Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Seaplanes E-Powered
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 08-22-2007, 07:00 PM   #1
ripster327
Paul
Location: Keuka Lake (One of the Finger Lakes in New York State)
Default Slow Stick Flying Boat
What a blast! Finally got my GWS Slow Stick Flying Boat to ROW! The flying boat is made from the kit sold by Jim Spencer of Sayre, PA (jimsp1@yahoo.com). He's a Wattflyer member. Thanks Jim!!! SSFB total weight is 27 oz. Used a GWS speed 400 with 3:1 gear ratio and GWS 1180 prop, Electri-fly 12 amp micro ESC, and Electri-fly 3S (11.1V) 1500 mAh batt. Rose off the water (ROW) quickly. Flew level at good altitude at 1/2 throttle. With battery located below in the flying boat hull (resulting in low CG), the flight and landings are extremely stable. However, rather short duration, probably due to batteries not being fully charged. Previous flights required hand launching due to the use of speed 300 and 350 motors with 7.2V NiMH batteries. They were good flights but ROW was nearly impossible. Video clip to follow once I get someone to operate the camera. Check out Jim's postings on the SSFB as well as those by VTT. Very valuable stuff.
ripster327 is offline
Old 08-22-2007, 07:16 PM   #2
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
Send a message via AIM to FlyingMonkey
AP Contest Winner  AV Contest
Friends: (24)
do you have a link to any pics of this?
what about a link to his profile so we can see what else he has?
Self proclaimed dictator of the Flite Test fan club.
FlyingMonkey is offline
Old 08-23-2007, 02:57 PM   #3
ripster327
Paul
The best pics of the SSFB are those by Jim Spencer and can be found at jimsp. Try his thread entitled" SLOW STICK FLYING BOAT II." Go there for virtually everything you want to know about this plane. JIM HAS SOME GREAT PICS. Also, check out the site by RetiredVTT. He shows some modifications to Jim's design, including the widening of the sponsons that I incorporated.
Old 08-23-2007, 03:11 PM   #4
FlyingMonkey
Flite Test Fan
Friends: (24)
I have checked that out.
In fact, I referenced that thread yesterday.
Old 08-23-2007, 09:17 PM   #5
LAbelle44
LAbelle44's Avatar
View LAbelle44's Gallery1
Club: Columbia County RC Flyer's
Default Directions Please
I too have a jimsp SSFB, down right now due to dumb thumbs. I wonder if you can provide a link to the mods by VTT. No time like the present for modifications!
Do not worry Icarus, that wax will work just fine!
(response of lhs owner to first ARF buyer)
LAbelle44 is offline
Old 08-24-2007, 07:22 PM   #6
ripster327
Paul
Default Response to "Directions Please"
I incorrectly provided the site you refer to. The correct site is retiredVTT. Check it out and you'll see a beautiful yellow/blue SSFB (with the FB modification of Jim's design) with the modified sponsons. I contacted retiredVTT (his name is Bill) regarding his power system. It is: Hyperion 2213/20 motor, 18 amp esc, 3S pack and 10/3.8 prop. He says it flys well on half throttle. Good luck with your SSFB. Don't get discouraged. Once you get things right, the sky is the limit! (Sorry, I just couldn't help that.)
Paul
Old 08-24-2007, 09:13 PM   #7
LAbelle44
LAbelle44's Avatar
Okay, so my thumbs are not the only dumb part, I do not understand how to get to "site retiredvtt". I tried a search for post,s by retiredvtt with no luck. And thanks for the encouragement. My fellow club memebers say the same thing. I am learning how to take pride in creative crashes er landing's!
Old 08-24-2007, 10:07 PM   #8
ripster327
Paul
No, it's not you LAbelle. I went back to try to fine the posts by retiredVTT, and here's what I found. On wattflyer I went to the posting by jimsp dated 11 Feb 2007. After a few minutes I found myself NOT in wattflyer, but in the www.rcgroups.com web site. I'm not sure how that happened. Anyway, if you find yourself there, go to posting #112 dated 3 August 2006. That is one by retiredVTT with many pics. Look around in the area of that posting and you will fine more pics by both Jim at jimsp and Bill at retiredVTT. Good luck. Let me know how you did.
Paul
Old 08-29-2007, 12:16 AM   #9
LAbelle44
LAbelle44's Avatar
Thanks Paul, been on jury duty so havent had the energy to post. I will go hunting there!
Old 08-29-2007, 07:52 PM   #10
tdearth
I will second the fun factor of the slowstick float plane.
Here is a post I just made on RCGroups.
http://www.rcgroups.com/forums/showthread.php?t=735058
That post also has a link to Jim's original thread.
The only changes I made from Jims was to reinforce where the
pontoon CF rods enter the hull, and use a large rectangular hatch
for ease of battery insertion and water rudder maintenance.
This thing is a ball to fly off of even small water puddles.
Tim
tdearth is offline
Old 08-30-2007, 04:30 AM   #11
ripster327
Paul
Default Beautiful SSFB
tdearth,
Beautiful job! I really like the square hatch idea. I didn't know the SSFB would fly so high to require oxygen for the pilot.
What is the power system?
Paul
Old 08-30-2007, 09:29 PM   #12
tdearth
I have an eflight 370 outrunner with a GWS 10-47 slow fly prop.
I have been using TP1320 prolite LIPO but I am going to try a TP2100
because the extra weight is neglegible in this plane and I can use the extra duration.
With the 2100 I was afraid that the pilot would need oxygen for insurance.
