| Aerial Photography Discuss all aerial photography topics as they relate to rc aircraft |
#1 | ||
www.FPVpilot.com
I got one of these on the way FlyCamOne v2 video camera. It's alot better then the first one I'm told which I have but rarley use. Anyone have anymore info or feedback on it. Thanks
#2 | ||
I got mine over a Week ago but the Weather's so bad in the UK, I've not had chance to try it.
It's attached to my PZ Spitfire ready for a flight! Here are a couple of videos from the FCO 2 I've seen elsewhere. http://www.acme-online.de/video/c17.wmv http://www.airmix.de/modules/shop/fi...9aa7c11953.wmv Paul. |
#3 | ||
www.FPVpilot.com
Thanks for sharing the videos
. Mine will be here Monday . I like the way the camera lens can turn 90o, that's cool. There picture resolution looks pretty good.
#4 | ||
WAA-08 Pilot #1
Club: Gloucester Aera Modelers Association (GAMA)
Waiting on some more examples. Thanks for sharing those.
What format does it record in? Thanks, Frank |
#5 | ||
It does't seem to say in the manual. AVI I think.
It drops straight into Windows Media Player/Movie Maker. I did my first flight today. It's very gloomy here, so came out a little dark. Not too bad though. I'm pretty happy with it considering the light. If you have plenty of Sun light it would be fine. Paul. |
#6 | ||
WAA-08 Pilot #1
Thanks Paul. Most likely AVI if WMM takes it.
Frank |
#7 | ||
Just found the Official Forum on the ACME website.
It's mostly in German, but I would think if you asked questions in English, you would get an English reply. http://www.flycamone2.com/index.php?id=28&L=3 Paul. |
#8 | ||
www.FPVpilot.com
It might be AVI since it records 30min of video on a 2gb card. That's a big file.
#9 | ||
Originally Posted by Murocflyer
I just got my FCO2 a couple of days ago, but the weather has kept me from trying it outdoors yet. I shot a little test video inside the house just to verify that it was working. I checked the video with Gspot to see what format it was using for audio and video. As you can see from the Gspot output below it shoots MotionJPEG video and 8 bit PCM audio all contained in an AVI container. It outputs about 4 Megabits per second to the SD card.
--Dave ------------------------------------------------------------------------- --- File Information --- File Name: PICT0001.AVI File Name (with full path): L:\DCIM\100DSCIM\PICT0001.AVI File Size (in bytes): 6,396,932 --- Container Information --- Base Type (e.g "AVI"): AVI(.AVI) Subtype (e.g "OpenDML"): AVI v1.0, Interleave (in ms): Preload (in ms): Audio alignment("split across interleaves"): Total System Bitrate (kbps): 0 Bytes Missing (if any): 0 Number of Audio Streams: 1 --- Video Information --- Video Codec Type(e.g. "DIV3"): MJPG Video Codec Name(e.g. "DivX 3, Low-Motion"): Motion JPEG Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed Duration (hh:mm:ss): 0:12.514 Frame Count: 329 Frame Width (pixels): 640 Frame Height (pixels): 480 Storage Aspect Ratio("SAR")" 1.333 Pixel Aspect Ratio ("PAR"): 1.000 Display Aspect Ratio ("DAR"): 1.333 Fields Per Second: Frames Per Second: 26.290 Pics Per Second: 26.290 Video Bitrate (kbps): 4018 MPEG-4 ("MPEG-4" or ""): B-VOP ("B-VOP" or ""): QPel ("QPel" or ""): GMC ("GMC" or ""): NVOP ("NVOP" or ""): H264 ("H264" or ""): Quality Factor (bits/pixel)/frame: 0.498" MPEG-2 ("MPEG-2" or ""): Interlaced ("I/L" or ""): Progressive ("Prog" or ""): Top Frame First ("TFF" or ""): Bottom Frame First ("BFF" or ""): 3:2 Pulldown ("3:2" or ""): Picture-per-field ("PPF" or ""): --- Aspect Ratio Related --- Broadcast standard: "PAL" (else blank) Broadcast standard: "NTSC" (else blank) src:"VCD", "SVCD", "CVD", or "DVD (else blank): Instructions to convert to VCD, first part: Instructions to convert to VCD, second part: Instructions to convert to SVCD, first part: Instructions to convert to SVCD, second part: Instructions to convert to CVD, first part: Instructions to convert to CVD, second part: Instructions to convert to DVD, first part: Instructions to convert to DVD, second part: Instructions to convert to AVI, first part: Instructions to convert to AVI, second part: --- Audio Information --- MPEG Stream ID (e.g. "0xbd"): MPEG VOB file Substream(e.g. "0x80"): Audio Codec (e.g. "AC3"): PCM Audio Audio Codec Status (e.g. "Codec Is Installed"): No Codec Required Audio Sample Rate (Hz): 8000 Audio Bitrate(kbps): 64 Audio Bitrate Type ("CBR" or "VBR"): Audio Channel Count (e.g. "2" for stereo): 1 |
#10 | ||
Originally Posted by English Electric
On the ACME forums site, ACME indicated that they "burned their fingers" on the delivery of the FCO2, and that they will be offering a firmware update for the FCO2 on their web site "real soon now". Dark videos seemed to be a relatively common concern, so I hope they address that with the upcoming new firmware. I know that I can not get decent videos indoors, with normal room light, with mine.
