#76 | ||
![]() Happy flying! |
#77 | ||
Formerly Maddux99
Club: Paducah AeroModelers Club
Hello everyone, first post! My first plane was also a Nexstar Select nitro plane. I still consider it to be my first plane as I have not solo'ed it yet. I have flown in about 4 times on a buddy box but did not feel ready to try a full solo yet. I have now stored that plane for a while and have been flying the sport trainer foamie (built several actually
) from mikeysrc. It is a 3 channel Aileron, elevator, throttle plane. Scratch building has been a whole 'nother thing to learn but it ahs been fun and I have learned alot about flight characteristics and plane setup during the experience. I have not flown anything without ailerons so I can't say if I would be any better without them.
#78 | ||
Friends: (8)
The question posed by this thread only applies to pilots who are trying to learn on their own. If you have an instructor, and will be flying on a buddy box, it doesn't matter if you start with ailerons or not.
You are ready for ailerons, as a self trainer, when you can fly your current R/E plane reliably, where crashing is a rare event, and you can easily handle flying toward yourself. The following may help people understand this whole aileron vs. rudder thing. As it is not really about ailerons, but about the design of the aircraft. Ailerons vs. Rudder Designs Which is better for new pilots? by Ed Anderson aeajr on the forums The question of ailerons vs. rudder only models, as a preferred design for new pilots, comes up all the time. People mistakenly focus on the control surfaces, but the real question or issue is the dihedral of the wing and the wing's placement relative to the fuselage. Let's discuss this and try to help clear up the question. First, let me say that if you are working with an instructor, it makes no difference whether your plane has ailerons or not. Your instructor will help you learn the function of the surfaces and how to manage the plane in the air. This is especially true if you will be training on a buddy box. So, follow your instructor's advice as to what plane or what kind of plane to get. As long as you are only going to fly under the supervision of an instructor, it makes no difference. Follow their lead. But what if you plan to try to learn to fly by yourself? Or maybe you will have a little help from a friend but will be doing most of your learning on your own. NOW it makes a difference. There is no law of nature that says you can't learn to fly on a plane with ailerons. Lots of people do it. But the R/E only planes seem to provide an easier starter set-up for new self-trainers. Let's see why this is true. Elements of a good first plane for a self training pilot. High Wing. - Having the wing located on top of the fuselage places the weight of the fuselage below the lifting surface. The plane will tend to want to fly with that weight below the lifting wing, so the plane will want to remain stable and have less tendency to roll on its own. So high wing is best for new pilots. Low wing designs tend to roll very easily so they are much less self leveling. They are very happy to go inverted, bad for a self trainer. High Dihedral - The angle of the wing as it extends away from the fuselage is called the dihedral angle. In some planes the wing may have several angles. These are called polyhedral wings. In some planes the wing will come out flat from the fuselage having little or no dihedral angle. The more dihedral angle in the wing, the more stable the plane will be as the wing will want to level itself naturally. The flatter the wing, the less stable the plane will be and the less self leveling. Because a flat wing is much less stable it is the preferred design for aerobatic planes. And since a flat wing plane will not tend to self level, the pilot has to do it or the plane will likely fall out of the sky. A flat wing plane requires the pilot to be much more skilled and attentive. So a good self trainer, both in models and full scale planes, will have a high wing with a lot of dihedral. In many cases, if you let go of the sticks, this design will right itself and return to level flight if it has enough time and altitude. Again a good design for new pilots who are trying to learn to fly on their own. Rolling the plane - direct vs. indirect In order to turn an airplane we roll the wings so that we redirect the lift into the direction of the turn. If we did not roll the plane it would tend to skid sideways. Ailerons - Ailerons roll the wings directly by changing the shape of the wing which modifies its lift characteristics. We tend to put the ailerons on the outer section of the wing so we get the most effect from the smallest deflection which reduces drag. The