Old 09-18-2008, 12:14 AM   #1
View CHELLIE's Gallery13
Friends: (327)
Default WHATS a UBEC ? and Who Needs Them ?
Hi I have been asked this Question a Lot, and a lot of people are unaware that a UBEC is needed is some applications, WHY I will try to explain why, and give some references, most ESC/ BECs are only rated for about 2 amps, on there BEC Battery, Eliminator, Circuit, the 2 amps is not a true rating, its less than that, If your using 3 to 4 servos, using Digital servos, using standard size servos, using a 4 cell lipo or bigger, you need to be using a UBEC Universal, Battery, Eliminator, Circuit or the BEC in the ESC will get over loaded and cause a Crash, its cheap Insurance to use a UBEC, here is some info from Heads Up Rc, that I found to be a great source of information, and from Castle Creations and others, hope this helps to explain why a UBEC is needed, we all want to protect our Investment in our Planes, I know I do hope this info helps, take care, Chellie.
http://www.headsuprc.com/servlet/the...-3-Amp-/Detail
Buss tie Circuit I really like this, you dont have to remove the red esc wire, its tied together with the ubec http://www.wattflyer.com/forums/showthread.php?t=73141
UBEC 3 Amp Universal Battery Elimination Circuit
3 Amp UBEC - Universal Battery Elimination Circuit
This3 amp Universal Battery Elimination Circuit (UBEC) is a 'switch mode' DC regulator that takes the high voltage (up to 23 volts) of the main battery pack and converts it to a consistant and safe 5 or 6 volts (selectable) for your receiver and servos. A UBEC is needed if the Electronic Speed Control (ESC) being used for the motor does not have a built in Battery Elimination Circuit (BEC), or if the BEC of the ESC is inadequate to power the number and/or size of servos being used.
Using a 3A UBEC is a safer way to go on large models for the following reasons:
1. Most built-in BEC circuits are 1 to 2 amp 'linear mode' circuits which are only useful for 2 or possibly 3 standard size servos when using a 3 cell Lipo battery. If you use more servos, or a higher voltage battery pack, you will almost certainly overload the BEC, causing a crashed model.
2. In an ESC with a built-in BEC, excessive heat generated in the ESC by the current draw of the motor and/or BEC can cause total loss of power to the receiver/servos, resulting in a crashed model. The chance of total loss of power is greatly reduced when a separate receiver battery pack or UBEC is used. If the ESC overheats and shuts down (no power to the motor), you will still have power to the receiver/servos, and will be able to maintain control of the model.
The UBEC is connected directly to the main battery pack of an electric model, the same as the ESC. In fact, the power input wires of the UBEC are often spliced into the power input wires of the ESC. The power output wires of the UBEC have a receiver connector on them, and this is usually plugged into any open channel of the receiver. If the ESC being used has a built in BEC, that BEC must be disabled when using a UBEC. To disable the BEC of an ESC, simply disconnect the red wire on the receiver plug of the ESC.
This 3A UBEC includes aferrite ring that is installed on the receiver wire for reducing interference.
3A UBEC Specifications:
Input Voltage: 5.5v to 23v
Output Voltage: 5v or 6v selectable by jumper pin
Continuous Current: 3 amps
Regulator type: Switching
Receiver Connector: Universal 'S' type
Interference Reduction: Ferrite Ring
Weight: 0.3 oz (9 grams)
Size: 1.7 x 0.6 x 0.25 inches
Old 09-18-2008, 12:16 AM   #2
Friends: (327)
and some more info
http://www.castlecreations.com/products/cc_bec.html
Products > CC BEC
CC BEC SWITCHING REGULATOR
Current Output:
Peak: 10 amps
Continuous:
<12 volts input = 7 amps*
<24 volts input = 5 amps**Ratings are determined with a 5mph airflow on the BEC. Servo connectors are not rated for current in excess of 5 amps. Users are encouraged to replace the connectors if more than 5 amp currents are anticipated.
Output Voltage:
Output 5.1 volts out of the package, user may set output voltage from 4.8 to 9 using the Castle Link (sold separately).
