Old 10-31-2005, 01:48 PM   #1
ENUT
ENUT's Avatar
Club: Wintonbury Flying club,Bloomfield,Ct.
Question Lipo battery balancing?
I just started flying with lipo batteries(TP 1320 3S) "How often do the need to be balanced?" thanxs,ENUT
Yes I'm a Lipo newbee
ENUT is offline
Old 10-31-2005, 02:58 PM   #2
Matt Kirsch
Matt Kirsch's Avatar
Truthfully, there's no hard and fast rule for balancing. The older the batteries are, and the harder you use them, the more often you should check to make sure they're balanced. In a perfect world, the cells should probably be checked every flight, but that's only practical if you have a balancing charger like the Skyvolt setup from FMA, or the offerings from Apogee or Thunder Power. With "conventional" packs, the reality is that you'll probably check individual cell voltages somewhat less than every flight. This is okay because under normal circumstances, the cell voltages don't go out of balance all that quickly, and cells that are in good condition and aren't abused won't vary much over the long haul, if they vary at all. Still, it's good to keep half an eye on the situation.
Matt Kirsch is offline
Old 11-01-2005, 02:24 PM   #3
Unbalanced prop
Watt, No fuel?
Unbalanced prop's Avatar
I have been checking and or balancing my 3S TP PL 1320s around every 10 flights. So far, after almost 100 cycles, they stay balanced very well on their own. I check my other brands around every 10 cycles also and they usually are very well balanced. As Matt said, I don't abuse my packs which helps to keep them in good shape and balance.
Doug
Electrics are COOL
Unbalanced prop is offline
Old 11-01-2005, 10:39 PM   #4
Heidelberg Germany Flyer
US Citizen, Overseas...
Is there any problem of soldering a connection to each cell to connect a balancer? My balancer only fits/connects to a Graupner battery?
I'm not sure I feel too comfortable playing with Lipos that way...
HGF
Heidelberg Germany Flyer is offline
Old 11-02-2005, 03:16 AM   #5
Unbalanced prop
Watt, No fuel?
I added taps (very carefully) to a couple older packs and made adapters for packs that already have taps to fit the balancer I use. Some cells have very fragile aluminum tabs to solder to any you have to use special flux. If you don't feel comfortable doing it, I would leave it alone. Packs that allready have taps should be no problem converting.
Doug
Electrics are COOL
Looking for LiPo Balancing Charger VF84sluggo Batteries & Chargers 10 04-02-2008 10:48 PM
Balancing the HBK2/battery recs Luvhelis Beginners - Helis 1 02-05-2008 06:02 AM
balancing lipo packs in series cliffh Batteries & Chargers 3 10-17-2007 10:26 PM
So I cut the balancing leads off... ruined battery MikeMc Batteries & Chargers 25 03-27-2006 04:46 AM
Older lipo battery balancing ?? rtn9105 Batteries & Chargers 6 03-07-2006 05:58 AM
Page generated in 0.09565 seconds with 27 queries
