Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 03-18-2013, 04:07 AM   #1926
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Saw one of these demo'ed by a HK rep at our field recently. Clocked at 96mph, supposedly completely stock. I was most impressed by his 96mph 4 point rolls ~4 feet off the deck! I'm tempted, but it sure seems scary. These things could hurt someone! To paraphrase, with great speed comes great responsibility!
Old 03-19-2013, 04:35 AM   #1927
Murman
Dumb-Thumbin' since 2007
Murman's Avatar
100mph Speed Demon
He must have added rudder control to his demo bird. The stock setup is only 3 channels.
Murman is offline
Old 03-19-2013, 09:24 AM   #1928
Club: CVMRCC, SEFSD
Nope! I couldn't believe it myself, but I saw it with my own eyes. They were very fast 4 pointers!
Old 03-30-2013, 10:22 PM   #1929
NeilRivera
175MPH Speed Demon  150mph Speed Demon
Default 4S Great Planes Super Rifle
Here is today's speed runs ! Loving it ! Zero wind, no clouds and temps in the upper 70's
NeilRivera is offline
Old 03-30-2013, 10:24 PM   #1930
NeilRivera
Default Rifle speed runs
Getting better...
Old 03-30-2013, 10:27 PM   #1931
NeilRivera
Default Rifle Runs
Finally! 200 plus...out of a dive ! But it is still 200 !
Old 04-06-2013, 08:49 PM   #1932
57sailplane
Motorcalc Junky
57sailplane's Avatar
100mph Speed Demon
so, if i dive my gws fw 190 and get a click on the radar gun of 159mph coming straight down at me dose that count. LOL
I am a Speed Freak!!!
57sailplane is offline
Old 04-08-2013, 03:16 AM   #1933
Murman
Murman's Avatar
100mph Speed Demon
I believe a true and fair speed pass doesn't involve any kind of dive. If you're just trying to reach a certain speed to please yourself, then have at it. I recently had a guy in another forum claim his stock Rare Bear was doing around 130mph when everyone else's RB only did around 110mph. Turns out it was in a dive, not a straight line pass. When everyone else is posting level speeds, it's like comparing apples to oranges.
Murman is offline
Old 06-22-2013, 05:22 PM   #1934
papabatman
papabatman's Avatar
2kW  100mph Speed Demon
here is a couple of runs
papabatman is offline
Old 10-01-2013, 08:23 PM   #1935
speedfreak123
Club: wrcfs ( wirral radio control flying society)
Hey guys. Iv just orded a dr mad thrust 4s 3300kv 1100w inruneer for my reverb hotliner. What prop and esc would be best. I have 4s 2200 70c lipos.
speedfreak123 is offline
Old 10-02-2013, 06:54 AM   #1936
View CHELLIE's Gallery13
Friends: (327)
Try a 5x5 or 5x4 apc prop, check your watts and amps, use a 80 amp turnigy plush esc if amp draw is to much with a 5" prop go to a 4.75 x 4.75 prop.
prop pitch speed with a 5 pitch prop is over 200mph with a 4 cell, but check the amps to be on the safe side, dont go over 80 amps, the motor is rated for 70 amps.
Old 10-02-2013, 12:22 PM   #1937
speedfreak123
Should I leave the esc on default setting or programme it different? I have the 80 amp turnigy plush.
Old 10-02-2013, 12:34 PM   #1938
Friends: (327)
start out with the lowest timing first and see what the amps are, bump up the timing after testing with different props, leave the esc at default but check it with a programming card, also set the esc throttle end points with the transmitter. hope that helps, Chellie
Old 10-02-2013, 12:47 PM   #1939
Friends: (327)
Default setting throttle end points
some great info from Nigel
Quite a few ESC need to see the FULL range of throttle stick movement ... so for setting it up :
a) Switch on TX
b) Put trim all way DOWN
c) Put stick all way UP to max throttle
d) Plug in model battery pack
e) Listen for beep
f) Return Tx throttle stick to DOWN minimum throttle position.
g) Listen for confirmation beep
Power of both.
Now test ...
