Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Electronic Builders Workshop
Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
Old 11-28-2007, 06:33 PM   #1
diego
Question Reversing polarity of brushed motor
Hello, I have a brushed DC motor, Electrifly T-370, which has an arrow on its label that shows the (preferred) direction of rotation. I want to reverse the direction, by reversing the polarity. However, I have been told that the efficiency of the motor is not the same as when the axis is rotating in the recommended direction.
My question is: is this true? If it is, by how much should I expect the efficiency to drop? Are there any other side effects?
Thanks a lot!
Diego.
diego is offline
Old 11-28-2007, 06:37 PM   #2
jonnyjetprop
It can be true. Brushed motors are timed. Most are not "neutral" but favor one directing over the other. Since brushed motors are a black art, I'd just suggest running it as is. Some of the more expensive motors can be chaged easily while the cheap can motors are basically forced by gripping the can of the motor and twisting it opposite the direction of rotation. How much?
John
jonnyjetprop is offline
Old 11-28-2007, 10:10 PM   #3
diego
Thanks for your advise.
Diego.
diego is offline
Old 11-29-2007, 05:23 PM   #4
rcflyair
Send a message via Skype™ to rcflyair
Default motor
Run the motor the way it is intended and flip the prop.
rcflyair
www.rcflyair.com
rcflyair is offline
Old 12-01-2007, 06:02 PM   #5
pilotpete2
Pilotpete2
pilotpete2's Avatar
rcflyair
www.rcflyair.com
"Flipping the prop" is used to start gas and glow engines. Sorry, but a "pusher" prop is needed in this case, putting the prop on backwards won't do it. Pete
pilotpete2 is offline
Old 02-14-2008, 02:10 PM   #6
xplo5iv
Lawn Dart Specialist
In addition the brushes may be designed mechanically in such a way that they need the motor to rotate in a particular direction. Reversing direction in such a case could damage the brushes quite quickly
xplo5iv is offline
Old 02-15-2008, 02:37 AM   #7
cyclops2
Default If you have GOOD eyesight.
You can look into the brush end of a motor and see if the brushes are straight up & down. If they are, No brush damage will occur.
You can then reverse the leads on the motor safely.
To test for SPEED loss. Unhook the motor. Test run it each way with a single C or D cell. Sound the same ? close enough ? Go for it.
Rich
cyclops2 is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
dx6i reversing motor rotation, help! micro heli t-rex frame style Alpha_&_Omega Micro Sized Electric Helicopters 5 07-19-2008 08:05 AM
Brushed Motor Temperature dumorian Power Systems 9 05-08-2008 01:36 AM
Deans Polarity? Les Ward Beginners 20 08-21-2007 09:36 PM
Waypoint Motor shaft reversing Jollyroger Power Systems 2 05-05-2007 03:37 PM
Hacker Reversing motor shaft Pony Pirate Power Systems 1 09-03-2005 01:15 AM
Page generated in 0.06988 seconds with 31 queries
