Old 04-03-2008, 10:35 PM   #1
Tyrant Blaze
Pull up, pull up, PULL UP
Tyrant Blaze's Avatar
View Tyrant Blaze's Gallery6
Default AR6200 Receiver connections
Hi
Ok, so I now have the DX6i and AR6200 Receiver...here come all the questions.
I am reading up on binding the receiver and the manual shows a receiver battery being used and the binding plug connected to the charge plug receptacle (See link)
http://h1070250.hobbyshopnow.com/Pr...ructions.pdf
I need to power the receiver througth the ESC because I dont use a receiver battery. The bind plug can be connected directly to the receiver Battery/Binder connector but this leaves no where to power the receiver from.
Can the receiver be powered through any of the vacant control channels?
Finally the 3-pin connectors on the receiver are not labeled for
+,- and Sig, is there a standard convention used for these pin outs?
Thanks in advance for any help
EEP Hacker Piper Cub, EPP BF109, EPP Mustang P51D, Hyperion Piper Cub,
GWS Tiger Moth 400, MiniMag
Tyrant Blaze is offline
Old 04-03-2008, 10:41 PM   #2
ronin4740
The AR6200 binds the same way that the other AR's do. Use the binding plug on the batt channel of the RX and use the ESC on the throttle channel. Connect a battery to the ESC and you're in binding mode!
usually the black wire on the servo/esc is the - connector.
Hope this helps!
ronin4740 is offline
Old 04-03-2008, 11:12 PM   #3
simibill
General Factotum
simibill's Avatar
View simibill's Gallery34
Club: Simi Valley Flyers
Outstanding Contributor Award
Originally Posted by Tyrant Blaze View Post
Hi
You can do the binding using the receiver battery as shown. When finished binding just remove the receiver battery hookup. Now you can proceed to connect your ESC to the throttle channel and other servos to their respective channels. For the AR6200, connect all servos and the ESC with the black wire towards the outside of the case.
Life's journey is not to arrive at the grave in a well preserved body,
but rather to skid in sideways totally worn out shouting, Holy Crap... what a ride.
simibill is offline
Old 04-04-2008, 12:25 AM   #4
HeadMaster
HeadMaster's Avatar
Hope this helps!
Yep...if it doesnt bind with the ESC plugged in one way flip the ESC plug around as the polarity is wrong...been there done that. and dont forget to remove the bind plug after binding
HeadMaster is offline
Old 04-04-2008, 08:28 AM   #5
Tyrant Blaze
Hey guys
Manys thanks for all the replys, you are a real helpful bunch
Chris
Old 10-11-2009, 04:22 AM   #6
Snoopy
Club: none
for the dx6 reciever do i need a 'Y' cable for the ailerons? i only see 1 slot i think for the connection.
Snoopy is offline
Old 10-11-2009, 08:06 PM   #7
Tyrant Blaze
Hi Snoopy.
If its anything like the Dx6i then no you dont have to use a Y cable, you can set up dual ailerons.
On the Dx6i its found in the 'Setup Menu' under 'Wing Tail Mix' and then the 'Dual Aileron' option, enable this option and you can use a seperate servo on each aileron.
The advantage of this arrangement over a Y cable is you can add differential to the aileron control. There are probably other advantages and I'm sure one of the nice people in here will chime in with them.
Chris
Old 10-11-2009, 08:22 PM   #8
Snoopy
Club: none
thx i running a dx6 reciever with a dx5 transmitter ... i needed the y cable, just got the plane done ultimate e-flite. plan to stretch its wings in a day or so... winter coming, i can always use the pieces to start the fire,,
Snoopy is offline
Old 10-11-2009, 08:41 PM   #9
Tyrant Blaze
Good luck with the maiden, let us know how it goes
Chris
Cheapest place to get AR6100/AR6200 Rxs? gzsfrk General Electric Discussions 12 07-17-2008 10:50 PM
Spektrum Ar6200 celticflyer RC Radios, Transmitters, Receivers, Servos, gyros 13 07-07-2008 05:35 PM
TRADE: NIP AR6100 for AR6200 or AR7000 Liquidity Radio Equipment For Sale & WTB 2 04-01-2008 03:09 PM
Spektrum DSM2 AR6200 Aussie E-Flite RC Radios, Transmitters, Receivers, Servos, gyros 6 01-28-2008 02:19 PM
Spektrum AR6200 RX rz22g Radio Equipment For Sale & WTB 0 01-27-2008 03:16 AM
Page generated in 0.09089 seconds with 35 queries
