#76 | ||
Friends: (16)
Originally Posted by GFH
Lets see, you need a minimum of 100 watts per pound of airplane, so that is 100X10 or 1000 watts. Since your model calls for up to a 120 4 stroke engine, that would be on the order of perhaps 150 watts per pound or a little more.
That is getting into serious electric motor horsepower. A wide variety of electric motors from a lot of different suppliers are available for this purpose. The question is which one to use? One program that will help a lot is www.motocalc.com, free for 30 Days, then $39. You can enter in your models wingspan, area, weight without motor and battery, and it will give you an idea on how well the model will fly. I'm an admitted Hacker nut, and would look at a Hacker A60-6SX. This motor would be an expensive, but very good power unit that will definitely pull your model around. Running this motor on an 8S1P (8 series, 1 parallel) LiPo pack with about 5000 Mah will allow this motor to turn a 16X8 APC-E (Electric) prop at around 9000 RPM. Motocalc indicates this motor will be running around 91% efficiency, a pretty good value. Again, per Motocalc, this motor will be pulling around 1900 Watts at full power, which turns out to be around 2.5 Horsepower. That comes out to about 190 Watts per pound, which will give plenty of power to haul up a sailplane in tow. I'm guessing on the wingspan, wing area and bare weight of your model as 66 inch span, 950 square inches, and 120 ounces bare weight with everything but the motor and battery. Nice thing about the Hacker motors, they will do what their specifications say they will, and will do it year after year. 9000 RPM on a 16 inch diameter Electric prop might be pushing the maximum RPM limits on an APC-E prop, you might have to go to a glow engine type of prop on this setup. As for speed controls check out the Castle Creations 75 Amp Phoenix ICE ESCs. The CC units work, and work well. (Looks like CC is out of stock on most everything, but perhaps other on line hobby stores will have one.) |
#77 | ||
Thanks Kyle
I should have added it has a 107 inch wingspan, 1550 sq inches. Not a high performer just large ![]() I tried motocalc link a couple of times and it was a dead end. Ill try again.. |
#78 | ||
AXIs website comes up with an AXI 5320/28 but I have no idea how to easily compare that with other manufacturers.
#79 | ||
Friends: (16)
No problem.
Check out the attached screen dumps for Motocalc on your proposed model and power setup. Bates # 1 and 2 are for a 17x6 prop, Bates # 3 and 4 are for a 16X8 Prop. Looks like either a 16x8 or 17X6 prop would be good with a good quality 8S LiPo pack. IMHO, it would be a good idea to stuff in as big a 8s LiPo pack as you can afford, since with the huge wingspan of this model, overall weight wound not be an issue. This model will obviously be a little overpowered with that Hacker motor, but if you're planning on towing sailplanes, being way overpowered is a good thing. Problem with some of those off brand higher powered motors, they've been known to have bearing problems, or have magnets come loose and so on. Not a good thing to have a power failure if you're towing a sailplane. This is for a smaller model, but a lot of the stuff covered in the PDF file will apply to your setup. Thread on 70 size glow engine conversion to electric http://www.wattflyer.com/forums/showthread.php?t=45222 One big problem with the larger electric model airplanes, is their cost skyrockets, something apparent when you look at the Hacker motor, the CC ESC, the LiPo battery, and the charger for the LiPo battery. On the other hand, you don't have vibration issues shaking your model and its servos apart, you don't have fuel getting all over everything, and fuel dripping on your auto carpet, or carpet in your home. I've got models that are on their 9th flying season with well over a thousand flights on one of them, that looks brand new. DennyV |
#80 | ||
I have been flying for 40 years I am an instructor and I am authorized to issue permits to fly for oversize aircraft (anything over 12 Kg but under 25Kg in Australia). I am however a total newbi to electric flight with aircraft. I have been reading endless threads on line but I am having trouble understanding prop size to motor to amp draw. In order to try and understand this I have started using either the CC ICE data logger or the Eagle Tree logger.
