Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Combat
Combat Electric combat discussion in here.
Old 09-24-2008, 07:29 PM   #26
krysallen
krysallen's Avatar
I think I found the plans that I am going to use, here is the link to 3 different planes, all done up nice....just print and glue then cut ill post a thread when I start but that will probably be at least a week or two I think I am going to build the avenger!!
http://www.rcgroups.com/forums/attac...mentid=1425351
krysallen is offline
Old 09-24-2008, 08:03 PM   #27
gregore2992
Club RAGE Member
View gregore2992's Gallery25
Club: The "Unclub"
I have the foam cut out for a P-47 (thanks smokejohnson!) and I just printed and cut out the ME-109 linked to this thread. That ME-109 is cool! I'll build both and probably end up fitting out and flying the ME first.
Greg
gregore2992 is offline
Old 09-24-2008, 10:26 PM   #28
krysallen
krysallen's Avatar
has anyone ever used posterboard for these planes? it seems sturdier and easier to cut....let me know what you think, we have some 1/4 inch laying around the office
Old 09-24-2008, 10:50 PM   #29
tiger86
Stay on target
tiger86's Avatar
View tiger86's Gallery9
Club: Club RAGE
Haven't tried poster board but my hunch is that it might weigh more than FFF or Depron. Thanks for posting the link to those other warbird plans. I may just have to build a few of those in my spare time. Wait, spare time? What's that?!
tiger86 is offline
Old 09-24-2008, 11:02 PM   #30
smokejohnson
smokejohnson's Avatar
View smokejohnson's Gallery22
Club: Independent
Friends: (108)
Originally Posted by Buzzsaw View Post
Glad to see that you are getting some E-Combat going Smoker.
Buzzy-WW2Ecombat Flyers of Muncie IN.
Yep, looks like it's finally happening . Thanks for the encouragement Buzz.
I'll add them to the list, thanks Krys.
Greg
No problem Greg...let me know if you have any questions getting it put together.
I haven't tried a combat plane but I have built several planes from poster board. On the planes I built I removed the paper and my planes flew fine. Others tried leaving the paper on and their planes never flew right, the paper just adds too much weight. With the paper off the foam is probably not thick/tough enough for a combat plane. It could be worth a shot though .
smokejohnson is offline
Old 09-25-2008, 08:39 PM   #31
krysallen
krysallen's Avatar
are there any cheep 2.4ghz recievers out there? we only need 3 channels for these planes if we aren't using the rudder 4 channels max. so i was hoping that I wouldn't have to spend 50bucks on just the rx....
Old 09-25-2008, 08:42 PM   #32
crash_out
Misanthropic Member
crash_out's Avatar
View crash_out's Gallery2
Club: No club, I'm a renegade!!!
Send a message via MSN to crash_out Send a message via Yahoo to crash_out
WAA-08 Pilot  1kW
No such luck on that. I've got a lot of flying wings that it is a waste to put a 6 channel rx in, but since no one has a 3 or even 4 channel one, I'm stuck there. In fact, I just left most of those on 72mhz with my Berg 4's.
Man, wouldn't it be nice if Spektrum would make a 4 channel receiver for about 30 bucks?
-nick
TANSTAAFL!
crash_out is offline
Old 09-25-2008, 08:51 PM   #33
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (52)
Hey Krys,
You have to use the AR6000 receiver for your DX6. About the cheapest you can find them new is at www.lightflightrc.com. They are $47.95 delivered. Occasionally you'll see one used on e-bay or RCGroups for $35 - $40.
Tom
Grasshopper is offline
Old 09-25-2008, 09:33 PM   #34
krysallen
krysallen's Avatar
ARGHHHH! damn this nice Tx
Old 09-26-2008, 08:16 PM   #35
tiger86
Stay on target
tiger86's Avatar
Club: Club RAGE
Has anyone tried printing one of these tiled plans yet? I've printed a couple of them (P-51 & P-40) and they don't seem to fit together correctly? I've turned off the "fit to page" printing option and am also printing as borderless. However there appears to be about 1/8" missing when trying to piece them together. Any ideas?
tiger86 is offline
Old 09-26-2008, 10:25 PM   #36
krysallen
krysallen's Avatar
no, I havent tried the tiled one, my office has a plotter that does 34x44 so I use the full size
Old 09-26-2008, 10:34 PM   #37
smokejohnson
Club: Independent
Friends: (108)
I had the same issue, I gave up :o. I don't know but the solution could be here. http://www.wattflyer.com/forums/show...printed+foamie
Old 09-27-2008, 01:29 AM   #38
tiger86
Stay on target
tiger86's Avatar
Club: Club RAGE
Default Printing tips
Ok. I finally got some time to play around with Adobe Acrobat and my printer here at work (color laser). After some trial and error, I found that the following settings will work for the P-40, P-51 and Zero found on the rcgroups.com thread that krysallen posted. Here goes...
