Old 09-05-2007, 03:11 AM   #1
Flyboytoo
Flyboytoo
Default How to get a Flying boat off the water?
I have a Hydro Foam flying boat. I have had a blast with it on the water. I have it set up with 3 servos (rudder, 2 for ailerons). I have briefly left the water and done an unintentional roll. The first roll came out ok - the second one tok some epoxy! How do I do a controled lift off without an elevator? I have been looking closely at the YouTube videos of these things and they appear to have ailerons. Is it possible to switch some wires around in a "Y" harness to get the servos to function together as elevators? Yes, I know that I can flip one of the servos to get the same effect but they are epoxyed in.
Thanks for any ideas/suggestions?
Flyboytoo
Flyboytoo is offline
Old 09-05-2007, 03:42 AM   #2
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Okay I think what you are wanting is...to add and elevator correct?
What you can do is either get whats called a V-tail mixer or if your Tx has it use the ELEVON setup.
Elevons are really just ailerons and elevator mixed. Pulling back on the left stick makes the elev go up, pushing it to the left or right will activate the ailerons. This is whats used on flying wings.
Hope that helps and heres a link to a V-tail mixer.
http://www2.towerhobbies.com/cgi-bin...?&I=LXHHS3&P=7
Also you may not have to remove or reposition your servos.
Water Boy is offline
Old 09-05-2007, 03:56 AM   #3
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Okay I hope this will explain it better. When you click on the pic, click on the puple square in the bottom right corner to enlarge. This way you can read the words.
Name:	Stryker elevons.JPG
Old 09-05-2007, 10:53 PM   #4
Flyboytoo
Flyboytoo
Default V Tail Mixer it is!!!
Thanks Water Boy
I have ordered 2 V tail mixers - They are the answer to how you get a flying boat off the water!!! Thanks much!
The diagram you sent was helpful too.
What's the story behind the WATER BOY?
Flyboytoo
Old 09-06-2007, 12:23 AM   #5
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Thanks Water Boy
Your welcome Flyboytoo. Glad I could help you out.
As far as the Water Boy, My last name is Waters. Thats pretty much the jist of it. Man its really not all that cool of a story.....HMMMM maybe I will think of some cool story and post it.
Hope you boat works well for you.
Capricorn - the ultimate flying boat. Larry3215 Foamies 2720 05-15-2013 07:17 AM
Flying Boat Robert Murray General Electric Discussions 8 12-24-2010 02:55 PM
Slow Stick Flying Boat ripster327 Seaplanes E-Powered 21 08-12-2009 10:16 PM
Flying Boat Hank47 Delta & Flying Wings 5 10-12-2007 06:31 AM
ESC and water - Ikarus Wizard flying boat Flyboytoo General Electric Discussions 4 08-07-2007 03:07 PM
Page generated in 0.28474 seconds with 30 queries