Tim
tdearth is offline
Old 10-11-2007, 03:10 AM   #13
ripster327
Paul
Excellent move you made by reinforcing the CF rods at the hull. As my hull begins to disintegrate due to some hard landings, I'm beginning to see the utility in those reinforcements. I'll be sure to add them on my next build.
Paul
Old 10-11-2007, 03:02 PM   #14
ripster327
Paul
Default Inexpensive outrunner/ESC combo for SlowStick FB
OK, I don't usually provide endorsements of products, but I cannot let this one go by without telling about it. I recently purchased an outrunner and ESC for my SSFB on eBay for less than $30! The seller is "heads up rc." He sells a brushless outrunner 2410-09Y and a 20 Amp ESC (already programmed for SlowStick performance) for $29.50 (Buy It Now). His shipping cost is only $2.00 for as much as you want to buy in a single purchase. I am currently using his products with a GWS 1147 prop and the SSFB flys perfectly. Batt is a 3S (11.1V) 1500 mAh LiPo. Check out "heads up rc" on eBay as he has lots of other stuff at extremely reasonable (that means "cheap") prices.
Paul
Old 11-14-2008, 07:10 AM   #15
phupper
Flyin' Phup
phupper's Avatar
"I recently purchased an outrunner and ESC for my SSFB on eBay for less than $30! The seller is "heads up rc."
The secret's out!
"No user serviceable parts inside" means I have to crack it open to see what they think I can't fix.
I'd have a lot more planes if I didn't fly so often.
phupper is offline
Old 11-14-2008, 06:46 PM   #16
aviatordave
aviatordave's Avatar
View aviatordave's Gallery10
Club: A wooden stick used for hitting.
Send a message via Yahoo to aviatordave Send a message via Skype™ to aviatordave
AV Contest  Outstanding Contributor Award  AP Contest Winner  AP Contest Winner
Friends: (29)
Go directly to the site: http://www.headsuprc.com/servlet/StoreFront
aviatordave is offline
Old 11-21-2008, 02:04 AM   #17
ripster327
Paul
Default Don't Forget the CorrosionX
The secret's out!
Hey phupper. Don't forget to douse that motor and esc (and the rx) in CorrosionX. That stuff really works.
Paul
Old 07-28-2009, 01:53 AM   #18
seth_man
View seth_man's Gallery1
does anyone know how much tdearth's SS weighs? i too have made my FB from my PZ SLO-V and some insulation foam. Pics to follow, but i was just wanting to compare the weights.
Thank you to all of you, and your informational inputs!
seth_man is offline
Old 08-06-2009, 02:59 AM   #19
ripster327
Paul
Default SSFB Weight
I flew my first SSFB for two seasons and finally destroyed it last week in a tree on shore. I've got a second one almost finished and will provide the weight and pics in a posting perhaps this weekend. Waiting to see your pics as well.
Old 08-09-2009, 03:01 AM   #20
ripster327
Paul
Default Slow Stick Flying Boat II
Just finished my second Slow Stick Flying Boat based on Jim Spencer's FB kit (jimsp1@yahoo.com). The markings are WWI Polish Air Force (my name is Wojciechowski). Here are the specs: 2410-09Y brushless motor (supplied from headsuprc.com), GWS EP1147 prop, Power Up 32A ESC for brushless motors also supplied by headsuprc (shrink wrap removed), Cirrus MRX-4 (Mk. II) Rx, two Hitec HS-55 Feather Servos for rudder and elevator, Electrifly 3S LiPo Batt 1500 mAh 11.1 V wired for balancing, weight is 25.0 oz. (including Batt.), Wing Area is 506 sq. in. or 3.51 sq. ft. Wing Loading is 7.11 oz./sq. ft., flight time (based on SSFB I) is 12 to 16 minutes on fully charged 3S LiPo. All the above items were used on my first SSFB with great success (once I converted to brushless motor and LiPo batt). Rise off water (ROW) is effortless and quite scale-like. Flight is extremely stable due to low CofG and deep dihedral when flying. Alerons not necessary. Jim Spencer sometimes uses a fourth servo for water rudder (would be nice, but not really necessary). Motor, naked ESC and Rx are soaked in Corrosion-X overnight for waterproofing electronics. Paint job is rough due to Krylon Spray paint. DON'T USE IT ON FOAM! It eats up the foam even when precoated with two coats of Minwax Polycrylic. Note that in the photos, only two rubberbands are used to attach the wing. This was only for the photos. You should use at least six rubberbands for this purpose. Happy flying!
ID:	106998 Motor, ESC and Servos
ID:	107000 Aluminum Tape on Hull & Sponsons
ID:	107001 Ready to Patrol the Skies
ID:	107003 Let's Go Fly
Old 08-09-2009, 08:04 AM   #21
View CHELLIE's Gallery13
Friends: (281)
Nice Flying SS Ripster, It looks like a lot of Fun, Take care, Chellie
Old 08-12-2009, 10:16 PM   #22
lrb605
Default Jealous!
That is a great looking SS boat. I just wish I had water closer to me so I could have an excuse to build it!
Keep it up Ripster!
lrb605 is offline
Flying Boat Robert Murray General Electric Discussions 8 12-24-2010 02:55 PM
Flying Boat Hank47 Delta & Flying Wings 5 10-12-2007 06:31 AM
Slow Stick flying made easier cliffh Beginners 4 09-21-2007 06:07 AM
How to get a Flying boat off the water? Flyboytoo General Electric Discussions 4 09-06-2007 12:23 AM
Slow Stick Flying Boat Solid Hit General Electric Discussions 23 07-29-2006 10:53 PM
Page generated in 1.25377 seconds with 69 queries
