soaring Manufacturers + Distributors, Links. Thanks, Tim!)
http://www.wattflyer.com/forums/showthread.php?t=28303 (High-Performance, Sailplane + E-Glider Links)
http://airplane-model.com/ (Composite F3J, F3B, F5B, HLG, DLG)
http://www.skipmillermodels.com/ (F3B, F3J, Electrics)
http://www.puffinmodels.com/category.php?dept=167 (UK)
http://www.soaringusa.com/cart/cart.php
http://www.espritmodel.com/index.asp...S&Category=549
http://www.fvk.de/Englisch/FVK-Model...h-Version.html
http://nesail.com/index.php?PHPSESSI...2c510521ae2b8e
http://irfmachineworks.com/lbwinch/ (Winch)
http://www.hangar-9.com/Products/Def...?ProdID=HAN200 (Hi-Starts)
http://www.aerofoam.com/hosemonster.html (Bungee, Hi-Starts)
http://www.airstrike.com.au/New%20F3...B%20Models.htm (F3-B, F3-J Sailplanes. Supra, Pike, Ceres, Graphite, many more. Australia) Thanks, Huffy!
http://www.airsportsrc.com.au/accessories.html (Winch, Turnaround. Autralia) Thank, Huffy!
Soldering
http://www.teamnovak.com/tech_info/h...der/index.html (Info)(X)
http://www.rcuniverse.com/magazine/a...article_id=172 (Info)
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=RBF
http://www.willingtons.com/mymac/soldering.htm
http://www.jperkinsdistribution.co.u...&Navmain=Tools UK)
SPAD (Simple Plastic Airplane Design)
http://www.spadtothebone.com/
http://spadworld.net/forum/ (Online Forum)
http://globemaster3c17.tripod.com/id55.html (Links)
Tools, Building, Measuring, Testing Equipment
http://www.micromark.com/
http://www.hobbytool.com/
http://www.hobbylinc.com/index.htm
http://www.a2zhobbies.com/hobby_tools.html
http://www.djhobby.com/cgi-bin/index...alog/mh-tools/
http://www.modeltool.com/kands/kandsindex.html (Aluminum, Brass, Copper Sheets, Tubing)
http://robotbirds.com/catalog/index....39587f032c091f (Tools, UK)
http://helihobby.com/html/hand_tools.html (Allen Wrenches, Ball Link tools, Metric + Standard Hand Tools, All Types)
http://www.faimodelsupply.com/fai-zona.html (Razor Saws, Miter Boxes, Vises, Clamps, Pin Vise, Sanding, Cutting Tools)
http://www.gliders.uk.com/products.asp?dept=25 (Tools, UK)
http://www.masterairscrew.com/GoCart...sp?RootID=1057 (Razor Plane, Balsa Stripper)
http://www.robart.com/Tools.aspx (Incidence, Deflection, Heli Pitch Meters, Model Stand)
http://www.aeroperfect.com/product.html (Digital Incidence + Control Throw Meter)
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=RAS (Incidence, Deflection Meters)
http://www3.towerhobbies.com/cgi-bin...&P=8(Incidence, Deflection Meters, C.G. Balancer, Hinge Slotter, More)
http://www.atlantahobby.com/shopdisp...C+Timing+Tools (Gear Pullers, Timing Tool For Brushed Motors)
http://www.quietrcflying.com/Product...d=HP-ADAP-PU01 (Collet Adapter Puller)
http://brchobbies.co.uk/?page=shop&category=17&start=0 (Chargers, Dischargers, Balancers, Power Analysers, 12V POwer Supply, Tachometers, Scales, Servo Tester, UK)
http://www.jperkinsdistribution.co.u...ctric%20flight (Pinion Puller, UK)
http://www.maxxprod.com/mpi/mpi-29b.html#Pinion (Pinion Puller)
http://www.hobbytool.com/index.asp?P...PROD&ProdID=45 (Helping Hands, Hand Tools, Power Tools)
http://www.rightonscales.com/web/pocketscales/ (Scales)
http://www.oldwillknottscales.com/in...%20And%2049.99 (Scales)
http://www.balances.com/port.html (Scales)
http://www.widgetsupply.com/page/WS/PROD/scalpels/BEU47 (Bulk Stainless Steel Scapel Blades)
http://www3.towerhobbies.com/cgi-bin...&I=LXL448&P=ML (Bulk Single-Edge Razor Blades)
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXDS77 (Bulk # 11 Blades)
http://www.widgetsupply.com/page/WS/...fe-blade-no-11 (Bulk Excel + X-Acto # 11 Blades)
http://www.widgetsupply.com/page/WS/CTGY/knife (Hobby Carving + Shaping Blades)