outside aileron goes down, generating more lift. The inside goes up generating less lift, and the wing rotates. ![]() But if you put ailerons on a high dihedral wing, the aileron is no longer flat out from the fuselage, it is at more of an angle. The higher the angle the more the aileron starts to look like a rudder. So ailerons on the outer apsect of a high dihedral wing will generate more and more of what is called, " adverse yaw" which means that they will try to pull the plane away from the turn. Rudder - If you apply rudder to a high dihedral wing plane, the rudder will swing the tail around. This presents the bottom of the leading wing and the top of the trailing wing to the oncoming air. This causes the wing to roll and allows you to turn the plane. It is this coupling of yaw and dihedral that allows a rudder only plane to turn. Once you realize this you see that you can not efficiently turn a flat wing airplane with rudder only, you need ailerons. But if you have high dihedral wings, you can do it with rudder alone. Putting it all together So, if you are a new pilot who will be training on your own, you would likely want a plane that is designed to be very stable and very self leveling in order to have the plane help you get out of trouble. A high wing, high dihedral wing design will do this best. This is the design of most rudder only or rudder/elevator airplanes. That is why many people will recommend these planes as the preferred design for new self training pilots. This is also why taking a plane designed for ailerons and disabling the ailerons is not the same as having a plane designed for rudder alone. Compromise designs Now, some planes have a compromise design. Planes like the GWS e-starter are high wing high dihedral designs. They also have ailerons. GWS has created a compromise wing that is not really the best at rudder only or the best at ailerons, but is OK with either use. The Multiplex Easy Glider is another example. There is enough dihedral in the wing that you can turn it with the rudder, but response will be sluggish. The plane has aileorns, but in order to minimize the adverse yaw effect they are placed in the center of the wing. This makes them less effective than ailerons on the outer part of the wing, but since this is a glider, not an aerobat, this compromise works pretty well. There are other planes that make a similar design compromise. However remember that disabling the ailerons does not make the plane more stable or more self leveling. It just means you have one less control surface to worry about. Disabling the ailerons on a plane that is designed to fly with ailerons will likley result in a plane that flies poorly and that is never our goal. |
#79 | ||
Formerly Maddux99
Thank you AEAJR for that information it was very helpful. I guess I was a bit brief in that last post. I started with an instructor but due to work restrictions and a long drive to the field I have been trying to teach myself with electric foamies. The learning curve has been slow but I feel gratified with what I have learned so far, having learned it for myself. Much of it was learned right here in this forum. I have been thinking about getting a 3 channel plane without ailerons like the multiplex easystar to see if I do any better with it.
#80 | ||
I wished I had foamies back then. They are indestructible so it does not matter how many channels the plane has. You fly more you learn fast.
I crashed at least three "balsa" trainers, one (red) "Stik", one Pete n' Poke... I learned very slowly because I was too afraid of crashing. Preparing a gas flight was a pain too. Well some people like to do the "pre-flight" stuff, but other people just like to fly, like me. |
#81 | ||
Friends: (8)
Originally Posted by NickMcEnjoy
Did you crash these planes while using a buddy box with an instructor? The buddy box is the appropriate way to learn to fly a glow plane as they tend to be larger, faster and heavier than the typical small electric used for self training. You may not have known that at the time.
Preflight stuff is required for all pilots flying any kind of aircraft, fuel or electric. Preflights for electrics may be different and perhaps simpler, but they still have to be done. If you don't want to do proper preflights then you should not be flying as you represent a danger to yourself and those around you. |
#82 | ||
Hello!
No. I crashed them after several solos. I already "graduated" and my mentor let me solo. First time when I flew with my mentor, he asked whether I already flew before because my maneuvers were good. I crashed them because I was so scared of losing. That led to mistakes. Btw, I have never seen anyone crashed anything while using a buddy box with an instructor.
