Old 12-26-2008, 08:29 PM   #151
jismail
Took it out for it's first flight today and it was great!!! flew away with full throttle and a firm toss, a bit slow a first but picked up speed quickly. Only took a few clicks to level it out and I was off!
I flew for a while WOT and then later slowed it down to about 3/4 throttle and just cruised. Ii is a bit harder to keep you orientation with this bird as compared to my prop planes, but aside from that, It wasn't to difficult.
It landed dead stick with no problems at all as long as I kept it on a good glide path.
The only issue I have had with it thus far is that it really heated up my 2200mah 25c battery! I am concerned that it may puff if I fly at WOT for any length of time..........
All in all, this plane seems like a great first EDF and with a little TLC looks pretty cool in the air too!
jismail is offline
Old 12-26-2008, 08:32 PM   #152
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (24)
Congrats on the maiden! Yep, sounds just like mine. I chop throttle before turning from base to final, then just glide it on in and slide in on the grass.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Old 12-27-2008, 09:55 PM   #153
BUCKSHOT
BUCKSHOT's Avatar
View BUCKSHOT's Gallery11
WAA-08 Pilot
Hey guys ,what is the actual motor in this ?
And what would be a big step up?( i need torque ).i have an older f 16 that is kinda fat with a 55mm fan
ALSO THE FAN IS WAY IN THE REAR COMPARED TO THIS ONE
BUCKSHOT
BUCKSHOT is offline
Old 01-05-2009, 03:16 AM   #154
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
hey guys. . . my phase 3 f-16 has white paper on the wings. do i remove the paper before glassing the wing? i guess you would have to because then the silk and wbpu isn't adhearing to the wing, its just stuck to the paper, correct??
iflyrc1012 is offline
Old 01-05-2009, 06:46 PM   #155
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
We would need to know exactly which kit/arf that is and it would help to know which exact fan you're using in it and what packs you have available
I think I need a signature.
Larry
Larry3215 is offline
Old 01-05-2009, 06:46 PM   #156
Larry3215
Larry3215's Avatar
I would remove it first befor glassing but it may be a bit of a pain. Be carefull of the trailing edges - they are pretty thin.
Larry
Old 01-07-2009, 12:53 AM   #157
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
i'm done peeling the wings and tail!!! whew! that only took 2 days. . .
Old 01-07-2009, 02:56 AM   #158
Larry3215
Larry3215's Avatar
Glad that worked out!
Larry
Old 01-10-2009, 03:03 AM   #159
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
ok. larry, i'm slow but i build keepers!! lol
Old 01-11-2009, 01:13 AM   #160
M@F69
I fired up the Stock motor and fan today. ONly went about 1/4 to 1/2 throttle. Just wanted to make sure everything was working.
After, i looked inside the fan housing to see if the blades had rubbed on the inner wall. SUre enough there were. ONly on one side. The blades did not rub anywehere else but a 1 inch spot.
IS this normal? Is there something I should do to fix this now before I go full thorottle?
M@F69 is offline
Old 01-11-2009, 01:22 AM   #161
Big A
Club: CRCC
I like the jet and it flys awesome. I have read most of the thread and was wondering.
Has anybody tried the spray paint from Hobby Town (Crafts etc.) Krylon (Short Cuts) It comes in very small cans. I have used it to paint foam planes and gliders, just a thought.
Big A
Big A is offline
Old 01-12-2009, 02:19 AM   #162
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
my version of the phase 3 f-16. . .
ID:	90142 i think its sleek and sexy
Old 01-12-2009, 03:45 AM   #163
Larry3215
Larry3215's Avatar
Wow! Thats cool. Is that a covering you painted or did you do all that detail?
Larry
Old 01-12-2009, 03:46 AM   #164
Larry3215
Larry3215's Avatar
Big A
Short cuts works pretty well. Use several lite coats for best results.
Larry
Old 01-12-2009, 04:12 AM   #165
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
larry,
i will explain all when i post the build log and maiden flight vid. i'm thinking all will be done in as soon as 2 weeks(if the northeast weather don't go artic!) i got the idea for the finish job from angler-hi who posted this build a few weeks ago. . so he gets alot of the credit for it. the plane will be totally stock except for the finishing job.
Old 01-16-2009, 03:37 AM   #166
Angler-Hi
Angler-Hi's Avatar
View Angler-Hi's Gallery20
Send a message via Yahoo to Angler-Hi
Friends: (40)
Looks great friend! Can't wait to see the maiden vid on her!