http://www.tailspinaviation.com/index.html (Blades, Scapel Blades, Pin Clamps, T-Pins, other tools)
UBEC See Battery Eliminator Circuitry
Vacuum Bagging, Vacuum Molding, Info
http://www.favonius.com/soaring/bagging/bagging.htm (X)
http://www.pilotsguide.com/rc/vacbag.shtml
http://www.nextcraft.com/rcdesignandbuilding.html
http://www.geocities.com/reystos/vacuum/
http://www.flyelectric.ukgateway.net/matter.htm#vac
http://www.monkeytumble.com/dlg/bagg...vlar_wings.htm
http://members.aol.com/kmyersefo/vacuum.htm (DIY Vacuum For Canopies)
http://www.build-stuff.com/1001plans_hobby_vac.htm (Hobby-Vac, Plans, Supplies)
Vacuum Bagging, Vacuum Molding, Supplies (Also See Composites)
http://www.acp-composites.com/acp-vbes.htm
http://www.expresscomposites.com/vbag.html
http://www.fibreglast.com/showproduc...roducts-0.html
Videos, DVDs
http://plawner.net/video/videos.html
http://www.radiocarbonart.com/Pages/mainrca.html
http://www.radiocontrolzone.com/plane/video.asp
http://www.flightstore.co.uk/categor...206.dept_l3.0/ (UK)
http://www.rc-airplane-world.com/rc-...ne-videos.html
http://www.rcdon.com/
http://www.hobby-lobby.com/videoclips.htm
Voltage Regulators See Battery Eliminator Circuitry
Voltmeters, Wattmeters, Multimeters
See Tools, Test Equipment
Washout See Aerodynamics
Wheels See Landing Gear
Wiki (E-Flight Wiki)
http://www.eflightwiki.com/eflightwi...itle=Main_Page
Wing Loading See Aerodynamics
Old 01-13-2007, 03:13 AM   #5
Cowboy
Airborne Cowboy
Cowboy's Avatar
Thanks Ron good info.
Cowboy
Cowboy is offline
Old 01-20-2007, 12:12 PM   #6
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Gone Again!
Sorry, Looks like our Gremlin ate the "A" through "L" page, will re-post soon.
Ron
Old 01-25-2007, 03:17 AM   #7
pdxmonkeyboy2002
ttt
pdxmonkeyboy2002 is offline
Old 02-11-2007, 04:13 PM   #8
TheOldGuy
I heard about a covering called So-Lite...anyone know where you can get it?
Charlie
TheOldGuy is offline
Old 02-12-2007, 01:37 AM   #9
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default So Where? So Lite?
Hi Charlie, SoLite is made by Solarfilm, in England. A couple of places that carry it in the U.S. are AllErc http://www.allerc.com/product_info.php?products_id=1085
And RadicalRC http://radicalrc.secure-mall.com/shop/?shop=1&cat=22&
Also, SoLite, MicroLite (sold by Coverite)+ Nelson LiteFilm are basically the same product; In fact AllERC even mentions that Nelson + SoLite are the same and whichever brand is in stock, will be shipped.
If you haven't used one of the "Micros" yet, follow the temperature directions carefully; This stuff melts easily! It has a good adhesive, shrinks well (again, watch the heat!) and looks great. Not as puncture-resistant as the heavier films, if you fly on an "unimproved" field, you'll be doing some patching.
Good Luck!
Ron
Old 02-12-2007, 01:19 PM   #10
TheOldGuy
Well, thanks a lot Ron for the info. I just started electrics a couple months ago and have been in fuel/gas planes for many years, so this is very helpful and I'll be careful with the heat as you suggested.
Charlie
Old 03-03-2007, 08:36 PM   #11
N3CLI
Retired Pharmacist
N3CLI's Avatar
Ron
Where do you find the time time to do all of this research???
We all thank you !
Fred
Fred AMA 68196
Amateur Radio N3CLI
Palm Beach Radio Control Association member
The largest AMA club membership in the USA
N3CLI is offline
Old 03-04-2007, 03:41 PM   #12
TheOldGuy
Thanks Ron for the info and I did get some Solite, but haven't reached the covering stage of my Mini-Telemaster kit. So far, it's been going together like a dream!! American made sure makes a difference in the quality.