Once the print dialog window opens in Adobe Acrobat (options may vary by version):
1. Set Page Scaling to "Fit to Printable Area".
2. Disable the "Auto-Rotate and Center" option.
3. Click the "Properties" button.
4. On the printer properties page (options may vary by printer):
a. Click the "Paper" tab
b. Set Document Size to "Letter (8.5" x 11")"
b. Enable the "Zoom %" option.
c. Set zoom percentage to 90%.
d. Click OK.
5. I suggest printing only A COUPLE of the tiled sheets and check the fit.
6. If the the test pieces fit together well, print the rest of the pages.
7. Otherwise, go back into the printer properties and adjust the zoom %
Disclaimer: These print settings worked for me with my version of Adobe Acrobat and my particular printer. You may have to tweak or play around with your particular settings to achieve the desired results.
Bottomline, adjusting the Page Scaling and Zoom % seems to be the key.
The resulting wingspans on all 3 planes I mentioned above fell within the combat specs that James outlined in post #1.
Hope this helps!
tiger86 is offline
Old 09-28-2008, 11:00 PM   #39
smokejohnson
Club: Independent
Friends: (108)
So who's up for some combat next weekend??
Old 09-28-2008, 11:07 PM   #40
gfdengine204
gfdengine204's Avatar
View gfdengine204's Gallery6
Club: RC Dusters, AMA 3875, Sandwich, IL
Send a message via AIM to gfdengine204
Outstanding Contributor Award
Friends: (53)
Ooooohhhhhhh I wish I lived closer.........
- Kev
AMA 873921
RC Dusters Flying Club, AMA 3875, Sandwich, IL
Question with Boldness. Hold to the Truth. Speak without fear.
gfdengine204 is offline
Old 09-28-2008, 11:14 PM   #41
Buzzsaw
Buzzsaw
I wished I did to.
We did get 10 rounds in Saturday at our new flying field.
Buzzy
Buzzsaw is offline
Old 09-28-2008, 11:29 PM   #42
smokejohnson
Club: Independent
Friends: (108)
Kev hopefully you'll get your chance in November. Buzz unfortunately I don't think there's any hope for us flyin combat, I wish there was.
Here's a video of us flying combat at the unclub.
http://www.vimeo.com/1795624
Old 09-28-2008, 11:37 PM   #43
gfdengine204
Friends: (53)
Was Tom cheating? Who was flying after they lost their streamer?
- Kev
AMA 873921
Old 09-29-2008, 01:08 AM   #44
tiger86
Stay on target
tiger86's Avatar
Club: Club RAGE
In Tulsa?
tiger86 is offline
Old 09-29-2008, 02:09 AM   #45
smokejohnson
Club: Independent
Friends: (108)
Yeah Tulsa, I can't do Joplin next weekend. I have a family thing that I have to be at by 1:00 .
Old 09-29-2008, 10:38 PM   #46
smokejohnson
Club: Independent
Friends: (108)
How does October 18th work for everybody to meet in Joplin?
Old 09-29-2008, 10:58 PM   #47
gregore2992
Club RAGE Member
Club: The "Unclub"
I could probably do that. Tha wife's parents live there, so that makes it easier.
Old 09-29-2008, 11:45 PM   #48
smokejohnson
Club: Independent
Friends: (108)
Is your plane ready to fly some combat around here this weekend?
Old 09-30-2008, 06:23 AM   #49
tiger86
Stay on target
tiger86's Avatar
Club: Club RAGE
The 18th sounds good to me.
tiger86 is offline
Old 09-30-2008, 07:08 PM   #50
Grasshopper
Friends: (52)
James,
Are you wanting to fly at the University? Will the radio interference be a problem?
Tom
Tags
ecombat , tulsa
Good time in Tulsa - Maiden photos. Grasshopper General Electric Discussions 56 03-31-2011 09:05 AM
who is up for combat and where? Sethbriancollins Combat 16 08-04-2008 11:37 PM
Pictures from Heatwave in the Heartland - Tulsa Grasshopper Off Topic Chit Chat 22 07-31-2007 05:59 PM
what is combat? socal swimmer Beginners 8 08-04-2006 01:58 AM
Where's the combat flyers!? HermitRiver Combat 0 04-17-2006 11:15 PM
Page generated in 0.95648 seconds with 69 queries