--Dave |
#11 | ||
WAA-08 Pilot #1
Dave,
That settles that! Thanks for the info. Very cool program you have there. Looking forward to the FC2 videos. Frank |
#12 | ||
Does any one know if a SanDisk 4GB Extreme III SDHC 4GB Secure Digital or something that wil read and write faster than a regular 4GB SD card will be compatiable. I see FCO2 has something that has a faster read rate. To make sure your Frame rate is getting the max frame rate.
Thanks, Jeff |
#13 | ||
Originally Posted by DaveS
What type of card did you use. A standard speed etc....
#14 | ||
The card I have used is a standard speed one.
High capacity cards cannot be used. 2gb is the max. Paul. |
#15 | ||
#16 | ||
#17 | ||
Just shot a video from my PZ Spitfire.
Still gloomy over here, but I think I can conclude that the video quality is not that great... Sorry about the bad flying! New Brushless motor fitted and needed a bit of a re trim, plus cold hands!! ![]() http://uk.youtube.com/watch?v=IsgzNN3YDOA Paul. |
#18 | ||
FWIW, the video quality of current CMOS sensors is never going to match the video quality of the CCD sensors in hand held cameras. There seems to be a few seconds of good exposures every once in a while in that video, but the low light, and prop in the frame, sure seem to wrecking havoc with the exposure control and color balance in the video. Since a CMOS image sensor does not have anything like a shutter mechanism, it would probably be a lot better to keep close in high speed motion out of the frame to avoid strobing the automatic exposure control and color balance software. Hopefully, ACME will address some of the low light difficulties in their upcoming firmware update for the FCO2. As usual, YouTube makes telling much else about the video pretty difficult.
--Dave |
#19 | ||
I made another video, this time from a Wing Dragon [BL motor and glider wing].
The Dragon flys much slower and has no prop in the way. Will try to get a video in decent light if we ever get any... ![]() http://uk.youtube.com/watch?v=mtno7-Whr7Y Paul. |
#20 | ||
Hey that one looked better! The exposure control seemed better, and so did the color correction (most of the time). Do you see the soft distant focus in the original camera output, or is that an artifact of the YouTube compression?
--Dave |
#22 | ||
Ouch!!!
![]() I notice that in mine too. I hope someone has the nerve to find a non-destructive way to open the case and adjust the lens focus for those of us who need it. The webcam app on the ACME site might work like a viewfinder to adjust the focus, if there is a non-destructive way to get inside the camera. --Dave |
#23 | ||
My focus sharpness and exposure improved significantly once I noticed and removed the protective plastic film from the camera head.
I carefully used a finger nail at the edge to avoid scratching the center. The camera head face is now glossy, instead of flat.
#24 | ||
Originally Posted by gjhaycraft
Man, do I feel like a dummy now, or what???
![]() After reading your post, I just removed the protective film from the lens of my FCO2, and now I need to go take a few more test videos. I am SURE that it will improve without the plastic film covering the lens, but how much? In my own defense, that protective film was VERY well hidden. ![]() --Dave |
#25 | ||
I sent mine back.I tried 2 sd cards,sound and video not in sync,and blue and red flashes in video.The directions should say that you need a high speed card,and to remove the plastic film on the lens.I did'nt notice that.I'll follow this board and maybe get a new one later.Dissapointing.
| Tags |
| flycamone , hobby , lobbys , v2 |
| FlyCamOne VS. 5-in-1 EDVR | sox101 | Aerial Photography | 78 | 03-26-2009 03:11 AM |
| FlyCamOne 2 velcro | platinumjason | Aerial Photography | 2 | 05-05-2008 03:43 AM |
| flycamone/two installed on twister jet | mulikow | Electric Ducted Fan Jets | 4 | 03-17-2008 04:12 AM |
| MM_Calc v2.09 -> v2.10 | ron_van_sommeren | General Electric Discussions | 2 | 10-25-2007 09:40 PM |
| Hooby-Lobbys new EV-97 | skiman762 | Beginners | 1 | 07-08-2006 05:40 AM |
