Old 08-03-2007, 04:09 AM   #1
seiser01
Default Carbon Fiber control rods
Hey all,
I'm converting a Guillows Thomas Morse Scout to an RC park flyer. I'm using a GWS Pico system with carbon fiber control rods. AT the servo, I simply bound a small piece of wire with a Z-bend in it to the rod using thread and glue. This seems very strong and light. At the control horns however I would like an adjustable attachment. Any suggestions? Du-bro makes a micro quick connect and I am considering that but it is for .040 wire and my rods are .052 inches. Do they make special conectors for CF rods?
seiser01 is offline
Old 08-03-2007, 05:31 AM   #2
fhdavenport
Unofficial Gravity Tester
Hi,
I have a Katana MD coming. It has carbon fiber linkage also, so I'm looking at the options for linkage/connection to cf too. I found parts at http://www.centralhobbies.com. At the top of the page is a button called "pushrods". They put an exploded diagram of the parts they recommend.
I dunno' just yet what to recommend, but the ez connector, (it's a sleeve with a pinch type screw), doesn't appear to be the way to go with cf. It's too brittle. I have to wait until my plane gets here before I can eyeball the situation.
Sorry I'm not more help, but someone here will step up. I shall return to lurking.
Frank
fhdavenport is offline
Old 08-03-2007, 05:25 PM   #3
fhdavenport
Okay, I found another site. Try http://www.darolcady.com for an adhesive called "Flash Black". This sounds like great stuff for use with CF.
That first site has a lot of good info on it also about linkage in general.
these are both CF guys.
Frank
Old 08-03-2007, 05:27 PM   #4
fhdavenport
OOps. Sorry. the URL is http://www.darrolcady.com. Sorry. typo.
F.
Old 08-03-2007, 11:29 PM   #5
Rabbitcreekok
Rabbitcreekok's Avatar
View Rabbitcreekok's Gallery8
Friends: (30)
The way I have set up my indoor flyers with carbon fiber rods is to use a figure 4 end or an L bend or a Z bend in the proper size wire and use heat shrink tubing to attach the wire to the CF rod.
On the servo end, stick the wire and the CF rod inside the heat shrink where they overlap and shrink the tubing with a heat gun. Then wick CA into the joint. That will lock the joint in place.
At the control surface end, make the same kind of connection, but shrink the tubing to the point where you can still move the joint. Adjust the control surface to neutral, then shrink the heat shrink completely. If all is straight, wick CA into the joint.
You may have to use a couple of layers of tinfoil behind the tubing to keep the heat off the airplane.
If you ever need to adjust the control surface, just cut away the tubing and redo the connection.
You could use a straight piece of wire on the end of the CF rod and then use the quick connectors. You just cannot tighten the connector down on the CF rod because it will shatter and fail.
Jim
AMA 735658
Rabbitcreekok is offline
Old 08-04-2007, 05:19 AM   #6
seiser01
Default CF Rods
Thanks guys. Great info. I will be checking out those links.
I was going to try to use a quick connect directly on the rod but your comments made me reconsider. I've flown some larger scale RC and have gotten used to the du-bro threaded rod ends for adjustments so I guess I'm spoiled. Thanks for the ideas.
seiser01 is offline
Old 08-04-2007, 01:27 PM   #7
eflight-ray
eflight-ray's Avatar
Here's one from way back that I still occasionally use to give a little adjustment in a push rod.
The main wire, (I use 18swg wire), has a 'zig-zag' bend in it that can be opened up or closed slightly for adjustment. I then use a 'keeper' wire at the horn/servo ends, (22swg), to retain the push rod and still allow easy removal.
Hope the picture explains it.
Ray in Wales
As I get older I think more and more about the hereafter.
I walk into a room, and think, 'now what was it that I'm here after?' :o
eflight-ray is offline
Old 08-05-2007, 04:57 AM   #8
seiser01
That's interesting Ray. I may give that a wirl.
seiser01 is offline
For Sale - Carbon fiber rods .050" and .060" x 36" @ $1.25 each pico Airplanes - Electric For Sale & WTB 10 09-06-2007 02:41 PM
For Sale For Sale - Carbon fiber rods .050" and .060" x 36" @ $1.25 each pico General RC items For Sale and WTB 0 07-28-2007 06:42 PM
Reinforcing with carbon fiber rods? ironfistx Scratch and Kit Built Aircraft 8 07-07-2007 09:53 PM
WTB: Carbon Fiber rods for cheap HoaRC Field Equipment For Sale & WTB 0 06-10-2007 10:16 PM
Drilling carbon fiber rods Reindeer Scratch and Kit Built Aircraft 5 05-15-2007 09:32 AM
Page generated in 0.16671 seconds with 36 queries
