| ParkFlyers Talk about all backyard and parkflyer aircraft here |
#1 | ||
r/c crash test "DUMMY"
Club: http://www.facebook.com/home.php?#/group.php?gid=221090112030
RCSmoke.com (A Member of the Regin HVAC Family) |
#2 | ||
How did these work for you? I am looking for some way to add smoke to my park flyer planes.
Without a muffler for heat, the smoke liquid is out of the question. Or is it? All input is highly appreciated. |
#3 | ||
Australia in the US
hobbylobby has some too, i think you just light them and away they go....
#4 | ||
I got several colors of the HL smokers. Put it on the bottom of a Lil Rascal (hanging down and aft) and burned a hole in the Monokote and scorched the balsa a bit. Easily fixed but disturbing at the time! The Purple is awesome! Dense, colorful and shows up whether blue or grey sky!
#5 | ||
i tried them last week i did not use a fuse just tried to light them did not work will try again using the fuse will post results when able so far expensive for what you get i think
#6 | ||
this photo was taken last wednesday night like i said before not sure i will buy again they tend to flame up i damaged my covering on this flight but they do look cool if you can come up with a better way to mount them that is my report
#7 | ||
here it is
#8 | ||
ELECTRIC > GAS
Hobby-Lobby sells smoke bombs that you can slap on your plane, all I remember is that they are $$$$............
#9 | ||
Stuff2disc
Club: bendigo, Bachas Marsh
Hi I am working on an electric smoke system that will give similar results to a conventional gas/ic smoke system. I have tested a system that will run off a 2s 1800 mAh lipo it did give off a great smoke stream using normal smoke oil. I need to develop the unit into a convenient size package that will be suitable for mid to large size electric models. Stay tuned I will have this system up and running within the next few months.
#10 | ||
Don't forget an automatic voltage cutoff...
#11 | ||
keep us posted!!!!!!!!!
#12 | ||
Friends: (281)
Originally Posted by Barry Townsend
good luck to you
I have tried to make a e powered smoke system with very little luck, a ballist resistor surounded with fiberglass insulation soaked with ATF, it worked but did not put out a lot of smoke, and it could catch fire Keep us informed. Chellie
#13 | ||
Friends: (8)
I used the RCsmoke system for the last 12 months and they work great. I have a remote ignition system set off on the retracts channel to simulate being hit by flak
Can't say too much more, as I am on my lunch break, but I'll get back to you in the next day or so
#14 | ||
Stuff2disc
#15 | ||
Stuff2disc
Check it out, no pump, needle valve, pressure feed or shut off valve required it draws the required amount of fuel through 2 burners. I have just set up using 3 burners it does give more smoke but does run a bit hotter runs of 11.1 lipo from 1000mAh up.
Demo is the 2 burner using an 11.1v 2200mAh will run continuously until the battery loses power or the fuel runs out, I did run this unit for at least 15 mins the case only got warm and there were no issues. Will be operated using a mini servo on a micro switch to turn on and off. http://www.facebook.com/photo.php?v=...type=3&theater |
#16 | ||
Do you think when on a plane it will need a fan? A smoother airflow will leave a denser (but thinner) column of smoke. Maybe a venturi sticking out the side of the fuse. |
#17 | ||
Stuff2disc
The first tests were with no fan and the unit did catch on fire? (ground run) the issue is the heat with no air flow. I will set it up on a model and try both as I am aware of natural air flow and obviously...you would not run it on the ground but you know what people are like?
Thanks for your input I am open to any suggestions. Cheers Barry |
#18 | ||
A good test of drawing the air into a tube or venturi might be to place the unit at the front end of a clear plastic pipe, and the fan down at the other end.
Temperature regulation might be necessary, maybe only a simple temp snap-switch like they use to protect electric heaters would do it. Like these, many appliances use the ones that are about the size of a thumbnail.
| Choosing an electric power system for your model | Chris F | Beginners | 84 | 03-18-2013 05:28 PM |
| Giant Scale Electric Power System | rcjake | Motors and Speed Controllers for sale & WTB | 8 | 06-06-2007 12:17 AM |
| smoke system??? | dmmalish | ParkFlyers | 8 | 12-19-2006 09:05 PM |
| Electric power system questions for a large PBY-5a | RSS Feed | RCU RSS Feed | 0 | 10-03-2006 10:10 AM |
| For Sale - Electric Power System | simibill | Motors and Speed Controllers for sale & WTB | 0 | 09-18-2005 05:10 PM |
