Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric Helicopters > General RC E-Heli Talk
Old 01-12-2008, 06:57 PM   #1
zirconx
RC Flyer
zirconx's Avatar
View zirconx's Gallery6
Default How to repair the canopy?
What have others done to repair the thin plastic canopies like on the Blade CP?
I would think super glue would crack fairly quickly. What about hot glue?
zirconx is offline
Old 01-12-2008, 11:24 PM   #2
1kW
Friends: (7)
You can try putting clear tape on the inside and then dab a little super glue on the cracks on the outside. They are very fragile. I usually repair them by pulling out my wallet.
The hot Glue does sound like a decent idea, just keep it away from the motor! Batteries get warm too, but I usually cant keep mine in the air long enough for that to happen...
I know that you believe you understand what you think I said, but I’m not sure you realize that what you heard is not what I meant
-Rob
Old 01-12-2008, 11:25 PM   #3
View CHELLIE's Gallery13
Friends: (281)
try 5 min Epoxy, it works great, you just need to use a little, Take care, Chellie
Old 01-13-2008, 12:15 AM   #4
1kW
Friends: (7)
Thanks Chellie! Why is it, sometimes the best ideas are right under our noses.
-Rob
Old 01-13-2008, 05:16 AM   #5
rcflyair
Send a message via Skype™ to rcflyair
Default canopy
I use very light weight fiberglass cloth. Cut a piece that covers the crack, and place it on the inside of the canopy. Then dab a little thin CA over the cloth. Swab off the excess with a paper towel (keep your eyes and nose away). You can hit it with accelerator if you want.
Light, works good, strong.
rcflyair
www.rcflyair.com
AMA 588516
LSF 1007
rcflyair is offline
Old 05-31-2012, 04:00 AM   #6
Mr. Clean
Club: AMA member but no club yet
I just tried the CA glue method on my Airfield (FMS) Trojan T28 canopy and it worked great! I did not use the paper backing and have not put it to the test, but it looks really good. I did tape it from the inside and glue it from the outside, but next time I would tape it on the outside and glue it on the inside.
I will continue to use this method for future canopy repairs.
Born again RC flyer having fun and documenting my experiences.
http://mywildhawkexperience.blogspot.com
http://rcflyingfun.blogspot.com
Mr. Clean is offline
Old 06-01-2012, 04:13 AM   #7
MWShelton
View MWShelton's Gallery8
If you can find it Shoe Goo does excellent. I cut a piece of the sheetrock tape (the kind that looks like screen wire) cover the crack and lightly coat it with Shoe Goo. I repair and reinforce my offroad rc cars this way and they take an awful beating. If you check on replacement you'll probably find out a new canopy cost less than the materials to repair it with unless you already have them. New canopies usually are anywhere from 4 to $10.
MWShelton is offline
Old 06-09-2012, 07:48 AM   #8
Mr. Clean
I would have replaced the canopy if I could get just the canopy. For the Airfield (FMS) Trojan T28, I could only find it with the foam cockpit and pilot. I'm not to the point yet where I want to get all of that too.
Old 01-21-2013, 05:04 AM   #9
Berrymartin
Banned
only way is to solder the wires off to get the motors out.
Berrymartin is offline
Sliding canopy warbird@home Warbird Electrics 5 11-29-2007 07:39 PM
Canopy attachment elbreeden Scratch and Kit Built Aircraft 2 03-25-2007 03:54 PM
Polypropylene Canopy / Fuse Repair cbatters Scratch and Kit Built Aircraft 4 10-26-2006 07:58 PM
x400 Canopy Inseminator General RC E-Heli Talk 6 10-22-2006 11:16 AM
looking for canopy watt_the?! General RC E-Heli Talk 8 03-09-2006 07:52 AM
Page generated in 0.22632 seconds with 34 queries
