Old 06-02-2007, 01:01 AM   #1
pd1
Still Learning
pd1's Avatar
View pd1's Gallery67
Club: Cape Ann RC Model Club
Friends: (47)
Default And now for something mostly different.
I used to fly glow planes, I used to fly a lot.
After a year or two the balsa got oil soaked and the plane was scrapped.
But just prior to scrapping, some good ones got a slight reprieve.
I used them for equipment checks.
A lot of times , after drilling a hole in the ground, I needed the equipment checked to make sure there were no new problems.
So the old soaker's got used for this, and they did their job well.
Electric is so clean, I don't get the worn out junkers anymore.
What to do?
Last winter I built a plane specifically for this, but it came out too nice.
Couldn't bring myself to using it as a test plane.
So now I wanted something with no time invested and very little money wasted.
So here it is a plane that cost about $5 and took two hours from start to first flight.
It's one of them styro chuck gliders.
I added a 1/8 sheet tail, 1/8 ailerons, Popsicle sticks for servo mounts and part of an orange crate for a lite ply firewall.
That's it, and it flew great. Just gotta stop the wings from flexing so much.
pd1 is online now
Old 06-02-2007, 02:00 PM   #2
pd1
Still Learning
pd1's Avatar
Friends: (47)
Since last night I've covered the wing with some 4 inch wide clear packing tape.
It stiffens the wing a lot.
By the way, this thing would probably make a good aileron trainer.
I'll probably test it this afternoon.
pd1 is online now
Old 06-02-2007, 02:52 PM   #3
CitaFly
Looking forward to a flight report - I saw this at a lhs and almost bought it, but I'm "planed up" - could change my mine though - great price.
My site for electric flying articles:
http://www.ampaviators.com
CitaFly is offline
Old 06-02-2007, 06:44 PM   #4
BcBasher
BcBasher's Avatar
I used that same chuck glider for my first and second atempt at RC flight. I used fiberglass filament tape to reinforce the wing. I thought the tail moment to short so I built a balsa fuselage. This pic is S*** Hawk 1 it lasted all of 6 flights till I bounced it off the inside of a discus cage. It actualy flew pretty good. I was the weak link, I'd like to build something sporty using the foam cores from one.
BcBasher is offline
Old 06-02-2007, 07:08 PM   #5
pd1
Still Learning
pd1's Avatar
Friends: (47)
Flew it again, It flys much better with the tape on the wing.
Funny thing, I can show up with a scratch built scale or pattern plane and nobody takes notice of me.
I pulled this out, and everybody had to get a close look.
Go figure.
pd1 is online now
Old 06-03-2007, 11:44 PM   #6
pd1
Still Learning
pd1's Avatar
Friends: (47)
If anyone is interested in making one of these them self, I can post the changes and mods.
This thing has practically no adverse yaw, it really would make a good aileron trainer.
pd1 is online now
Old 06-04-2007, 02:52 AM   #7
USAPatriot
Yeehadi
USAPatriot's Avatar
View USAPatriot's Gallery5
I kinda like it, PD -Rod-
USAPatriot is offline
Old 06-04-2007, 05:25 AM   #8
Bill G
Bill G's Avatar
View Bill G's Gallery65
Club: soda
Were you a Monty Python fan?
Actually, it was "completely", but close enough.
I like the plane. No hassles routing the elevator pushrod, eh?
Go figure.
Exactly! That's why I'm gonna show up at the field with this:
Bill G is offline
Old 06-04-2007, 10:57 AM   #9
pd1
Still Learning
pd1's Avatar
Friends: (47)
Hi Bill, you like my elevator push rod?
As I said I didn't want any time or money invested in something that was going to crash anyway.
No, I'm not being negative, my point is to use this to check suspect radios.
Sooner or later the suspect radio will be bad.
By the way I do like British comedy,I think it is far better than the stuff Hollywood puts out.
If you want something with good writing try the British version of, "Coupling, Chef, or Black Adder".
I think you're right, a simple,cheap, ugly airplane has a quality all it's own.
pd1 is online now
Old 06-04-2007, 01:38 PM   #10
CitaFly
I'd like to see this - thanks!
CitaFly is offline
Old 06-04-2007, 04:23 PM   #11
pd1
Still Learning
pd1's Avatar
Friends: (47)
Here's a quick build explanation so you can duplicate this plane.
1. Cut nose off fuselage at 5 1/4 inches, measured from forward edge of wing cut out. See picture 1.
Trace nose on Lite ply, 1/8 approximate. I used ply from orange crate.
Glue ply to fuse,I used Gorilla glue, Titebond or epoxy will also work.
2 Wings. Sand leading edge to round shape, my glider came through with a flat leading edge.
Cover wing with packing tape. I used wide clear tape.
Cut servo openings, glue popsicle sticks to wing for servo mounts.
see picture.
3. Glue wing to fuselage, I used GWS glue, but Gorilla glue or epoxy will also work.
4. Place yardstick along bottom side of wing, mark line at rear of fuselage. See pictures.
Mark up from line 3/8 and 1/2 inch and draw parallel lines. This is for stab opening. Cut open, I used a band saw, but a hacksaw or knife should also work. See pictures.
