Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 09-23-2007, 04:14 PM   #1
nitrobass180
Mike T
Default Electric sailplane 3 meter or larger
I am looking for some advice on electric sailplanes. I found the Hybrid electro on northeast sailplanes website. It looks like the airfoil I want.
Looking for something that is efficient and will fly great through the wind. One of the biggest features I am looking for is the ability to swap nose cones and go from electric back to regular nose. That way if I only have a short period of time to fly I can fly electric, if I have all day use winch or high start.
I like the carbon kevlar cap strip build on this one for durability.
let me know what you think and what the website it is sold on to look at.
looking to spend around 500.00 on the plane
This should be moved to the electric sailplane section. Sorry didn't see that area. First time posting
nitrobass180 is offline
Old 09-24-2007, 03:37 AM   #2
Jason T
Electron Liberator
Jason T's Avatar
View Jason T's Gallery8
Mike,
Welcome to Wattflyer!
I am not sure what your budget is but I know there are probably several that meet your requirements. I know of one in particular sold by SoaringUSA.com called the Trinity. You can get it with an electric nose as well as the soaring nose cone.
http://www.soaringusa.com/products/p...ategory_id=267
Jason T is offline
Old 10-01-2007, 06:18 PM   #3
Twizter68
I can't see my plane.....
Twizter68's Avatar
View Twizter68's Gallery2
Send a message via Yahoo to Twizter68
Go Woody, or go home! The Olympic II and IIs have the former for running a 600 series motor, you could easily modify the nose cap to be removeable....it can be found at www.skybench.com.
AMA 869130/LSF 8042
Currently planeless
Twizter68 is offline
Old 10-24-2007, 07:27 AM   #4
MNfly
Got altitude?
Default Bot
Personally I like the Bird of Time 3 meter.I have an original 1974 and plan to electrify it. I is made to use different weight blocks for wind and speed.
MNfly is offline
Old 04-12-2008, 11:54 AM   #5
Friends: (9)
Cool
Did you ever work out this quick change configuration? I would love to see it if you did.
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 04-12-2008, 05:49 PM   #6
nitrobass180
Mike T
no never found one that was was easy to change from electric to regular nose.
Old 04-13-2008, 05:24 AM   #7
Friends: (9)
In many of the modern electrics, the motor just about replaces the nose weight, so, if you put a hook in it and tape back the blades, or remove them, you basically have a convertable plane. No need to remove the motor, you will just have to add lead back.
www.lisf.org
www.flyesl.org
AEAJR is offline
Old 04-17-2008, 03:59 AM   #8
aeronca52
The Olympic's are great! I'm flying mine with a Master Airscrew 2.5:1 gearbox with the MA 12" folding prop. I use 1800 to 2000 7 cell nicads for the weight to help with wind penetration. What a different world from 2 meters.
aeronca52 is offline
Old 04-22-2008, 01:45 AM   #9
MNfly
Got altitude?
I also have a BOT same vintage as yours and plan on going electric also. I plan on using an AXI 2808/24
MNfly is offline
Old 05-02-2008, 10:27 PM   #10
mg1500
Default BOT electrified
I have a mid 33 year old BOT that is electrified. I am using a Hacker b408L and it goes vertical - actually over powered. I am flying it with three cell 2100 Thunder Power packs and have put it a carbon rod to replace the steel rod. What a great plane . . .
mg1500 is offline
Old 05-02-2008, 10:34 PM   #11
MNfly
Got altitude?
The biggest and only problem with a BOT is getting it to land ...I need to come up with something for a spoiler setup. I do not want to open the wings up so it could be a challange.
MNfly is offline
Electric sailplane Davehart Hi-Performance and Sailplanes 6 12-27-2008 10:04 AM
Great Planes 2 Meter Sailplane ed3 Airplanes - Electric For Sale & WTB 4 05-27-2008 05:06 AM
Great Planes 2 Meter Sailplane ed3 Airplanes - Electric For Sale & WTB 2 11-27-2007 11:32 PM
What size servos should be used with a 2 meter sailplane? ransom peek General Electric Discussions 19 01-08-2007 06:21 PM
Page generated in 0.09819 seconds with 39 queries
