| Delta & Flying Wings Discuss electric powered delta (flying wing) style aircraft here. |
#1 | ||
Club: C.D.P.A.
Power system: Dons Wicked 2700 Heads Up Rc 60amp ESC w/Bec BMS 380 Mg Servos Zippy 11.1v 2200mah 20c Lipo DX6 w/ Ar6000 MODS Done: Carbon Fiber added to wings for reinforcement (Epoxied in). Very light coat of spray paint. Cut off the fake intakes. Added 2 magnets to the nose for mounting. Now to the problem... She rolls RIGHT. The faster she goes, the more roll. Now, had it been left, I'd think torque, but it's rolling right... HARD RIGHT. WOT is not an option since the roll is very bad at WOT. I about lost it the first time I went from 50% to WOT. I've trimmed her at 50% and it flies straight and level. Over 50%, the roll is insane. I've trimmed the radio to it's max with little to no effect. I've gone over all surfaces very carefully and cannot find anything at all wrong. I've adjusted the surfaces and even used a ruler to check that they are the same measurement. I've checked the side to side balance, and added 2 small nails in the left wing tip to ensure that the plane's wings are balanced. At the suggestion of Newjak, I checked the thrust angle and made some adjustments in case the thrust angle was incorrect. Did not work. I've shimmed the motor in both directions to change the thrust angle and the roll was the same. I can not "see" anything that would cause the roll. IDEAS? I'm at a loss. |
#2 | ||
Megans Servant
Club: Maggie Mae's Menagerie
Had the same problem with my second build. I think it's just luck of the draw when a bad fuse with just a slight twist makes it out of the factory. Of course then they have them on display in the bags standing on edge so that may help develop the twist sometimes.
All I did was adjust the clevis a bit on the elevon to the right, setting it just a little lower than the left side. Helped out quite a bit but on occasion if I Wasn't paying attention the plane would try to surprise me. Kind of a basic fix but it worked for me. |
Cheesy poofs are what Yankees get when they eat Southen Food!!
bub, steve
#3 | ||
Club: C.D.P.A.
Tom, I'll give that a try, however, wouldn't the trim be off to the left below 50%? I've looked at the wing and she appears straight. This is driving me nuts. There looks like there is a slight undercamber to the tip of the left wing. About 4" in from tip. Do you think that maybe this is pushing the left wing up? If so, how in the heck do I correct that?
#4 | ||
Club: C.D.P.A.
Press between a couple of books maybe?
#5 | ||
Megans Servant
Well some folks have taken a heat gun on low setting and had some success bending foam. I've only tried it once and even on low settings I've had foam show it's displeasure at getting warmed up too much.
I don't think the trim should be off under the 50% after adjusting the elevon, because like it is now, the airspeed/wind over the control surfaces is much less so it shouldn't affect them like it does when you take it to 100%. You'll be surprised how little you have to adjust the elevon to trim it out anyway. |
bub, steve
#6 | ||
Friends: (40)
Hey TS, not to hijack your thread, but how do you hook up the servos to the Rx and get them to activate elevator and ailerons in the Delta Wing mode? I did what the manual says, but elevator input activates the servos as ailerons and the aileron input activates them as elevator...like the channels are reversed. Any ideas friend? Sorry to go off topic.
Mike |
#7 | ||
Friends: (281)
Originally Posted by totalsnafu
try mixing a little epoxy and lite weight spackle together, and fill the undercamber, use a flexable straight edge to get the spackle and epoxy/filler smooth with, Like doing body work , with bondo
Hope that helps, Chellie
#8 | ||
Breaking wind.
Club: RCG Shady Flyers
Friends: (22)
Originally Posted by Angler-Hi
That's really is unusual. IF you switch left for right channels on the RX you only reverse the ailerons. Elevator stays the same. If while you have the the channels plugged in wrong and you reverse them on the radio, elevator will reverse and your ailerons will be corrected. Once you correct your RX input you can correct your ailerons/elev. settings.
What you describe sounds like a radio issue. Some radios allow you to switch stick assignment. What radio do you have? |
Dan
------- "Stop screw'in around! ! Ya'll screw around way to Much!! ! bub, steve"
#9 | ||
Breaking wind.
Friends: (22)
Maybe is force related. More speed you have more something misshapes. Maybe one of your reinforcements isn't as solid as you think. Instead of holding it still it allows one wing to twist at speed?
Vertical not straight? Causing a pronounced turn at speed? Just throwing ideas at you. I have no real clue.
Dan
#10 | ||
Super Awesome
I would have to believe you need to adjust one of the elevons, if the problem is more pronounced at speed all that means is the little bit of pull is amplified the faster you travel. This should be something easy to fix and the problem is probally something simpler then you think.