1) Switch on Tx
2) Put throttle trim to mid point
3) Throttle stick to idle position
4) Connect battery to model
Listen for beeps / music if enabled.
Try throttle ... you should have full range now.
If not ... reverse Tx throttle and try above set-up again ....
It's always good as well if you have a Throttle Cut or Hold you can activate when connecting model battery's ... but this will inhibit arming of motor till switched of.
Old 10-03-2013, 02:25 AM   #1940
View Don Sims's Gallery114
WAA-08 Pilot  Globetrotter Pilot
Friends: (41)
Don't forget, we need the following info to give your awards...
NAME;
SPEED;
PLANE;
MOTOR;
ESC;
BATTERY;
PROP;
Take care and thanks for posting at WattFlyer!!
Don
Don Sims is online now
Old 06-20-2014, 06:37 PM   #1941
waytooslow
Crash'em if you got 'em!
waytooslow's Avatar
Club: 114th Grapevine
100mph Speed Demon
we had faster passes with the F27Q on 4S, but it was suspect - 161??? Probably not? but possible
so submitting a slow one into wind, I am breaking down to get a radar unit
NAME; waytooslow
SPEED;100.7 (went faster but suspect error in program)
PLANE;parkzone f27q styker
MOTOR; stock 450
ESC; Grayson 70 amp - I had laying around
BATTERY; motion rc admiral 4S 2200 30c
PROP; APC 7x5 EP
Too many hobbies, and not enough time!
waytooslow is offline
Old 06-20-2014, 09:18 PM   #1942
Club: CVMRCC, SEFSD
Heeeyy, wait a minute... Is someone by the name of waytooslow allowed to join the 100mph club???
LOL! Good luck! I have to get my act together with the EF Phantom and join! My MPX Tucan may be a contender, too. But it's waiting to get finished after the XF5U...
Old 06-21-2014, 03:29 AM   #1943
View dahawk's Gallery6
Club: 114th RC Aero Squadron
Yep, I was there standing right next to WTS ! I swear it was doing 150, maybe more on the downwind. Seen enough of these now to know what 100+ is like.
Old 06-21-2014, 03:41 AM   #1944
"Too fast" is almost fast enough...
Old 06-21-2014, 05:01 AM   #1945
waytooslow
waytooslow's Avatar
100mph Speed Demon
It's a ploy to lull my victims. Actually it came from my motorcycle race days----- slow in fast out.
Old 06-21-2014, 01:25 PM   #1946
WTS,
Check thread # 1940 above. Need the details.
Old 06-21-2014, 04:51 PM   #1947
waytooslow
waytooslow's Avatar
100mph Speed Demon
Thanks. Adjusted the post. This too much work.
Old 06-22-2014, 12:36 AM   #1948
Friends: (41)
Gotcha taken care of! Congrats!
Don
Old 08-19-2014, 04:29 AM   #1949
semperfi1970
Club: Club of hard knocks
Wow my very first post on this forum. I have lurked long enough and decided to become part of the community. Here is a video of a 35" GWS Corsair with a mod or two. I do not know how fast it is as I have no real means of measuring speed. With a buddy and a stop watch (less than scientific but good enough for a red neck) it will cover a football field in under 1.3 seconds goal to goal. The plane is running a EF1 racing motor on 4s spinning a 9x9 prop.
semperfi1970 is offline
Old 08-19-2014, 04:30 AM   #1950
semperfi1970
Oops, gotta have one or more posts to have a link. Here is the video.
Tags
100 , club , mph
HYPER MINI BEE 100+ mph ? Hope so CHELLIE Delta & Flying Wings 45 06-11-2016 12:42 AM
want a 100+ mph delta/wing HELP!!! Figure.N9ne Delta & Flying Wings 26 09-18-2008 07:22 AM
100+ mph Microjet crash Aero Ace Ace Crash and Safety Forum 5 06-17-2008 01:58 AM
Speed Runs 100+ Mph Club Info CHELLIE Delta & Flying Wings 2 03-02-2008 12:14 AM
Page generated in 0.93103 seconds with 75 queries