Old 03-05-2007, 09:15 PM   #13
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (17)
Ron,,
Thanks for the effort! I PM'd you some more (which you've gotten already). I'll send more as I come across them.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Old 03-24-2007, 04:42 AM   #14
deltamik
Hey Sky Shark -
I'm new to this forum and EF.
I've been roaming in the wilderness of the ether desert for weeks; magically, you appear like an oasis with your catalog of helpful sites. I'm drinking it all in. You have offered a prodigious compilation -THANKS!!
Don
"...tempus fugit..." ("Time Flys")
deltamik is offline
Old 02-05-2008, 05:08 PM   #15
grubbyjeans
grubbyjeans's Avatar
Thumbs up Looking for 3-views?
Check this. Click on 'Blueprints'
grubbyjeans is offline
Old 02-05-2008, 08:42 PM   #16
crxmanpat's Avatar
Friends: (17)
Dude! Awesome resource! Thanks for posting that link.
Pat Gagnon
Old 02-06-2008, 01:22 AM   #17
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Great Link!
Thanks, Grubbyjeans, I added it to the list.
Ron
Old 06-30-2008, 06:20 PM   #18
creyes123
R/C Advisor
creyes123's Avatar
Club: Albuquerque Soaring Association
Talking RCadvisor.com - free advanced model airplane calculator
You don't seem to have a link to my calculator.
Carlos
RCadvisor.com
creyes123 is offline
Old 06-30-2008, 07:55 PM   #19
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Another Good Link!
Thanks, Carlos,
I added your site to "Aerodynamics, Airfoils, Model Design"
Ron
Old 06-30-2008, 11:00 PM   #20
crxmanpat's Avatar
Friends: (17)
Ron,
Please add rc.tomhe.net (no "www"). Link to free plans for depron pusher jets. Site is owned by the designer. I guess it would fall under "Plans, 3-views".
Pat
Pat Gagnon
Old 07-01-2008, 03:01 AM   #21
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Good New Link!
Hi Pat,
Thank you for the link, that's a good one! I added it to the list.
Ron
Old 08-16-2008, 05:10 PM   #22
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Club: www.rmvc-cumulus.nl , Nijmegen, Netherlands
Compilation of calculators:
Compilation of motor test stands/rigs:
http://www.rcgroups.com/forums/showthread.php?t=386175
Vriendelijke groeten Ron van Sommeren
motor building tips & tricks
diy brushless motor discussion group
Drive Calculator download & discussion group
int. electric fly-in, Nijmegen, the Netherlands
ron_van_sommeren is offline
Old 08-16-2008, 05:12 PM   #23
ron_van_sommeren
DIY brushless motors
Introduction (I would give this one the 'X')
www.southernsoaringclub.org.za
-> Articles from Southeasters
-> Electric Motors - part 1 ... part 5
Tips, tricks and savers:
'Bibles':
Powercroco, Googletranslation
Old 08-16-2008, 05:36 PM   #24
ron_van_sommeren
E-flight FAQ's (would be my first chapter in the list)
www.ezonemag.com
-> faq
Everything You Wanted To Know About Electric Powered Flight
Old 08-16-2008, 05:42 PM   #25
ron_van_sommeren
Outrunner database, over 1200 types, in French but the numbers speak for themselves:
http://electrofly.free.fr/file/BLDC-Outrunners.zip
Outrunner manufacturers, diy kits/parts/magnets/stators too:
http://www.rclineforum.de/forum/thre...did=43664&sid=
Tags
builders links
"Builders" Links, Downloads, Tips Sky Sharkster Scratch and Kit Built Aircraft 11 07-15-2010 04:42 PM
WARBIRD "LINKS" Updated! Sky Sharkster Warbird Electrics 29 12-02-2009 10:21 PM
PLANS! "Aeromodeller" "Keil Kraft" "Mercury", More Sky Sharkster Vintage and old timer models 4 05-10-2008 01:14 AM
"Builder Links" Done and Re-Done! Sky Sharkster General Electric Discussions 0 03-05-2007 01:26 PM
WTT "NIB" AXI 2212/34 FOR A "NIP" CC35 or JETI 30 ADVANCE PLUS OR? papamac Motors and Speed Controllers for sale & WTB 0 10-02-2005 06:27 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 1.00591 seconds with 67 queries
