| Batteries & Chargers Discuss Li-P, Li-Ion, NiMh, Nicad battery technology and the chargers that juice 'em up! |
#1 | ||
Prajurit
Base on Lipo Charger designed by Scott Henion
http://shdesigns.dyndns.org/lionchg.html I have made 3 charger combined in single PCB, each charger has output voltage 4.2V. Cascade them to become Charger fit for 2 or 3 cels Lipo pack. They have worked well. The transformed that used here has 3 x 8VAC secondary output. |
Now Everyone can Fly..
#2 | ||
c'mere Monkey
Location: Just North of Houston.Heard of Humble? I didn't think so...
Friends: (7)
that's awesome! I bookmarked that link for my next rainy day I have free...if I ever get a free day, rainy or not! lol
Don't be a victim of Heli Envy! learn how to Fly Great...or Get a bigger heli...(guess I need a full scale) Just call me X! (or Gary works, too.) proud member of the Monkey Whuppin Squad! ![]() don't chide me for being off topic, that's just how I roll! ![]() |
#3 | ||
Prajurit
The homebrew charger on duty
![]() Charging 2S Lipo (8.4V), Two LEDs are ON Charging 3S Lipo (12.6V), Three LEDs are ON |
#4 | ||
does each charger charge one cell of the 3S lipo?
How much does it cost to build the whole thing? Individual components are rather cheap but once its all ordered and purchased the total may be higher and smehting like a cellpro charger cheaper ... Still its nice to build your own stuff ![]() By the way ... NS makes a Lipo charger IC that can also be used for self made chargers .. i thought about it once but decided its not worth it... Matt |
#5 | ||
Prajurit
Hi Trex,
Yup, each cell of Lipo was charged by one dedicated charger, look at the picture there are 3 chargers. Each of them has charging voltage 4.2V. The cost are arround US$7 or US$8, maybe different depend on the country. For example the LM317 is only 20 cents here (Indonesia). In my case, several parts are recycling from dead electronics equipment, it's make them become cheaper. Sometime, DIY equipment is'nt worthed compare to ready build one from factory. But self satisfaction is invaluable, isn't it? |
#6 | ||
#7 | ||
Friends: (215)
Hi, Thats a neet looking charger, it seems to charge each cell individually, but it does not look to balance charge the cells, I could be wrong, or maybe you dont need to balance charge each cell by charging them seperate, Hmmmmm very interesting, take care, Chellie
#8 | ||
Prajurit
@Matt,
Pls share me the cheap BEC @Chellie You are right, this charger doesn't balance each cell. In my mind, due to each cell was charged individually, when they fully charged also become balance . |
#9 | ||
Friends: (215)
Yes that make sence Ajoe, Take care, Chellie
#10 | ||
^_^
Friends: (4)
Great idea using three and the "low" voltage transformer. I've been using the DIY charger for a couple months after my bought charger died. I had the parts on hand from an abandoned project. In 3s it takes 17v which I can't feed with enough amps to pull off more than a 650mAh initial charge.
Used a .68Ω resistor that should be charging over 1amp. How did you change the AC to DC? What rate is the batteries charging? |
"If you stand behind me... You gonna get kicked."
#11 | ||
The best source for ALL needs of RC is a ATX power supply.... Every cheap one will give you 12V / 10A or more.
I am just blinging mine out with Dual Selectable voltage from 1.5 - 12 V and build in volt and ammeter. Matt |
#12 | ||
Originally Posted by Ajoe
@Chellie:
By charging each cel with its own charger you dont need a balancer .. thats in general how the Cellpro 4S works...Here is my BEC It is built on a National Semiconductor LM350 ADJ. You can set any (as long as its below the input) output voltage by varying the drain resistor. You can download the datasheet for the LM350 which shows the schematics for the voltage regulator setup. If you need any help or details let me know! You dont need the capacitors but I added 1000uF on the output to make sure there arent any power surges ![]() You do need a little heatsink. If you dont need 3A you can also use a LM7805 (1 AMP) which can be found on soundcards, older PC power supplies and older mainboards. In general you can recycle a plethora of parts from old PC!! My heatsink and 1000uF cap came from a mainboard ![]() Here is a pic for size comparison. You need to assure adequate cooling under the load the are pulling from it to make sure it doesnt burn up. I am also working on a SWITCHING 3A BEC that will be much more efficient but its harder to build. ![]() http://img245.imageshack.us/img245/1725/becsn6.jpg |
#13 | ||
Prajurit
Originally Posted by fr4nk1yn
Just using simple bridge rectifier and Cap 4700 uF, My charger is capable to feeding up to 600 mA.
