Old 02-09-2007, 02:03 AM   #1
radioflyer75
radioflyer75's Avatar
Default What is Aileron, Elevator, Rudder, & Throttle Mixing?
Got any good links that will explain this? I've got a radio for a Stryker that has all of this and I have no clue what it is. Is mixing the same as reversing? Got that too.
radioflyer75 is offline
Old 02-09-2007, 12:07 PM   #2
Sky Sharkster
Sky Sharkster's Avatar
View Sky Sharkster's Gallery11
Globetrotter Pilot
Friends: (20)
Default Mixed Up?
Hello Radioflyer, here's a good link with explanations of the various mixes and reversing, expo, dual rates, etc;
http://www.blackflight.com/intro_rc/intro_rc_radio.asp
For your "Stryker", the control surfaces have a dual-control function. Each wing panel has only one surface (called an "Elevon") but must perform two functions; Pitch (up-and-down control) and Roll (turning the model right/left by banking). So one servo is plugged into "Elevator" and the other into "Aileron" on the receiver. Then the transmitter elevon-mixing function is programmed to combine these.
When you apply "Up" elevator command, both elevons go "Up". If you apply "Left" turn command, the left elevon goes up, the right elevon goes down. For a right turn, the left elevon should go down, the right one up. For "Down" elevator, both elevons move down.
These are not isolated or separate; A bit of "right" and "Up" (together) will result in a mix of the two controls on the aircraft surface. Both will go up, but the right elevon will go up more.
Hope this helps!
Ron
Sky Sharkster is offline
Old 02-09-2007, 02:02 PM   #3
Friends: (9)
If you have the RTF radio for the Stryker or StrykerB on 27 MHz, you have very little avalable to you.
This might be helpful:
For beginners - Computer Radios and Surface Mixes
http://www.rcgroups.com/forums/showthread.php?t=157053
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 02-09-2007, 02:14 PM   #4
radioflyer75
Ok....after reading that link...now my head is really spinning!
Old 02-09-2007, 06:17 PM   #5
Friends: (9)
Spinning?
Try a little left rudder to over come the spin. If that makes it worse, then try right rudder.
Ha Ha!
www.lisf.org
www.flyesl.org
AEAJR is offline
Old 02-10-2007, 12:50 AM   #6
radioflyer75
Ok, another question. What happens if I just move the right elevon up while the left one stays stationary? Just a not-so-steep bank? So technically there is no rudder on the stryker, because the plane has to bank to turn?
Old 02-10-2007, 02:13 AM   #7
Friends: (9)
There is no rudder on the stryker, right.
All planes bank to turn.
www.lisf.org
www.flyesl.org
AEAJR is offline
Old 02-10-2007, 02:14 AM   #8
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Turning One Way?
Hello RadioFlyer, the answer to your first question is the same as the answer to this one;
If I drove my car and wanted to turn, could I just use one front wheel to turn?
Yes, but it's a bad idea. Cars have two front wheels and the Stryker has two wing panels with control surfaces on each one. Moving just one elevon (as an aileron) to turn makes that surface work twice as hard and results in an asymmetrical (offcenter) control moment. The plane will pitch towards the turn side, tuck the nose down and "barrel" roll. Not good. To get a smooth, stable turn (or complete roll) both elevons are needed. Balanced lift, balanced control movement.
2nd question; Yes. There is no rudder on the Stryker. You bank the plane sideways and apply a bit of "up" elevator to turn. When the plane is sideways, the "elevators" (elevator function of the elevons) becomes the rudder. After a few flights it will be as natural as steering a car. With both wheels!
Just kidding!
Ron
aileron mixing joebob Beginners 10 09-02-2008 10:42 AM
HB CP2 mixing elevator and throttle Help! Esparrago Beginners - Helis 11 08-06-2007 01:57 PM
New Rudder & Elevator for SkyFly Sierrazulu85 General Electric Discussions 9 10-20-2006 04:14 PM
Mixing Throttle & Ailerons? donjiskra General Electric Discussions 9 08-06-2006 04:15 AM
Best Way to Remove Rudder & Elevator From SS Armound Beginners 2 11-25-2005 08:51 PM
Page generated in 0.09684 seconds with 33 queries
