| Foamies Talk about building, power setups and anything having to do with e-powered foamy planes! |
#1 | ||
Anyone know where I can get the hardware, a recked model, OR a cheap model (NIB)? Thanks, Vic |
Vic - WebMaster iFLYrc
http://iflyrc.hypermart.net |
#2 | ||
Flight Junkie
I looked my Furious over and it appears that the hardware is just ordinary stuff that you can get from Dubro and others. Pretty straight forward...control horns, pushrods, easy connectors, etc. And unless you're flying off pavement, you won't need or want landing gear.
The Furious flies just like a profile foamy, better actually, because the full fuse stiffens it. So to launch, just hold it out in front of you, point it at the sky, goose the throttle and let it go. Thrills and chills! I think you'll love it. |
It's easy to be wise. Just think of something stupid to say and then don't say it.
#3 | ||
Club: NWEF.ORG
Friends: (31)
Tower has discontinued this model for good reason, Ultrafly discontinued many of there planes over a year ago. Theres nothing special included in the kit your missing that cant be found in most hobby stores. As noted above ditch the landing gear and it flies better all around.
#4 | ||
Flight Junkie
Vic,
When Kosh says Tower discontinued it for good reason, it's because Ultrafly quit manufacturing it. It's not because something was "wrong" with the plane. As with most model planes, when sales start to drop off the manufacturer pulls it and releases something else. The Furious was a great flyer. You're lucky you got your hands on one. There are a lot of discontinued planes that I pine for. Believe me, you'll like the Furious. It's a good'n. Peace, Bud |
#5 | ||
Originally Posted by Ribcracker
I guy on another board had one for sale - NIB complete kit for $29. I got it!
#6 | ||
aint crashin aint flyin
Club: AMA
Friends: (12)
I am going to get one this weekend from hobby people. they are $42, they still have it. I will use a 480 outrunner for it. does this plane fly stable, or anything?
#7 | ||
Club: NWEF.ORG
Friends: (31)
I'm afraid your going to be severely disappointed if you add that motor combo to the plane. Its just not the type plane were bigger is better, The flat 3mm wings flex under the all up weight of 10 ounces that the plane was designed for. Your setup would be closer to 20 ounces and make it a flying brick that limits what the plane can do. A smaller motor and battery is key to making this a fun all around plane.
#8 | ||
Club: Leek and Moorlands Model Gliding Association.
Benovisoff,
I have one of these too and I have carried out some basic mods to stiffen up the airframe. I have added 3mm x 1mm carbon strip to L/E & T/E of upper and lower wings, 1mm dia. carbon rod to brace the upper surface of the tailplaine to the rudder, and 1mm dia carbon rod cross bracing between the interplane strutts and the fuselage. The braces are glued to each otherb where they cross over and this is vital to increase the rigidity. This has stiffened up the structure to such a point that I can now do WOT snap rolls without the plane re-kitting itself! My motor set up is an E-Pr0 2828-28 (1048Kv). This motor weighs 43g, turns a 9"x 4.7" APCe prop, draws 13.5 Amps (static) and has 145 Watts on a ThunderPower 1320mAh 3s LiPo. I use the supplied stick mount with a GWS plastic motor mount and with this motor the plane will go vertical OOS at hell of a rate! This bipe is a great fun plane and mine is over a year old and still going strong. I have another, NIB up my attic, and that cost a mere £12 (about $18) because of stock clearance, what a bargain, how could I resist! I can post pics of the mods I did if needed. P.S. I also strengthened the interplane struts with 3mm x 0.5mm carbon strip. I simply cut the struts in half (length ways) and used UHU Por to bond the pieces together. |
The original Dead-Stick Dummy!
#9 | ||
Club: AMA
Friends: (12)
hmmm.... intersting. I do I have little motor from hobby city, but it might be just a little under powered. I could take that other one off your hands maybe
I could use that with a 1300mah lipo from heads up, all I'm missing is a 20 amp esc. I might be looking at the little bigger ViVo, because it is twice the weight and size and may take a 480. If you are willing to part with it, being the outrage or furios, pm me. Also if any one has a 18-22 amp esc that can handle it too. All the little escs are bought out here and the only ones they are left on this site are 70ampers. The motor I have was 6 bucks, its the little pink and metallic one, 1060 outrunner. If you would look it up and tell me if it willl work I would be much obliged.
| Tags |
| furious , ultrafly |
| Ultrafly Furious 3D help | Phrozius | Foamies | 9 | 01-21-2009 05:16 AM |
| Need Advice on some good 3D powerplant setups for 10oz 3D planes | GreenAce92 | 3D Flying | 25 | 08-19-2008 11:59 PM |
| Night Ranger 3D or NR 3D micro? | Chad | Micro Sized Electric Helicopters | 17 | 04-04-2008 06:50 PM |
| Ultrafly Furious Biplane $21.99 | Kosh | 3D Flying | 6 | 04-25-2007 02:39 AM |
| Align Electric 3D Contest plus 3D Invitational, Taiwan | steph280 | Events, Shows and Fun Fly's - Electric Airplanes | 0 | 08-03-2005 07:14 PM |
