Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Power - Batteries, Chargers, ESCs and More > Brushless Motor Construction
Brushless Motor Construction Discuss design and construction of custom Brushless motors
Old 05-18-2008, 07:01 AM   #1
AeroJim
Default Test Stand
Hi Guys,
I need to build a test stand for testing/rating props. It needs to run them at up to 7500 RPM and I will be measuring static thrust vs. power input. The current requirement is for testing 16x14 props, but I may need to do other sizes eventually. I'm thinking a large brushless airplane motor (2HP or so) might work. The stand will be stationary, so there will be only propwash for cooling and, to make things worse, there will be a 4 inch prop spinner and motor fairing to minimise turbulance. I can add cooling fins to the fairing if needed, and some vents for the motor, but it won't see anything like the airflow you'd have in flight.
Being a lab set-up, I don't have the usual power and weight limitations as on a plane. I just need to find an efficient motor setup that can spin the prop up to that RPM more or less continuously without smoke.
Is this even realistic, or should I be looking at another type of motor? I found some long-skinny DC servomotors that would fit behind the spinner, but they're big-$$ and it's hard to find one that will do that kind of RPM without gearing. Any advice?
Thanks!
Jim
AeroJim is offline
Old 05-18-2008, 08:58 AM   #2
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Club: www.rmvc-cumulus.nl
Several test stand designs, ranging from simple&cheap to elaborate&$$$/€€€
http://www.rcgroups.com/forums/showthread.php?t=386175
Several e-flight calculators:
http://www.rcgroups.com/forums/showthread.php?t=606703
Vriendelijke groeten Ron
ron_van_sommeren is offline
Old 05-18-2008, 02:59 PM   #3
Dr Kiwi
Outstanding Contributor Award
I'd look at Neu Motors - Steve has several motors capable of 1000's of watts.
Dr Kiwi is offline
Old 05-18-2008, 07:24 PM   #4
AeroJim
Default Test Stand
Wow, thanks for the links. It'll take some time to digest, but looks like a lot of good info.
Jim
AeroJim is offline
Helicopter flight training gear and test stand helisafeproducts New Product Announcements 11 09-24-2010 07:57 PM
Electric Heli Training and Test Stand helisafeproducts Helicopters- Electric For Sale & WTB 24 06-22-2008 04:53 AM
Castle Creations doesn't stand up to the test. RSS Feed RCU RSS Feed 1 01-16-2007 06:23 PM
Test Stand tashley Power Systems 19 12-11-2005 11:17 AM
details on building a motor test stand? magfluxman Power Systems 8 08-25-2005 10:22 AM
Page generated in 0.05800 seconds with 25 queries
