Old 11-09-2008, 07:12 PM   #1
Sky Sharkster
Sky Sharkster's Avatar
View Sky Sharkster's Gallery11
Globetrotter Pilot
Friends: (20)
Default Dying Canopies, Step-By-Step
Hello All,
I've posted this method (in text) before, but now I've got a digital camera, so maybe a photo step-by-step will be more useful. I picked up a metal pan for $2.00 at a yard sale, RIT Dye for a couple of bucks a pack, a cheap pair of pliers and a disposable stir stick are the basic tools. Paper towels and window cleaner are needed, also.
This canopy is going to be Golden Yellow, if a darker hue is needed, a bit of Black will work. I used 1/2 pack of yellow dye and enough water to cover the canopy.
After mixing the dye with boiling water, remove and let cool for a few minutes. Protect the work area with newspaper.
Good Luck!
Ron
ID:	83205 2 SIG Canopies, 7" 8"
ID:	83206 RIT Dye Canopies
ID:	83207 Clean Canopies With Window Cleaner
ID:	83208 Nice And Clear!
ID:	83209 1/2 Pack Of Yellow RIT Into Boiling Water. After Mixing, Remove From Heat And Let Cool Slightly
ID:	83210 Using Pliers, First Dip, About 3 Seconds, Rinse With Cold Water
ID:	83211 2nd Dip, About 5 Seconds
ID:	83212 Total Of 5 Dips, Last Ones About 7-8 Seconds Each
ID:	83213 Rinsed And Dried
ID:	83214 Finished, Cleaned With Window Cleaner Dried
Sky Sharkster is offline
Old 11-09-2008, 07:31 PM   #2
rhino
rhino's Avatar
Friends: (8)
Cool! Thanks for the clear step-by-steps.
rhino is offline
Old 11-09-2008, 07:37 PM   #3
groundrushesup
groundrushesup's Avatar
View groundrushesup's Gallery45
Club: Hill Country Wattheads
Send a message via AIM to groundrushesup
1kW
Friends: (16)
Originally Posted by Sky Sharkster View Post
Hello All,
Good Luck!
Ron
Thanks for the tutorial.
Have you ever tried using Future to tint your canopies? I've seen people have great success with both methods, the boil-in before the future method.
Everybody's Somebody at The Hill Country Watthead's Thread!
Stop in and see what we're up to!
Visit Our Youtube Channel, too!
groundrushesup is offline
Old 11-09-2008, 11:58 PM   #4
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Fuure Coloring?
Hello GRU,
I've never tried the Future method. How does it work? Is it like a wax or tinted coating?
Ron
Old 11-10-2008, 12:54 AM   #5
groundrushesup
1kW
Friends: (16)
Hello GRU,
Ron
Yeah it is an acrylic floor wax that modelers often use - it dries clear and hard like a candy coat, and you can use stuff like food coloring and/or acrylic paints like Tamiya's translucents to get a good effect.
A friend of mine uses the RIT / boil method to lay down a base coat of color - the yellow like you used, and then future polish tinted with some Tamiya 'smoke' (translucent black) and Tamiya translucent gold to get the spectacularly realistic effect of that gold-tinted filter found on many a modern jet's canopy.
It is very cool. I think I'm gonna do it to my T-28's canopy when it gets here. I'll post pics if I remember
Future is also great at hiding scratches on clear plastic. Best thing is, it is like 6 bucks for a big ol' jug (found mine at Home Depot).
Old 11-13-2008, 01:09 AM   #6
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Send a message via MSN to Ramovan Send a message via Skype™ to Ramovan
Great idea. I'm working on a winter project and would like to use this method with black dye for dark windows. Any experience with how black turns out?
Randy Moody
RC Dude Hobbies
http://www.rcdude.com
Check out the Scorpion Powered Models web page
http://www.rcdude.com/servlet/.fc11d...ionSetups/Page
Ramovan is offline
Old 11-13-2008, 01:32 AM   #7
groundrushesup
1kW
Friends: (16)
If I may... Depends on the base pigment. Some go a ruddy brown, while some go indigo-ish. My friend did find a kind of pigment that stayed relatively black-ish but I cant recall right now. I'll send him an email and ask.
Old 11-13-2008, 02:15 AM   #8
Sky Sharkster
Globetrotter Pilot
Friends: (20)
Default Black or Gray?
Hello Randy,
Yes, I've tried black dye, in fact the first few I did, I used black. GRU is right, if you only dip it a few seconds it's more of a reddish-brown, but after a couple more immersions it turns pale gray and if continued, eventually gets very dark, almost solid black.
Here's photos of one I did about 1/2 way to solid black. This is a Hobby Hanger kit of the Edge 540. The canopy supplied was much thicker material then the SIG canopies, so it took longer to absorb color;
Good Luck!
Ron
Old 11-13-2008, 02:32 AM   #9
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Hello Randy,
Good Luck!
Ron
Sounds good - I think I'll try it. I want to tint the windows on a Top Flite Stinson Reliant I'm building. The kit comes with a flat piece of window material. Perhaps I'll try a test piece before doing the full sheet. Even turning out brown wouldn't be too bad. Your canopy look nice.
Randy Moody
RC Dude Hobbies
Ramovan is offline
Tags
canopies , dying , stepbystep
Step by Step guide for the CVS Camcorder Mad Joe Test Posting Forum 3 11-18-2008 11:45 PM
Step by Step guide for CVS Camcorder Mad Joe Aerial Photography 37 09-16-2007 01:37 PM
*EasyStar Repair for Dummies* wanted... step-by-step fuselage replacement info thecloudpainter Beginners 1 08-11-2007 10:45 PM
Magpie Step by Step Build TexasRCFlyer Foamies 45 07-18-2006 03:56 PM
Next Step jmullane Beginners 18 09-06-2005 08:40 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.60986 seconds with 50 queries