The results I am getting are so far from those published by the manufacturer of the motor I am really confused and would appreciate some help. Example Scorpion SII-3020-1110Kv (V2) motor CC ICE 75 ESC 3 cell and 4 cell 25c battery Scorpion says with a ACP 10x5E prop on 3s I should pull 29A and with 4s should be 48A I get 37A and 56A respectively. If I change to a SP 10x3.7 prop the current draw jumps to 71A I have tried similar other setups with different motors and in every case the current draw has been a lot more than the figures published. If anything what am I doing to get such a different result to the manufactures published results. I have tried Motorcalc but could not get it to work due to the data base not having ICE ESC or any of the current Hyperion batteries in its data base. Any help would be appreciated. |
There I was.. Inverted,,nothing on the clock..and only my joystick in my hand
#81 | ||
Friends: (16)
Originally Posted by CT4
I've not used the Scorpion motors, but have found that the various $$$$ Hacker motors are fairly close to their published value.
The CC ICE ESC will have little effect on the actual current pulled by the motor/battery/prop combination. By far, with a given motor, the propeller and cell count in the battery will have the greatest effect. So, rather than using a Hyperion battery, find another battery with similar capabilities in the motocalc battery database. Now, for the Scorpion motor. What I've done is take a current/voltage/rpm reading off of the motor with a given propeller. Then compare that reading to the measured values that you've taken. Then, go to the Scorpion motor specifications, save it as a different name, such as Scorpion my tests. Then tweek the KV numbers of the motor to match your actual tests. Now you've got a baseline on your Scorpion motor to try different props and so on in motocalc. You will find it doesn't take much of a change in the KV numbers to really make a big difference in how much current that motor/prop/battery pulls. And, just a few percent more in battery voltage under load (with a higher quality battery) can also make a big difference in the current pulled by the motor. Take a look: Thread on 70 size glow engine conversion to electric http://www.wattflyer.com/forums/showthread.php?t=45222 Also: http://www.wattflyer.com/forums/showthread.php?t=44686 And, if you decide to go for real high powered electric models, you will find that the cost skyrockets! And, you've got to find a way to field charge the motor battery. It takes either an AC source, or a PAIR of 120 Ampere Hour deep cycle batteries. And those deep cycle batteries won't last much more than a year or two. Personal experience. http://www.wattflyer.com/forums/showthread.php?t=59273 |
#82 | ||
amazing!! Just what I have been looking for thanks!
#83 | ||
Friends: (16)
#84 | ||
I was looking for this kind of tutorial on internet for few days. Actually i am interesting in buying electric power system for your model. I have found your tutorial very helpful. Thanks for sharing....
#85 | ||
Friends: (16)
Originally Posted by Barrymartin
What size model?
One of these threads should cover just about any size model with electric power. ![]() Giant Scale Power System: Battery Backup System http://www.wattflyer.com/forums/showthread.php?t=63794 Giant Scale electric motors vs Gasoline Engines http://www.wattflyer.com/forums/showthread.php?t=58035 Harbor Freight Gasoline/Alternator Setup http://www.wattflyer.com/forums/showthread.php?t=66066, Great Planes Giant Big Stick Electric Conversion http://www.wattflyer.com/forums/showthread.php?t=65052 Giant Scale Cessna Model http://www.wattflyer.com/forums/showthread.php?t=66414 Thread on 70 size glow engine conversion to electric http://www.wattflyer.com/forums/showthread.php?t=45222 Hacker 6S2P A123 powered Models http://www.wattflyer.com/forums/showthread.php?t=44686 Hangar 9 Kantana Model (Still waiting for flying weather on this model. Right now, its snowing outside. Again.) http://www.wattflyer.com/forums/showthread.php?t=68844 AEAJR's Site on Electric Power http://www.wattflyer.com/forums/showthread.php?t=18521 BEC Linear Current Rating http://www.wattflyer.com/forums/showthread.php?t=63497 |
| Tags |
| choosing , electric , model , power , system |
| Giant Scale Electric Power System | rcjake | Motors and Speed Controllers for sale & WTB | 8 | 06-06-2007 12:17 AM |
| Electric power system questions for a large PBY-5a | RSS Feed | RCU RSS Feed | 0 | 10-03-2006 10:10 AM |
| Choosing a Power System | omba | Power Systems | 9 | 05-16-2006 12:49 AM |
| Advice on upgrading the power system on my EasyGlider Electric? (long) | Jeremy Z | Hi-Performance and Sailplanes | 15 | 05-15-2006 09:31 PM |
| For Sale - Electric Power System | simibill | Motors and Speed Controllers for sale & WTB | 0 | 09-18-2005 05:10 PM |
