Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Sport Planes (Formerly I/C & Gas Conversion)
Old 11-16-2005, 05:09 AM   #1
manga
Default Great Planes Seawind conversion
Hi
I am new to electrics but this plane has me very interested. I think it can be a challenge to convert to electric. It is a flying hull. The specs are as follows:
"Wingspan: 71 in (1805 mm)
Wing Area: 676 sq in (43.6 dm2)
Weight: 10.25-12.25 lb (4.6-5.5kg)
Wing Loading: 35-41 oz/sq ft (106-127 g/dm2)
Length: 56 in (1410 mm)
Requires: 2-stroke .60 cu in (10 cc) or 4-stroke .70-.91 cu in (11.5-15 cc) engine, 5-7 channel radio w/7-9 servos"
The main problem I foresee is the available prop clearance. According to other forums the limit is 13". Great Planes recommends a 3 blade prop for the glow engines. I guess a 4 blade prop could also be used.
Any ideas what kind of set up (motor, gear, prop, battery, ESC) would work for this plane? Specially in light of the fact that prop size is limited by the design of the plane.
manga is offline
Old 11-16-2005, 03:50 PM   #2
Warden
Warden's Avatar
I'm not going to be of much help here as far as recommendations go. I looked at this plane as a conversion candidate myself and decided against it. That plane has some pretty hefty wing loading (35-45 oz/sq ft). If it flies glow it'll fly electric but it'd take an outrunner brushless with a lipo pack fer sure and lipo's and water don't mix very well.
Good luck in your quest! I'll be very interested to see what suggestions you get.
Always strive to be the person your dog thinks you are!
Warden is offline
Old 11-16-2005, 04:21 PM   #3
Matt Kirsch
Matt Kirsch's Avatar
I'm thinking 6S LiPoly battery for power, or 20-cell NiMH, but the LiPoly will be about half as heavy...
For motor on a .60-size sport plane conversion, I would normally recommend the AXi 4130/16 or the new Eflite 60 outrunner. What I'm worried about is being able to get enough propeller on either of these so there's enough power available to fly the plane. A motor with a slightly higher Kv rating than either of these would be a better choice on 20 cells.
Actually, I just got to thinking, and why not use more cells? A 7S LiPoly or 24 cell NiMH would allow these motors to spin a smaller prop faster. The AXi is rated for up to 8S, so that may even be an option....
Going with an 8S LiPoly, I estimate that you could run a 12x8 3-bladed prop on the AXi 4130/16 and be right in the ballpark.
Matt Kirsch is offline
Old 11-17-2005, 03:12 AM   #4
BillB
What is the concern with lipos and water? Tab corrosion?
Bill
BillB is offline
Old 11-17-2005, 10:34 PM   #5
manga
Thanks all for the imput. If you have more suggestions it would be appreciated.
Any thoughts on using the Kontronik Tango 45 motors for this application?
manga is offline
Old 11-18-2005, 12:13 AM   #6
bruff
Use a Vario adjustable pitch prop. 13" dia and dial in a pitch of 14" to 16". That should load the motor up and work fine. I did this to my 88" Skymaster.
Bob
bruff is offline
Old 11-18-2005, 12:39 AM   #7
jrb
I too have looked the Sea Wind (@ 6S & mulitblade); specifically for flying off snow.
A friend at my club has flown his with a .90FS and say its not “heavy”, maybe 8 pounds w/retracts.
He says its quite fast in the air yet is very docile on landing; and tracks very nicely.
And, he too is looking forward to flying it off snow.
jrb is offline
Old 11-18-2005, 01:04 PM   #8
Warden
Warden's Avatar
Default Lipos and water.
BillB, This is taken from "Answers.com".
The lithium in a Li-Poly cell is hazardous and will react violently with water.
Obviously, this would take a cell puncture for the lithium and water to mix but that scenario would be far from out of the question in a seaplane crash.
Answers.com isn't where I got the initial info. It may have been on this board that someone was thinking of putting lipos in an RC boat and the lipo/water hazard was mentioned.
It's kind of odd, too but recommended methods of disposal of Lipos involves puncturing a hole in the case and soaking in salt water. The kicker is that the cell is completely discharged before immersion.
Warden is offline
Old 11-19-2005, 07:53 AM   #9
BillB
Warden - Thanks for your response. I have just become painfully aware of another concern with LiPos and water.
Not too long ago, I flipped a floatplane in fresh water. No damage, but the 5S2P 5000 mah pack got wet. The pack has balance taps. I just recently noticed that one pair of parallel cells is always out of balance - charges higher and discharges lower than the other pairs. I suspect that an aluminum tab has corroded and that only one cell of the 2 cell pair is in the circuit.
The manufacturer agrees that corrosion might be the problem. Rather then open the pack myself, I have elected to send it to him to see if it is salvageable, but I am afraid that there may be other corrosion and the pack is toast.
Sorry to take the thread off topic - I am seriously considering the Sea Wind conversion.
Bill
BillB is offline
Old 11-19-2005, 06:48 PM   #10
manga
It seems that Lipos and water require extra precautions. Has anyone tried covering the conections with heat resistant silicone compund? Would that be detrimental to the battery pack? Sorry if the question sounds naive, but I am new to electrics, let alone Lipo technology.
What do R/C boat hobbists use to protect their battery packs?
manga is offline
Old 11-21-2005, 01:26 AM   #11
manga
Bob
buff,
Did you mean 2 or 3-blade prop? I noted that they also make 4-blade hubs. Nice product!
May be a 11- 12" dia 4-blade prop with 14-16" pitch would work for this plane.
manga is offline
Old 11-21-2005, 01:56 AM   #12
hoppy
Watts up Doc?
There is NO metallic Lithium in a LiPoly cell.
Here's some myth buster literature.
http://www.hardingenergy.com/pdfs/LiPolymer.pdf
http://americansolarchallenge.org/te...iumcontrol.pdf
http://www.ulbi.com/documents/msdshe...14-Polymer.pdf
hoppy is offline
Old 11-21-2005, 02:02 AM   #13
hoppy
Watts up Doc?
SeaWInd conversion thread
http://www.rcuniverse.com/forum/m_3378048/tm.htm
You might also check these conversions for a similar sized plane conversion-
http://www.hobby-lobby.com/glow2econ.htm
hoppy is offline
Great Planes Seawind Seaplane EP mpotter187 Seaplanes E-Powered 64 07-26-2011 09:23 PM
Great Planes SlowPoke E-Conversion stefanv Sport Planes (Formerly I/C & Gas Conversion) 21 04-17-2011 09:53 PM
SOLD: Great Planes Seawind EP ARF *RTF* FREE SHIPPING! rongreg13 Airplanes - Electric For Sale & WTB 2 10-27-2007 02:04 PM
Great Planes U-CAN-DO EP brushless conversion kgfly Foamies 0 01-16-2007 02:33 PM
great planes tiger moth conversion baddad Sport Planes (Formerly I/C & Gas Conversion) 12 06-19-2006 11:20 PM
Page generated in 0.10258 seconds with 43 queries