The best teacher in the world is experience...now go fly something already
Angler-Hi is offline
Old 01-16-2009, 03:41 AM   #167
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
if the artic weather takes a weekend off , i'd like to patrol the skies over my flying field. . .
Old 01-16-2009, 03:43 AM   #168
Fly Time
Ask me how I know
Fly Time's Avatar
View Fly Time's Gallery17
WAA-08 Pilot
Friends: (20)
Good to see you checking in Mike! These forums have been pretty quiet without you around
Doug
Loves the sound of 50 amps through an outrunner!
Fly Time is offline
Old 01-16-2009, 03:55 AM   #169
Angler-Hi
Angler-Hi's Avatar
Friends: (40)
Thanks Doug. It's been busy over here man! Things are calming down a bit now, so hopefully I'll have more time to chat with you guys. Well, I have to run for now, but I'll check in later tomorrow. Take care Doug.
Old 01-16-2009, 03:55 PM   #170
M@F69
Anythoughts on this???
I am finished painting. Will post picks soon. Just need to sort out the fan rubbing on the inside of the fan housing.
Any thoughts on why or how to fix would be greatly appreciated.
THanks
M@F69 is offline
Old 01-16-2009, 04:00 PM   #171
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (52)
THanks
It sounds as if your motor might be mounted slightly off to one side. You can see if there is any play in the screw holes that will allow you to move it over a little bit. Either that or your fan housing could be slightly out of round. Can you take it out and slowly rotate it by hand and watch to see if the blades all come closer to the inside of the housing in that area?
I just bought one of these today. Probably going to put one of my Don's 400s in it.
Tom
Grasshopper is offline
Old 01-16-2009, 05:35 PM   #172
Larry3215
Larry3215's Avatar
If the rotor is out of balance it will rub too. Also, at hi speeds the fan blades stretch and will rub.
Pretty much every one Ive ever owned had some rubbing though.
Get the motor centered as well as you can then work the motor up to speed a little at a time to wear it in slowly so you dont over amp the esc.
Larry
Old 01-17-2009, 01:13 AM   #173
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
when is a motor considered "worn in?". . . 2 batteries run thru? more? less?
when breaking in a motor do you use a test stand? or just hold the fan assembly??
Old 01-17-2009, 02:15 AM   #174
Larry3215
Larry3215's Avatar
Its not the motor you need to wear in - its the fan blades. Here is my general proceedure with any new fan assembly.
0)Never hold the fan in your hand while you run it up. For one thing you can get seriously hurt. For another, your hand will exert uneven pressure and distort the outer housing so you wont be able to tell if its rubbing because its off center or because your squeezing it.
1)Balance the fan rotor really really well. You want it running butter smoooooth. Do what ever it takes to get rid of all vibration.
2) get the rotor as close to centered as you can. Elongate the motor mounting holes if needed. The rotor needs to be centered.
3)Mount the fan in a holding fixture or in the model then run it up part way and check for rubbing. Gradually run it up faster and faster and stop and check for rubbing.
If its rubbing - check to see if its still centered. Idf that looks ok, then you just need to slowly wear the fan blades down by running it.
Dont just go to full throttle and hold it there. The rubbing may cause the amps to go WAAAAY up and burn up the controller and or motor. So go slow and work at it. Doesnt really take all that long.
Larry
Old 01-17-2009, 04:33 AM   #175
iflyrc1012
Insane Wiggy pilot
iflyrc1012's Avatar
Globetrotter Pilot
Friends: (19)
ok gotcha. . . thanks for the advise
Tags
3 , build , f16 , phase , thread
Maiden Phase 3 F-16 (EF-16) Crash9 Electric Ducted Fan Jets 35 08-12-2009 01:07 AM
phase 3 EF-16 sb13 Electric Ducted Fan Jets 54 03-03-2009 02:34 PM
PHASE 3/ENroute EF-16 Fan Appreciation Thread!!! SmoothCruizer Electric Ducted Fan Jets 57 07-14-2008 06:36 PM
Phase 3 EF-16 Help s0laris Foamies 3 07-01-2008 12:13 AM
new f-16 from phase 3 CORVETTER89 Electric Ducted Fan Jets 15 09-14-2007 05:38 PM
Page generated in 0.58234 seconds with 70 queries