Originally Posted by AEAJR
Yeah I knew that
I did not say that I don't want to do proper preflights. I always do preflight checks and I believe I did them properly. I just don't like them. I also don't like to go to school. School sucks. But I must go to school because it helps my bottom line
I have done quite well in school, although I always hate it
#83 | ||
One hitch AE1 -- USN
Re; "flat wing" difficulties. Do you know the Lazy Bee and now Stevens Aero "Sky Buggy"? The Sky Buggy has R/E only. I am NOT an experienced pilot, (I have'nt completed build yet), but will this plane give me fits? and what should I watch out for ?
#84 | ||
Club: Mullet Mauroders
Friends: (86)
Originally Posted by Flywhat2
Keep it light as you can, she's got a fat wing chord (lots of lift) , and she's a easy plane to fly from what i've read check'in around for this post, , and look's to be a good trainer as long as you don't try her in any wind,,(that'll come later ), what are you going to fly her on?? motor, esc, batt, Etc, bubstevePS keep the control surface throws LOW as she's got a short Fuse !!bubsteve
Monkey Minion'air
#85 | ||
Steve, Thanks for tips. I am going to (try) to fly on:
BL 2208-14 outrunner (1450kv,130 W, 16 amps max), 9x4.7 Slo-fly prop, T'bird 18 amp ESC by Castle, AR 6110 Rcvr E-flite 800 mah 2s LiPo, HS55 servos. Think that'll do it? I will set control surf throws at min on control horns and rate at low on DX5e radio. Is that too conservative? Thanks much,Fly
#86 | ||
ailerons aree neat
#87 | ||
Glad to see this board has so many helpful and knowledgeable members willing to explain things in detail.
#88 | ||
Friends: (7)
You are ready for ailerons if you fly a plane with ailerons and succeed!
![]() As a practical matter if you have an instructor and a buddy box or an instructor that has a method of easily assuming control of the plane you can confidently start out with ailerons from the beginning. If you're on your own, you need to feel absolutely comfortable flying your three channel plane. You know when your predominate feeling goes from "don't crash, don't crash" to "wow, this is fun, wow, this is fun." When you've turned that corner and crash rarely and know exactly what you did wrong if you do crash, you're ready for the next step: ailerons. But you REALLY only know if you're ready if you try it and succeed!
#89 | ||
Originally Posted by Balil
That's pretty much what I did. I just wanted to fly. I bought a HZ Super cub to get my feet wet, next day I picked up a hf p51 and a PZ f4u Corsair. I taught myself the do's and don'ts of a full control plane with the p51. I put the f4u together and haven't looked back. That was 6 days ago today. No simulator and no formal training, just the desire to fly. The p51 is petty beat up though but for 80 bucks I don't feel bad .
#90 | ||
speeddaddy
Hi everyone, just trying to get my 2 posts
#91 | ||
Friends: (7)
#92 | ||
What, me worry?
Club: A.M.A. Member, not currently affliliated with a club
I have to agree with what was said earlier about those P47s. Not accounting for the nearly non-existant weight, the little 400mm one I have is a BEAR to fly. Would most likely fly a lot better in the calm, but days like that here are few and far between. However, with that said, I have flown the micro several times in the wind with positive results, so I'm thinking the much larger version I've got (Airfield/FMS pictured at left) should be a lot more forgiving, AND it's got flaps (6 CH.) to slow it down for landings. I can't imagine flying a plane without ailerons...
R.C. Hobby is a hole into which one dumps money.
| Ailerons | meddyliol | Beginners | 2 | 09-10-2008 10:16 AM |
| Flying with Ailerons | DelawareDon | Beginners | 11 | 05-13-2008 06:56 PM |
| First flight w/ailerons | meesier42 | Beginners | 17 | 02-06-2008 04:23 AM |
| need help with ailerons | Brandon16166 | General Electric Discussions | 5 | 01-20-2008 05:12 AM |
| Rudder vs. Ailerons | Ribcracker | Hi-Performance and Sailplanes | 26 | 08-16-2006 05:55 AM |
