| Power Systems Talk about motors, ESC speed controllers, gear drives, propellers, power system simulators and all power system related topics |
#201 | ||
Friends: (281)
#202 | ||
Friends: (281)
putting the motor behind the firewall/motor mount should be better, because it should be stronger and IMHO will look better with a nice clean tight nosecone fit to the fuselage.
Also Welcome to Wattflyers DL8698 ![]() |
#203 | ||
Originally Posted by CHELLIE
Hi, Chellie
Yes, I have considered the power pod method The retractable pod looks a bit complicated to build. And a non retractable pod will probably not be good for thermalling with power off. That is why I chose the folding prop nose mounted method. Not sure how well the DG1000 model thermals although it is based on a full sized glider which I'm sure thermals well, with its high aspect ratio wings. |
#204 | ||
Friends: (281)
Originally Posted by DL8698
Hi
I found this thread on converting a large glider to E Power, hope it helps, Take care and have fun, Chelliehttp://www.rcuniverse.com/forum/m_82...tm.htm#8237737 |
#205 | ||
Friends: (281)
I had a 2 meter glider that i used a power pod with, it worked great, I used a nitro engine, gee that was about 25 years ago
hope you are able to find the info you need, there is not a lot of info on converting larger 3 meter gliders to E Power for some reason, Take care, Chellie
#206 | ||
Friends: (281)
#207 | ||
#208 | ||
Tekton Ochroma Pyramidale
Club: Lancaster County Fliers
What a Great thread, and just what I'm looking for too! I have already searched it, and this question has not come up yet, so here goes...
I am building an AeroCraft Miss Stik (http://www.wattflyer.com/forums/showthread.php?t=59723) And I have decided to use the recommended AXI 2212/26 brushless out-runner to power it. From the specs it looks like a good motor for this bird, however what I don't like is the recommended mounting location, which is on the cowling. This wouldn't be a problem except the cowling is only taped onto the front of the fuselage. To me this is no better that just taping the motor onto the plane and I see all sorts of problems arising from it*. So what I would like to know is (are?):
![]() *The problems I see with using only tape to hold the motor on are:
, I would much rather have a solid mount against the firewall that will stay where I put it. Let the cowling be what it is meant to be; a covering for the motor.
Flying: AeroCraft Skimmer "2212"; Tom Hunt Miss Stik Sr.
On the shelf: AeroCraft 1913 Eastbourne Waiting until the day I become worthy: Dave Thornton Bird of Time.
#209 | ||
Friends: (281)
Originally Posted by FlyWheel
It looks to be a simple motor mount bolted to the firewall from the pic. measure your motor with the cowl, so it fits right, if not you will need to find a motor thats not to long, better a fat motor than a long motor ![]() http://www.rcgroups.com/forums/showt...=601101&page=4 |
#210 | ||
Friends: (281)
here is another idea if you want to use a stick motor mount, use a 3/8" x 3/8" bass wood, if the mount is a little loose, wrap masking tape on the wood, with a little ca, that will make for a tight fit.
#211 | ||
I've read that thread, in fact I have a printed copy with me on my building board. The motor pictured in that pic is not an AXI, it's a Frio 10 http://www.rcgroups.com/forums/showt...=601101&page=4 (post #50).
However, I found the Axi home page, and yes, with an adapter plate/spindle it can be rear mounted, and it will just barely fit. Backwards! ![]() ![]() http://www.modelmotors.cz/index.php?...e=26&line=GOLD |
#212 | ||
Here is a store bought option that lets you customize your mount from many different parts.
http://www.espritmodel.com/search.aspx?find=motor+mount |
#213 | ||
What would you all do in this situation? The mounting bracket spread is too big for the firewall. I could get longer screws, put the bracket on the back side of the firewall and use the holes for mounting the bracket to the motor... Anyone have any other ideas?
#214 | ||
Drill the inner bolt pattern into the firewall, throw the "x-mount" aside, and make sure your screws are long enough, but not too long to hit windings in the motor. Put a washer or two on the firewall side to keep the screws from pulling though, hit them with ca if you would like.
Or cut the ears off the xmount and put it in there instead of the washers. Most parkflyer sized motors have 3mm motor screws. |
#215 | ||
Friends: (281)
Originally Posted by hayofstacks
+1
Great Advice, Also you can cut off the holes on the X mount and drill some new holes closer in, it looks like the motor body tappers towards the rear, so it should not be a problem with getting the screws into the fire wall. Hope that helps, Chellie
#216 | ||
That is what I was originally thinking so it's great to hear. I'll post pictures of the workaround. Thanks |
| Tags |
| motor , mount , outrunner |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| EFlite 400 Outrunner motor mount screw size???? | Dubaya | Power Systems | 4 | 03-17-2008 07:08 AM |
| Motor Mount For E-Max Outrunner? Please Help! | wattflyer6161 | General Electric Discussions | 2 | 11-03-2007 08:49 PM |
| help with outrunner mount | RSS Feed | RCU RSS Feed | 0 | 09-05-2006 05:10 AM |
| How to mount an outrunner? | pootman | Beginners | 5 | 03-10-2006 06:51 PM |
| Where to Buy Motor Mount for Outrunner ??? | LDM | Power Systems | 2 | 01-03-2006 08:59 PM |
