Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > Maxamps discussion
Maxamps discussion Welcome to the Maxamps.com support forum
Old 07-26-2008, 02:44 PM   #1
JAM MaxAmps
JAM MaxAmps's Avatar
Exclamation The ROAR Approved MaxAmps 35C 4200 pack is here!!!!!!!!
<TABLE width="100%"><TBODY><TR><TD width="90%">Alert - The ROAR Approved MaxAmps 35C 4200 pack is here!!!!!!!!
</TD><TD align=right width="10%"><!-- End of show warned sign --></TD></TR></TBODY></TABLE>
<HR style="COLOR: #a7a7a7" SIZE=1><!-- message -->MaxAmps 35C 4200SS 7.4V Pack
MaxAmps.com presents the ultimate “Sanction Spec” racing pack that has been approved by ROAR. As you racers know, the most important factor for your batteries is voltage under load. This pack boasts a 35C constant rating for all your amp hungry racing setups. It will maintain higher voltage under load than any other pack on the market.
In addition, it comes with your choice of “leaded and unleaded”. The leaded option offers 6 ounces of additional weight added to the bottom of the pack. This allows racers to keep their current NIMH setups without throwing off the balance of your setup or having to add weight to make weight requirements.
• 35C Constant Discharge(147amps)
• Hard Outer Case
• 139mm x 47mm x 25.1mm
• 7.4 Volts
• 4200mah Capacity(plenty for racing)
• 8.8 ounces(unleaded) 14.8 ounces(leaded)
As with all MaxAmps packs, you choose your plug, tap, and wire options and your pack is built to order within 24-48 hours of placing your order on the website at www.MaxAmps.com
See it here: http://www.maxamps.com/Lipo-4200SS-74.htm
Jason
MaxAmps.com
<!-- / message -->
Jason
MaxAmps Marketing Manager
jason@maxamps.com
www.NitroKillers.com
www.MaxAmps.com
JAM MaxAmps is offline
Tags
maxamps , roar approved li-po
MaxAmps Lipo 2500 11.1V Transmitter Flat Pack JAM MaxAmps Maxamps discussion 0 02-22-2008 04:24 PM
NEW 5s 4000 mah maxamps pack smurf Motors and Speed Controllers for sale & WTB 0 02-17-2008 07:48 PM
35C Fire Safe Li-Ion cell hoppy Batteries & Chargers 9 01-21-2006 02:56 AM
9S2P 4200mAh 15-20C Pack of MaxAmps LiPo's with TP balancing Plugs CustomPC Motors and Speed Controllers for sale & WTB 0 12-06-2005 11:04 PM
Page generated in 0.14913 seconds with 19 queries