Input Voltage:
5v to 25.2v (2S to 6S LiPo)
Length:
Width:
Height:
1.2” (30mm)
0.6” (15mm)
0.4” (10mm)
Weight:
0.4 oz (11 grams)No small animals or interns were harmed in the incredibly long development of this product. Some engineers maybe, but that is a personal matter. They are fine now.
What the heck is a BEC?
Our Battery Eliminator Circuit is a little device that eliminates the need for a receiver and servo battery pack. It draws higher voltage from the motor batteries and drops it to a voltage level that is suitable for your receiver and servos. This is required in applications which draw high power for multiple servos or use more than 3S motor packs, as most ESCs with linear BECs are not designed for these applications.
CC BEC is better because it is smaller, cheaper, and far more powerful.
See the CC BEC User Guide or the CC BEC FAQ page for more details.
CC BEC retail price only $24.95
TOUGH ENOUGH!
How tough is the CC BEC? Ask John Robert Holmes, owner of Holmes Hobbies, known for rock crawlers. Crawler guys have yet to find a switching BEC that can stand up to their own unique punishment. John was truly impressed! "I wish I could have blown this sucker up, but so far I am not able to even get it to shut down from overheating." This video shows John testing CC BEC with 57 lbs. loaded up on his platform.
CC BEC Wiring Diagram
Click image for larger view
CC BEC Usage Advisories
CC BEC Usage Advisory #1:
Multiple CC BEC Setup
CC BEC Usage Advisory #2:
Testing Potentially Damaged CC BECs
CC BEC MULTI-PACK INSTALLATION
Click image for larger view Click here for a printable version (516k PDF)
CC BEC/SPEKTRUM Compatibility instructions
Castle has learned of a slight incompatibility of the CC BEC with the SPEKTRUM AR 6100, 6200, 7000, JR 790 ScanSelect, and JR 2100 ScanSelect Synthesized receivers. There is a very easy work around for our customers who already have the CC BEC and we are making modifications to the components of all new CC BECs that are built from Nov. 1, 2007, forward.
The simple explanation is that the CC BEC, like most Castle products, is designed to be USB linkable via the signal wire on the servo connector. As part of that, the CC BEC will pull the signal wire to ground unless it is sending a signal on that line. Nothing out of the ordinary with this. Similarly, the Spektrum team designed these receivers to look for a grounded signal pin on the battery port in order to initiate binding. Nothing strange there either. Castle does something similar with our Berg receivers. The problem is that the two designs result in the CC BEC triggering the receiver's binding mode immediately upon power up. We have redesigned the CC BEC to facilitate the USB activities without initiating the binding mode.
For those of you with the affected CC BECs and Spektrum receivers there are at least three solutions:
  1. <LI class=bodytext-whitetext>Remove the orange signal wire from the CC BEC RX power lead before you plug the lead into the battery port on the receiver. <LI class=bodytext-whitetext>Plug the entire/intact lead from the CC BEC into any other port on the receiver.
  2. Use a "Y" connector to plug the entire CC BEC lead into any port other than the BATT port on the receiver.
If you are unsatisfied with any of the above solutions, please simply send your CC BEC to Castle for upgrade.
Please note that this incompatibility will be immediately apparent. There are no known issues after the system is successfully powered up.
Thanks!
Team Castle
235 South Kansas Avenue, Olathe, Kansas 66061, USA
Old 09-18-2008, 12:29 AM   #3
Liquidity
Combat Vet
Liquidity's Avatar
View Liquidity's Gallery62
Club: Hodges Hobbies, RAA, and GAMA
WAA-08 Pilot  1kW  125mph Speed Demon
Friends: (26)
Dont forget the best BEC around. The Parkbec, sportbec and Very High Voltage BEC (VHBEC) by Dimension Engineering
"War is an ugly thing, but not the ugliest of things..." http://www.quotationspage.com/quote/27169.html
Liquidity is offline
Old 09-18-2008, 12:33 AM   #4
Friends: (327)
Thank you Liquidity for Chiming in please give a link to the Parkbec, thank You, Chellie
Old 09-18-2008, 12:48 AM   #5
Liquidity
Combat Vet
Liquidity's Avatar
Friends: (26)
Sorry Chellie, I did not mean to butt in I am just soo bored looking for conversation.
