Old 01-24-2006, 11:22 PM   #1
velojet
velojet's Avatar
Club: Hibiscus Coast Radio Flyers
Globetrotter Pilot
Question Motor sizes - what do the numbers mean?
I'm new to electric flight - bought a copy of Bob Aberle's Getting Started in Backyard Flying (2002 www.backyardflyer.com) as my introduction, but found he doesn't explain what the motor size numbers mean, and I haven't yet tracked down any thread in this Forum which explains them.
So, just what is a 180 size, a 280 size, a 370 size, a 400 size, etc? Is there any standardisation? Why do only some manufacturers use these numbers?
Thanks!
John Velojet - the Flying Kiwi
Project Globetrotter official route monitor
Project Globetrotter pilot (Western Pacific phase)
Jetex.org editor/developer
NZMAA #10375
velojet is offline
Old 01-25-2006, 04:26 PM   #2
flyranger
I Crash Things!!
flyranger's Avatar
Welcome to my world!! I just got started in electric flight last spring and I was just as confused. Near I as I find out, the numbers are arbitrary, but relate to each other. As those numbers increase, the power output and the current required increase. Best bet is to start with the plane you want to fly and it's weight. I only do park flyers, 36" wingspan or less because I only have parks to fly in, so I started with a geared 370 inrunner e-flite park 370. It draws a max of 7 amps. 7 amps times 11.1v from my Li-poly battery gives 77.7 watts. Moved my 14 oz Great Planes Basic Light Trainer with authority. Takeoffs in less than 3 feet, flying at 1/4 to 1/2 throttle. My Great Planes Lil Poke was 16oz flying weight and would barely fly with the same setup. Moved up to a e-flite Park 400 outrunner and sized the prop for the max of 10amps. 10 amps times 11.1v gives 111 watts. Nice comfortable park flying, takeoffs in about 6 feet, flying at 1/2 throttle, but not aerobatic capable at all. Now moving up to an e-flite Park 480 (got on feebay) which draws 20 amps max. That results in 222 watts, which, with the proper sized prop, should make it totally aerobatic. Oh yeah, I replaced the three channel polyhedral wing with a scratch built aileron wing also. Building a new fuse (also scratch built) and stronger tailfeathers to take the added pressures. FUN!!
ID:	6482   Click image for larger version
ID:	6483   Click image for larger version
ID:	6484   Click image for larger version
flyranger is offline
Old 01-25-2006, 08:40 PM   #3
TManiaci
Stupid Contributor
TManiaci's Avatar
View TManiaci's Gallery9
Red face I'll take a stab at that...
You know, I could be wrong, but I bet the origin of motor sizing is related to the grams of aircraft it was intended to fly and/or the thrust it was designed to produce. So, a 400 motor was intended to fly a 400 gram, or ~14 ounce airplane. A 480 would fly a ~17 oz plane, etc.
Since most aircraft manufacturers recommend underpowered setups, this power level only provides medeocre performance, generally not enough for 3D acrobatics. This would have been in the days of brushed motors, and I would guess the lines have blurred considerably with the introduction of brushless motors a few years ago.
Then again... this could all be BS...
TMan
TManiaci is offline
Old 01-25-2006, 10:03 PM   #4
slipstick
Outstanding Contributor Award
The basics for brushed motors are here :
http://www.ezonemag.com/pages/faq/a414.shtml
The rest of the FAQ is worth reading too.
Unfortunately brushless motors are different again. There are no real standards.
slipstick is offline
Old 01-26-2006, 03:52 AM   #5
velojet
velojet's Avatar
Globetrotter Pilot
Thanks to all for your responses (and for your welcome, flyranger). Slipstick pointed to the best answer I'm going to get on this - that "if you measure the length of a standard ferrite electric motor in mm and add a 0 you have its approximate Speed xxx designation". Some scheme! So I guess the length does bear some rough relationship to power, but certainly nothing even as equivalent as TManiac suggested (or, naive novice that I am, I expected).
NZMAA #10375
velojet is offline
Old 01-26-2006, 04:25 AM   #6
TManiaci
Stupid Contributor
TManiaci's Avatar
Unhappy
Oh well, shot down, but it sounded good, huh?
TMan
TManiaci is offline
Old 01-26-2006, 07:08 PM   #7
velojet
velojet's Avatar
Globetrotter Pilot
Sure did! Most ingenious, and certainly more ingenious than the actual method!
NZMAA #10375
velojet is offline
Motor Numbers?? WingingIt74 Power Systems 3 09-23-2008 04:07 PM
Servo Sizes RUBiksCUbe RC Radios, Transmitters, Receivers, Servos, gyros 8 09-07-2008 02:59 AM
Motor Physical Sizes .... Width diverdon Beginners 2 05-18-2007 04:59 AM
planes' sizes tiredboot Beginners 4 05-26-2006 08:50 PM
Wow to decode Himaxx motor model numbers? Twmaster Power Systems 3 02-11-2006 09:52 PM
Page generated in 0.38222 seconds with 37 queries
