Old 02-10-2008, 03:44 AM   #1
sgf323
View sgf323's Gallery12
Default Making sense of Watts, RPM, Amps and how to calculate thrust?
I've got an eLogger and I've been doing some playing around with it. With a nearly charged battery here are some readings I just got with my Park 450.
11x7E: 190 watts, 17 amps, 7800 rpm
10x7SF: 220 watts, 20 amps, 7300 rpm
The 20 amps is just above the max burst for the motor but, how would these two setups differ in the real world? Which would provide more thrust?
Since the 11x7E is pulling less amps the watts are lower but that doesn't mean it's a less powerful setup, right? Being that both are x7 props with the SF just having more prop area I'm assuming the 11x7E would be faster and provide more thrust since it is turning at a higher RPM. Is that right?
I though I read somewhere that you could calculate thrust based on several parameters, including RPM, but I can't find it anywhere. Anyone know how to do this?
sgf323 is offline
Old 02-10-2008, 04:17 AM   #2
Dr Kiwi
Outstanding Contributor Award
Here is a good way to get a ballpark estimate of thrust if you know your rpm: http://www.badcock.net/cgi-bin/powertrain/propconst.cgi
The other way is for me to check my spreadsheet with 8500 entries for motor/prop/rpm/thrust etc and match your rpm for each of those props.
Back in a minute!
11x7 APC E: My measurement from my thrust stand: 7770rpm = 1374g/48.52oz
From badcock - his figures tend to be just a fraction low: 7800rpm = 1334g/47.00oz
10x7 APC SF: I've never dared take one that high - safe rpm limit for that prop (as listed by the manufacturer) is only 6500rpm; from badcock: 7300rpm = 1268g/44.65oz
Dr Kiwi is offline
Old 02-10-2008, 04:21 AM   #3
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
WAA-08 Pilot  Globetrotter Pilot  AV Contest  AP Contest Winner
I gave up on trying to figure that out long ago.
Here is what I use when I need to know that: http://www.gobrushless.com/testing/t...calculator.php
I'm sure someone knows how to do that. Looking forward to a better response.
Frank
Murocflyer is offline
Old 02-10-2008, 04:23 AM   #4
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Back in a minute!
Cool! Another one for the reference book.
Thanks!
Frank
Old 02-10-2008, 04:43 AM   #5
sgf323
Heh, I guess I never even thought about seeing if I was taking the SF prop too high!
I guess I'll try the 11x7E out for a while!
sgf323 is offline
Old 02-10-2008, 07:48 AM   #6
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
This illustrates one other thing - diameter is king when it comes to thrust.
Even tho the 10x4.7 prop had more power and was turning at a significantly higher rpm, it developed less thrust than the 11" prop.
Thrust is a function of two things - prop diameter and prop rpm.
Thrust goes up as the 3rd power of RPM but it goes up as the 4th power of diameter. In other words - if you double the rpm you get 8 times the thrust 2x2x2=8. But if you double the diameter you get 16 times the thrust 2x2x2x2=16.
So if all your concerned about is thrust - larger props are your friend
Larry
Larry3215 is offline
Speed, Thrust, and Watts - Why do watts really matter? PerlAddict Power Systems 6 01-10-2008 05:25 AM
Amps X Volts = Watts ?? diverdon Power Systems 21 12-21-2007 04:34 AM
Kv Rpm Watts Pitch Speed Volts wattflyer6161 General Electric Discussions 1 06-19-2007 04:25 PM
Volts, Amps and Watts Johan Power Systems 41 03-03-2007 07:32 PM
Calculate Amps from C? RSS Feed RCU RSS Feed 0 09-28-2006 09:20 AM
Page generated in 0.22069 seconds with 29 queries