5. Cut stab from sheet of 1/8 thick balsa.
Mine is 19 3/4 long, that's the piece I had laying around, a little shorter should be OK.
See drawing.
I cut leading edge back to give leading edge a sweep. I took the pieces I cut off and turned them around and re glued them back on the leading edge.
6. Glue stab to fuselage, I used epoxy.
Elevator is 1 inch wide 1/8 thick balsa. hinged at 4 places.
I used GWS hinges, with GWS glue. CA hinges will also work.
7. Ailerons, 1 inch wide by 24 1/4 long 1/8 balsa. That was the size piece I had. a little shorter would still work. see pictures.
8. Hinge ailerons, I used 3 hinges per side, GWS hinges with GWS glue.
CG, the balance point is at 2 inches back from the leading edge at the side of the fuselage.
pd1 is online now
Old 06-04-2007, 04:55 PM   #12
alienx
alienx's Avatar
View alienx's Gallery38
Club: Edison Park Flying Field
Friends: (4)
That's awesome!! And it's huge ...says so right on the package!
Pretty sure I'm going to have to try this!
alienx is offline
Old 06-04-2007, 05:43 PM   #13
pd1
Still Learning
pd1's Avatar
Friends: (47)
Andy, make one and we can do slow speed combat.
pd1 is online now
Old 06-04-2007, 05:52 PM   #14
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
Club: Joplin RC Club
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (49)
That's pretty cool Paul. Maybe I missed it, but what motor and battery did you use?
Tom
AMA #877639
Grasshopper is offline
Old 06-04-2007, 06:01 PM   #15
pd1
Still Learning
pd1's Avatar
Friends: (47)
Tom, the motor is an E-Max CF 2212, $15.00 the battery is a 900 MAH 3 cell$22.00, both from Blackdogrc.
Plane fly's over 15 minutes at half power,
and with a little wind it thermaled.
pd1 is online now
Old 06-04-2007, 06:08 PM   #16
Yaniel
Yaniel's Avatar
View Yaniel's Gallery8
Club: Mako's RC Jet Club
Send a message via AIM to Yaniel
very tempted to build this... time to hit up the toy stores for the glider
Yaniel is offline
Old 06-04-2007, 06:11 PM   #17
pd1
Still Learning
pd1's Avatar
Friends: (47)
Maybe we should have a contest to see who can build one the fastest.
It took me all of two hours start to finish, and I wasn't trying to go fast.
pd1 is online now
Old 06-04-2007, 08:30 PM   #18
Yaniel
Yaniel's Avatar
i'd definately be in last place or end up with a paper weight
Yaniel is offline
Old 06-05-2007, 02:33 AM   #19
alienx
alienx's Avatar
Friends: (4)
Haha, I see two planes following each other at exact opposites sides of a big wide circle and moving slooowly!!
Where do you get one of these babies??
alienx is offline
Old 06-05-2007, 02:40 AM   #20
Balil
foam murderer :D
Balil's Avatar
anyone thought of putting wing spars in the wings?! that would solve the problem of the wing flex... im deffinatly gonna give this one a try
what goes up, must come down! *looks around* sometimes they come down harder than we intend
Balil is offline
Old 06-05-2007, 01:48 PM   #21
pd1
Still Learning
pd1's Avatar
Friends: (47)
Andy , my wife picked it up at "Big Lots", it's a chain of stores with low priced stuff. Cost was $5.00.
That would be funny, two planes circling and not being able to close on the other.
In actual fact, with full power it climbs quite steeply.
I haven't gone fast in level flight because I was having so much fun I didn't think about trying to go fast.
Balil, with the tape on the wings the wing flex is gone.
I don't think it needs spars.
At least for the flying I do it won't.
I'll save the aerobatics for the other planes.
pd1 is online now
Old 06-05-2007, 03:32 PM   #22
alienx
alienx's Avatar
Friends: (4)
Oooh ...I have a big lots out on the highway! To be perfectly honest, I've wanted to try covering a foamie, and Tom has given me some cool cloth to test too, so maybe this plane will be it! And you have to love the viturally unlimited CG adjustability (not to mention the fact that everything flush mounts on the outside!). How can you go wrong here!?
alienx is offline
Old 06-05-2007, 03:41 PM   #23
Grasshopper
Friends: (49)
Thanks Paul! Now you've made me go look for another plane. We have a Big Lots about 5 minutes from home. I have a spare 2908-10 and a 3S 2100 pack. Think that would pull it?
Tom
AMA #877639
Old 06-05-2007, 05:31 PM   #24
pd1
Still Learning
pd1's Avatar
Friends: (47)
Tom, that motor would pull it just fine.
pd1 is online now
Old 06-06-2007, 03:03 AM   #25
Balil
foam murderer :D
Balil's Avatar
pd1 you think a himax 2812-1080 with a 3s 2200mah pack with a 10x8 pack would pull it?
Balil is offline
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.92302 seconds with 86 queries