Here is the link to all the Dimension Engineering Products, including the BECs
http://www.dimensionengineering.com/
Old 09-18-2008, 01:13 AM   #6
View firemanbill's Gallery67
Club: Smoky Mountain Aero Club
Friends: (64)
I have a couple of these from Medusa Research and they perform very well also.
http://www.medusaproducts.com/BECs/BEC%20Main.htm
President - Smoky Mountain Aero Club, Sevierville Tennessee
Old 09-18-2008, 01:16 AM   #7
Gohmer
Banned
View Gohmer's Gallery28
Club: SMMAC / MARCEE / Duluth Superior RC
Smile UBEC
It is a poor substitute for a receiver battery and possible source of glitches if you are using 72mhz.
Gohmer is offline
Old 09-18-2008, 01:26 AM   #8
Liquidity
Combat Vet
Liquidity's Avatar
Friends: (26)
Poor sub? Hardly! A receiver battery is heavy, a bec is a few grams.
I see it as an alternative to a receiver pack, not a poor sub.
Old 09-18-2008, 01:27 AM   #9
Friends: (64)
Agreed. In a plane like my sons Diamante, and my Super Airliner it is a huge space and weight saver. In my 1/5th scale Waco I run a Rx pack since weight and space is not an issue
Old 09-18-2008, 02:54 AM   #10
Friends: (327)
Hi Liquidity Your not butting in you are helping to give Valuable information and insite to why a UBEC is needed in some applications, this helps to prevent problems and possible crashes, Please give your thoughts on the Subject and Others please do the Same, Pos or Neg input is Welcome on UBECs, that way everyone can come to their own Conclusion, This thread is ment to inform, and I know there are a lot of different Opinions, Thats OK, they are all Welcome, Take care, Chellie
Old 09-18-2008, 03:02 AM   #11
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (89)
Per Ms Chellies advice I run um on anything that uses more than three servos ( sence the not formentioned " In'see'dent"" with the monkey chopper) Thanks my Bub'ett!! your bub, steve
Name:	petty an red 571.jpg
Monkey Minion'air
stevecooper is offline
Old 09-18-2008, 03:06 AM   #12
Friends: (327)
Hi Gohmer UBECs have there place, in a smaller model, they work great, if a extra battery pack is to heavy, they could be a source of a glitch, if a person has a Cheapy receiver, I only use Berg Receivers for 72mhz, and never ever had a glitch with a berg receiver, they are almost like a 2.4, they will lock onto your transmitter, Great little receiver, and they are not expensive, about the same price as others, Thank you for Chiming in, Take care, Chellie
Old 10-13-2008, 03:33 AM   #13
vax6335
Crazy 'bout Bees
vax6335's Avatar
View vax6335's Gallery12
Club: Fort Wayne Flying Circuits
Send a message via AIM to vax6335 Send a message via MSN to vax6335 Send a message via Yahoo to vax6335
Globetrotter Pilot
Could one of these be used to run a 2 or 3 cell lipo as a Rx pack only? Would there be an advantage to doing that? Say, running a 2 or 3 cell 1500 lipo w/ a ubec as opposed to a normal 4.8v 1500 rx pack.
vax6335 is offline
Old 10-13-2008, 03:42 AM   #14
Friends: (327)
Sure they can thats what they are for, to take the load off of a ESC-BEC, normally a ESC-BEC is only about 2 amps if that, so its best to use a UBEC of higher amperage 3 to 4 amps, when using 4 servos, or digital servos, the advantage would be in using a lipo over a Ni Cad rx pack would be lite weight advantage, and possible more flying time, and you can use a larger lipo than a Ni Cad, and have the same weight , and more flying time, Hope that helps, Chellie
Old 10-13-2008, 03:47 AM   #15
vax6335
Crazy 'bout Bees
vax6335's Avatar
Globetrotter Pilot
I think I'll end up with one of these then. I'm about to put a .60 Corsair in the air (shhh, it's glow) and wanted to use a lipo for a rx pack.
vax6335 is offline
Old 10-13-2008, 04:52 AM   #16
Friends: (327)
that will work fine use the castel creation 10 amp UBEC, you will have enough amps for every thing you need, and it will last you a long time, Take care, Chellie
Old 10-13-2008, 05:02 AM   #17
Friends: (64)
that will work fine use the castel creation 10 amp esc, you will have enough amps for every thing you need, and it will last you a long time, Take care, Chellie
I think you mean the 10 amp BEC not ESC right???