I have seen strykers bent from smashing the earth at WOT that still could track correctly. IMO i would start be centering the trim and then adjusting the control arms to center; start there. |
4-27-2006 Stryker B
6-05-2006 PKZ FW190 Brushless 8-25-2006 Stryker C 9-27-2006 Typhoon 3D 3-28-2007 PKZ Spitfire Brushless 4-28-2007 FunJet 9-06-2007 Kyosho F-16 10-21-2007 Phase3 F-16 |
#11 | ||
Friends: (40)
Thanks PK. I'm just a moron...everything was working like it was supposed to. I just forgot that when looking at the servos side by side, that they were supposed to move the same way. I'm a dork! BTW, I'm using my DX7.
#12 | ||
Breaking wind.
Friends: (22)
Funny ... I was setting up my radio for my Stryker, switching servo slots on RX (couldn't remember which went where), reversing servos and thought I had it all figured out. Trimming everything out and I run out of trim. I couldn't level the flaps. What the ....? All of a sudden I'm looking at the flaps again and they are reversed? Damn ..I have to set it up all again ...this time correctly. Trim problem solved too.
Dan
#14 | ||
Club: C.D.P.A.
Thanks for the responses. I've looked at everything. I will adjust the elevon again to see what I come up with. It's annoying the heck out of me. I think that Tom may be correct and that I have a fuse with a slight twist in it. The tails are perfectly square, so that's been eliminated. Elevons are dead even (as measured with a ruler), and thrust has been ruled out since I have adjusted the motor (shimmed) in both directions and still have a problem. There is extremely little flex in the wing. I can hold it by one edge and it moves very little.
I'm going to adjust the left elevon up a few turns to see if I can counter the right roll. I'm just worried about the thing wanting to turn left at slow speed. I'm also creating more drag, which is a bummer on a Stryker. I appreciate the assistance. "Thanks Button" is a good thing. |
#15 | ||
Breaking wind.
Friends: (22)
TS...post some photos up. Top, bottom, left and right sides, front and back. Just curious.
Dan
#16 | ||
Club: C.D.P.A.
#17 | ||
Megans Servant
You'll be surprised at how little you have to move the elevon to trim it out for high speed. You probably won't notice any change at the slower speeds. Good luck
bub, steve
#18 | ||
Club: C.D.P.A.
Adjusted the Elevon last night. She stays fairly level at high speed (a little drift but trimable) but now she turns left a slow speeds. I think that I'm screwed either way.
#19 | ||
Kamikaze Ace
Couple of things that may help. Very hot water, will allow you to straighten out the one wing that's off. Run the wing under hot water while twisting out the bad section, go a little past where it should be. Hold the wing until it cools, or switch to cold water to speed it up. Repeat as needed.
Other and I would only do this as a last resort. If your tx has the capabilities, you can mix the elevons to throttle position. I used to do this to combat the climb the Stryker want's to make as you accelerate. On mine I mixed the elevons to throttle to drop the elevons in relation to throttle position. You could do the same, making a left up right down elevon mix to the throttle to combat the roll condition. |
#20 | ||
AMA Park Pilot Partner
Club: Central Delaware Parkflyers Association
Friends: (13)
Don't give up the ship just yet. How about trying a programmable mix on your DX6? I've never done it, but it might be worth trying.
A.M.A Park Pilot Partner / Wattflyer Mentor
#21 | ||
Club: C.D.P.A.
I'm going to try the mixing solution... just no clue how to do it on the DX6.
#22 | ||
Super Awesome
i was thinking about this problem today, have you checked the vert fins?
4-27-2006 Stryker B
#23 | ||
Breaking wind.
Friends: (22)
Geez all this trouble for a $20 fuse......buy another and rip your stuff out. Even with all the radio "repairs" it's just not going to fly right. If you can't fix the fuse then you'll never be really happy with it.
Anyway thats how my frustration would deal with it. ![]() Really sucks you got a bad fuse. |
Dan
#24 | ||
Club: C.D.P.A.
The vert fins are perfectly squared. I checked them. I have honestly left it be for the last week before I get mad and trash it. A wise flyer told me to walk away, regroup, reassess, and retry. So, I've been working on another project.
| Tags |
| problem , rolls , stryker |
| new stryker c problem | MARKZR7 | Delta & Flying Wings | 6 | 08-07-2008 03:02 AM |
| F-27C Stryker Problem with Controller Settings | HillsFlyer | Delta & Flying Wings | 5 | 04-27-2008 03:01 AM |
| taileron rolls | rickmartinez | Electric Ducted Fan Jets | 1 | 12-18-2007 06:37 AM |
| Problem with motor on F27-C Stryker | wattflyer6161 | Electric Ducted Fan Jets | 6 | 12-14-2007 04:08 AM |
| Stock stryker rolls and loops | jcblough | Delta & Flying Wings | 9 | 06-12-2006 01:46 AM |
