Old 06-16-2008, 09:17 PM   #1
jayxer
Default SuperCub to Tri Pacer help
I'm looking at buying all the parts of a Super Cub, but modifying it to be a Piper Tri Pacer. Going to be giving it to my father as a gift, his dad had a red and white Tri Pacer a long time ago. My main concern is the CG of the plane as it is stock, to where it will be when a steerable nose gear is added. Any suggestions?
Going to get my dad into RC flight finally, he's always been into anything RC, does the car thing but I'm tired of him watching me fly all the time. So I'm going to teach him on my super cub, so if he crashes, no big deal! Then when I'm finished with the Tri Pacer, he should be good enough to handle it, and eventually we'll ad ailerons to it.
jayxer is offline
Old 06-16-2008, 09:27 PM   #2
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
View SkunkyMagoo's Gallery11
Send a message via AIM to SkunkyMagoo
The CG of the airframe will remain the same. You will need to add weight to either side to balance the plane on the CG with all of the new hardware and weight up front.
TX | JR x9303
RW's | Vibe Fitty - Blade mSR
FW's | 64mm EDF Mirage 2000 - 64mm EDF F-5E Swiss Tiger
SkunkyMagoo is offline
Old 06-16-2008, 09:43 PM   #3
WingingIt74
WingingIt74's Avatar
Funny that you mention that. I've been contemplating about making a Cessna 172 look like my grandpa's old plane. Although, would like to find a Bonanza A-36 to do as well.
The Tri-Pacer would also have the main Gear moved back a little. I met a WW2 pilot at an airshow once. He had one and called it Molly Milk Bucket, as it sat very similar to a 3 legged milk bucket stool.
WingingIt74 is offline
Old 06-17-2008, 04:22 AM   #4
dk_aero
dk_aero's Avatar
View dk_aero's Gallery3
I'd been thinking of the same with my SC... Gotta love that Tri-Pacer!
As previously stated, CG will remain the same... How the CG will be affected by moving the mains back behind the struts and the addition of the nose wheel remains unknown.
"Always remember you're unique...Just like everyone else."
AMA 903496
dk_aero is offline
Old 06-17-2008, 09:44 PM   #5
wingspann
Certified Codger
wingspann's Avatar
View wingspann's Gallery5
I don't know how 'scale' you wanted to make it, but the Super Cub is a 2-place tandem plane. The Tri-Pacer is a 4-place. That means the Tri-Pacer fuselage is going to be wider than the Cub. The T-P also has shorter wings and fuselage than the Cub. Note also that the gear on the T-P is not just moved back a little, it's actually reversed. If you can find a Piper Pacer kit, then it would be the right proportions at least, and you could convert it to tricycle.
Good luck!
John
wingspann is offline
Tags
pacer , supercub , tri
Ford Tri-Motor macmaps Scale E-Powered Aircraft 19 06-05-2016 01:17 PM
Tri-prop vs regular? Firestem4 Power Systems 5 07-24-2008 01:12 AM
Tri-blade rotorhead? rcheli82 General RC E-Heli Talk 14 09-25-2007 06:29 PM
Piper Tri-Pacer plan. rebell Scale E-Powered Aircraft 0 12-31-2005 07:06 AM
tri plane big daddy Beginners 10 10-26-2005 05:47 PM
Page generated in 0.11829 seconds with 30 queries