Old 10-13-2008, 05:56 AM   #18
Friends: (327)
Yes, Silly me Thank you Bill for catching that Take care, Chellie
Old 10-13-2008, 03:07 PM   #19
pilotpete2
Pilotpete2
pilotpete2's Avatar
Hi Andy,
While there is certainly no problem using a 2S lipo with a UBEC. You may want to look into going with 2S A123 cells for your glow powered models, big advantage is they require no regulator, as long as the servos are rated for 6V (5 cell) operation. I fly glow and electric, my 5 cell Nicds are due for retirement at the end of the season, I plan on switching over, as I have two Cellpros with A123 capability.
Good luck,
Pete
"If the women don't find you handsome, they should at least find you handy"
Red Green
pilotpete2 is offline
Old 10-13-2008, 10:11 PM   #20
Friends: (327)
Originally Posted by pilotpete2 View Post
Hi Andy,
Good luck,
Pete
Hi Pete I like your Quote, it cute The A123 cells are Nice, if weight is not a problem, as the A123 cells weigh twice as much as a lipo, for the same given capacity, that is something to concider when using A123 cells, Take Care, Chellie
Old 10-14-2008, 01:23 AM   #21
pilotpete2
Pilotpete2
pilotpete2's Avatar
Hi Chellie,
I agree, A123 have a definite weight penalty for powering an electric model, I only would consider lipos for that.
On the other hand powering a radio system, particularly in a larger wet powered model is a nuther story, for my .60 to .90 sized glow powered models 1100mA is quite adequate, so that would only be 2 AA sized A123 cells (currently I'm using 5 cell nicds), in fact they would probably be a great alternative to a traditional 4 cell AAA pack for a non powered glider.
Regards,
Pete
Red Green
Old 10-20-2008, 05:18 AM   #22
Castor
Castor
Castor's Avatar
View Castor's Gallery25
Club: UnClub
Friends: (8)
Chellie Thanks for the information. I'm pretty sure i crashed my Mini Ultra Stick for this exact reason. I will be investing in a UBEC. You can count on it.
Thanks again
Castor is offline
Old 10-20-2008, 01:19 PM   #23
pburt1975
Hotel California
pburt1975's Avatar
View pburt1975's Gallery17
WAA-08 Pilot
Thanks Chellie, just save me a couple of crashes. I've got 2 planes on the bench now with 4 servos on them. The one I've been testing mostly the ESC was getting hot on, just sitting static with everything hooked up.
Is there anything special to hooking one up? just plug and play?
pburt1975 is offline
Old 08-21-2009, 08:03 PM   #24
aero_k
aero_k's Avatar
This thread is a bit old, but I wanted to clarify something.
I have planes with 4 or 5 servos, but they are all 9g micro servos. Do I need a UBEC in this case?
aero_k is offline
Old 08-21-2009, 08:20 PM   #25
Friends: (64)
Depends on your amp draw Aero. Normally 5 small ones should be ok. But if you are running them in a really high amp motor application an external BEC would be recommended.
For the average park flyer, no, you shouldn't need one.
Tags
ubec
ubec do I need one? windshadow Power Systems 9 07-13-2010 09:15 AM
Bec, Ubec, Kbec???? Micro_R/c.co.za Power Systems 6 08-31-2007 11:32 PM
ubec for hitec electron 6 tvhelidad General RC E-Heli Talk 2 08-28-2006 08:03 PM
Connecting a UBEC? k-vette Power Systems 6 05-28-2006 06:03 PM
Hooking Up A Ubec rcflyer7 General Electric Discussions 5 04-05-2006 01:45 PM
Page generated in 0.59715 seconds with 69 queries
