Old 06-01-2007, 03:14 PM   #1
Reformed Nitroaddict
Reformed Nitroaddict's Avatar
Send a message via AIM to Reformed Nitroaddict
Default Castle Creations Berg Receiver Issue - Help!
Purchased a CC rcvr for a new electric 3D plane, and it is supposed to copy any FM TX. I am using a 6channel JR system. When hooked up to the plane, I was only able to control channel 3. Power was going to channel 1, the ESC, but it would not program and I had no throttle.
Removed it and tried it another plane. In this plane, channel 1 works fine for throttle, and 3 works as well. But still have no power coming from 2 or 4.
Any ideas? I was going to return it today, but that means I will have to wait for the LHS to order a crystal for a JR transmitter and I want to fly this weekend.
Any help would be greatly appreciated!
"My piloting skills are proof that gravity does exist."
Reformed Nitroaddict is offline
Old 06-01-2007, 03:46 PM   #2
Rodneh
Remember that the channel order on the transmitter controls which slot to plug in the esc. On a Futaba or Hitec, it plugs into channel 3, on a JR it is a different channel for the throttle.
Rodneh is offline
Old 06-01-2007, 04:05 PM   #3
This is interesting, so even though I have a JR Radio, the CC rcvr might be different?
I'm not sure on this though. As when hooked up to my plane, the throttle does work like normal when plugged into ch1, and whatever I have plugged into ch3 works normally as well. But both ch2 and ch4 are dead.
Old 06-01-2007, 04:37 PM   #4
skiman762
FFFC
skiman762's Avatar
If your using the 4L remember the channel 2 and 4 the servo plugs in opposite of 1 and 3 all the black wires go to the outside on all channels
''To those who defend it freedom has a ring the protected can not hear''
Thank You Uncle Henry 4-April-1945
skiman762 is offline
Old 06-01-2007, 05:59 PM   #5
Hmm - this might be the problem. So ch1 and ch3 go in the opposite direction of 2 and 4?
That would explain my problem of no output on those channels.
I will give that a try.
Old 06-01-2007, 09:18 PM   #6
Well, I figured out one problem only to discover another.
After installing channels 2 and 4 in the opposite direction of 1 and 3, all channels are now working on my hydrofoam and formosa.
But, now - when I hook up the battery on the Typhoon 3D, the ESC beeps only twice, saying that it is only reading 2cells, instead of the 3S pack I am using. Also, no controls work at all, including throttle.
Help!
Old 06-01-2007, 09:57 PM   #7
Rabbitcreekok
Rabbitcreekok's Avatar
View Rabbitcreekok's Gallery8
Friends: (30)
If the battery is not fully charged, it will read the voltage as a highly charged 2 cell rather than a low charged 3 cell. At least some of them work that way.
Jim
AMA 735658
Rabbitcreekok is offline
Old 06-02-2007, 12:52 AM   #8
Well - I think I have also figured out this other problem.
The Radio I am using is a JR XP652. I think that the programming is off, because I tried my backup TX, which is an XF421 and now everything works.
The problem now, is the reason the XF421 is decomissioned is because the servo reversing feature quick working. So, all the servos are out of wack.
I need to figure out the programming problem with the XP652 and I should be set. If no luck, worst case senerio is that I have to switch the servo horns to the other side of the control surfaces.
Old 06-03-2007, 04:19 AM   #9
Well - I finally figured out the problem I was having. My computer radio programming was all off and was mixing things that should not have been mixed. I switched to a new program and finally got everything set up.
First maiden on the Typhoon tomorrow morning pending it isnt raining!
I cannot wait! I moved recently and have had all the planes packed up for over a year! This will be the first flight with a true 3D plane. Previously, the only serious aerobatic planes I had were a Stearman PT-17 and a GWS brushless Formosa.
Wish me luck!
Castle Creations berg 7p anyone? xuzme720 RC Radios, Transmitters, Receivers, Servos, gyros 11 08-18-2007 12:10 AM
Castle Creations Berg 7P horizontal pin receivers are now available!!! Joe Ford New Product Announcements 0 01-28-2007 12:44 AM
Castle Creations now at WattFlyer Rugar General Electric Discussions 0 11-19-2006 01:24 PM
What's up with Castle Creations' new Berg 7 debut? Steve G General Electric Discussions 2 06-19-2006 04:11 PM
Page generated in 0.48973 seconds with 35 queries
