Old 11-09-2008, 01:38 AM   #1
Ralph V
Default Air Retracts nose gear help
I am working on a new plane that I want to install some air retracts in.
My question is how to hook up the steering on the nose gear, I am using
Robart retracts but they do not include instructions on how to hook up
the nose gear steering. I was told they use cables, how do you keep the
cables from getting tangled up when the gear is up? Does anyone have
some pictures they could post to help me out? I have some ideas, but I
am always looking for some better ones.
Ralph V.
Ralph V is offline
Old 11-09-2008, 06:44 AM   #2
hillbille
hillbille's Avatar
View hillbille's Gallery29
WAA-08 Pilot
Friends: (9)
Haven't seen any in a long time (!) but if I remember the ones I saw used a ball soldered on the end of the cable and a ball point pen spring against the steering arms to allow the cable enough tension for reasonable steering but keep the cables taught when retracted. When they were "down" the cables pulled the ball and flattened the springs against the steering horns - so that the cables were tight enough to steer the gear - then in retracted mode - the spring would tension the cable keeping it taught in the "up" position. There may have been a ball and spring on the servo end also to allow more travel - I just can't remember as it has been a while since I have seen that setup. Hope that helps.
Hillbille
It isn't the mistake that causes the crash - it's the time it takes to realize that it WAS a mistake!!
AMA884978 KK6NKY
hillbille is offline
Tags
air , gear , nose , retracts
Tri-gear retracts with 1 servo? GreenAce92 Scratch and Kit Built Aircraft 0 10-08-2008 01:49 AM
T38 Trojan Nose Gear djackson Foamies 3 05-16-2008 05:46 PM
Steerable nose gear? dotyj ParkFlyers 2 07-24-2007 07:01 PM
Steerable nose wheel retracts Joe 1320 General Electric Discussions 7 07-11-2007 01:35 AM
Air operated micro retracts LJE4357 ParkFlyers 6 09-08-2005 05:44 PM
Page generated in 0.06156 seconds with 21 queries