#14 | ||
Friends: (215)
That is really neet, that some smart people can use a old comp. and make a motor from the cd drive/hard drive to power their planes with and other old pc. parts can be used for chargers and BEC, thats really clever, i wish i had learned a little more electronics, I just know the basics, and it seem very interesting, my son and i did make a simple square wave oscillator , using a 555 chip, and made a custom amp regulator for a hydrogen generator for autos, using 3 NPN 2N3055 15 amp transistors, and regulated each one to only allow 5 amps to pass through it, and connected them up so we only got 15 amps total @ 14.1 volts we were trying to use each transistor at only 1/3 of there output to keep things cool, reason we had to do this, is because the amperage/draw of the hyd. gen. was regulated by the amount of electrolite in the gen, and it was temp. sensitive, and would vary with temp and the electrolite getting weak, so now we can use a lot more electrolite, and the amp draw will always stay the same, one problem solved, BTW this hydrogen generator works great, it uses lead plates, and will double the fuel mileage on most cars @ cruise speeds, we have been working on this project for a few years, it uses distilled water, breaks it into hydrogen and oxygen and is drawn into the eng. with vacume, and has a auto fill water system, and makes hydrogen on demand, we will be selling the plans soon, it can be made with material bought at like home depot and radio shack, take care, Chellie
#15 | ||
Do I understand this correctly that you use power from the vehicles 12V on board power system to break water into hydrogen (and oxygen) and you feed this into the engine?
Interesting idea but wouldnt it consume more energy to make hydrogen as you gain by burning it? Matt |
#16 | ||
Friends: (215)
Originally Posted by Trex
Hi Trex
No it produces more energy, with a cars 12v+ ,although the hydrogen generator is not overunity in its self, there are a lot of things going on here, first you have the added hyd fuel, second the hyd. fuel catalyzes the gasoline and makes it burn 25% more efficient, third you have pure oxygen that makes everything burn better, and the fuel is produced in a vaccume, more volume than if made not in a vaccume, lots of things going on, so your not really getting more energy from just the hydrogen fuel being produced, but from all the other positive events that are taking place with the hyd. fuel and oxygen, its been called brown's gas, Rhode's gas and a few other things, when oxy & hyd gas/vapors are mixed together, the hydrogen that is made, produced these gas savings at cruise speeds only, here is why, it takes only about 8 to 10 hp to maintain your cruise speeds, the hyd produced will make 4 to 5 hp, the gasoline makes up the other 4 to 5 hp, so half of your fuel to maintain cruise speed is made with hyd. for up to a 50% gasoline fuel savings, take care, ChelliePs I listed one hyd generator, but mine is much better ![]() http://www.eagle-research.com/fuelsav/hyztechld.html |
#17 | ||
Retired Pharmacist
Chellie
How is yours better? Is it available as a kit? Fred |
Fred AMA 68196
Amateur Radio N3CLI Palm Beach Radio Control Association member The largest AMA club membership in the USA |
#18 | ||
Friends: (215)
Hi Fred
Its bigger with bigger plates in it, so it makes more gas, it workes under vacume, and has a float switch, hooked to a solenoid valve that draws water into the generator Via vacume to refill the generator as the water is depleated, then turns off, and is a simple design, no electronics to it really other than a amp regulator, at this time we are working with carbon fiber plates, so we can take the lead out of the generator, we will be selling the plans to it, and later maybe the kits, with the carbon fiber plates, still need to do some R&D with the carbon fiber plates, so should know soon if the CF plates will work as well as the lead, we have tried stainless steel, copper, and other metals, and lead so far workes the best, hoping that CF will work as well or better, take care, Chellie
| For Sale ParkZone 3S 1800mah lipo and Parkzone Lipo Charger Price Reduced | BoysToys | Batteries and Chargers Forsale/WTB | 2 | 01-05-2010 12:05 AM |
| My first homemade pack - a123 | kalel | Batteries & Chargers | 8 | 12-29-2007 02:22 AM |
| homemade rudder hinge? | hookedonflyin | General Electric Discussions | 13 | 02-02-2007 05:16 PM |
| homemade balancer | Bulldog | Beginners | 2 | 01-18-2007 07:55 AM |
| Homemade 3D | Down is up, Up is down? | 3D Flying | 2 | 09-12-2006 06:05 PM |
