Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Seaplanes E-Powered
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 08-24-2011, 06:25 AM   #251
Otto Dieffenbach
Check six
Outstanding Contributor Award
Default Polaris XXS maiden flight tomorrow
Will maiden tomorrow morning. Made out of 7 Chevy's take home containers.
Otto Dieffenbach is offline
Old 08-24-2011, 07:27 AM   #252
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Very nice!
That has to be about the smallest one Ive seen yet!
But - you cant get off that easy. We need more details! Motor? ESC? Batts? Servos?
You cut the tail off in the pic so I cant tell - elevons or seperate elevator and ailerons?
Your video guy will have fun keeping that one in the view finder I bet!
I think I need a signature.
Larry
Larry3215 is offline
Old 08-24-2011, 08:39 AM   #253
Otto Dieffenbach
Check six
The only mods to the original are 1) doubled the step to about 3/8 inch. I've found that on the micros you need more step because of water adhession. I have a micro P-82 built from two PZ P-51s on floats. 2) raised the motor a 1/4 inch for prop clearance. Otherwise standard setup. Motor is a APO5 3000kv,prop GWS 4.5x3, 7a ESC, 2s 350mah, AR6400 rcvr block up in the tail and two 1.5g spektrum servos for the ailerons. This was just a quick and dirty spy cam photo cause I was too lazy to get the good camera. Hopefully more tomorrow.
Old 08-24-2011, 06:29 PM   #254
Larry3215
Larry3215's Avatar
Good luck!
Larry
Old 08-24-2011, 09:26 PM   #255
Otto Dieffenbach
Check six
Default Micro Polaris XXS video
Had 4 flights this AM. Flys great... stable and fast. See video and thread started in micros section of Wattflyer.
Old 08-25-2011, 03:58 AM   #256
Larry3215
Larry3215's Avatar
LOL
Outstanding!
Larry
Old 08-25-2011, 06:10 AM   #257
Otto Dieffenbach
Check six
Thanx Larry, you turned me on to it. Very good flight characteristics but does not like inverted. Is the big one that way? A lot of elevator to keep the nose up, and I mean a lot. Also significant pitch changes with speed, not power but speed pitch changes. Nice addition to my water toys.
Old 08-25-2011, 06:59 AM   #258
Larry3215
Larry3215's Avatar
Ah! I forgot to mention that.
Thats mainly a CG issue. Im flying the big one way behind where Steve recomended the cg to be. I tend to like my models to be pretty close to neutral CG wise. That can make for a sensitive elevator but it really improves over all handling - especially the issues you are talking about.
If you do move the cg back, be prepared to move the step back as well or you can get severe porposing when landing at speed. if you remember in my water video that first landing at speed had multiple bounces. Thats due to the cg being well behind the step. When you hit the water, the weight pushes the tail down and causes the pitch up. Having the step further back reduces that or eliminiates it.
its not an issue if your flying the stock CG point - only if you move it back.
IIRC, I ended up about 4" to 5" behind where Steve recomended the CG to be. Thats equal to 2" behind on the original drawing. For your size - if Im doing the math correctly - that would be about 7/8" to maybe 1" behind the "stock" position if you started where Steve said to start.
I just measured and I moved the step back 4" on the XXL and I was going to move it back another 1/2" but didnt get around to it.
You need the step to be just slightly ahead of the cg. To far forward of the CG causes the porposing and to far aft makes it harder to rotate and harder maintain straight lines on the water or grass at speed. Its just like having the main wheels on a tail dragger in the wrong position.
Larry
Old 08-25-2011, 04:55 PM   #259
Otto Dieffenbach
Check six
It flys so well upright I don't what to change it. Flew two flights in a Gym last night at 1/3 throttle, great low speed handling. Generally, I've found on the little ones that you need the extra stability due to gust/bumpy air. I am right at the suggested cg. I will try an experiment, move it back and check inverted behavior and elevator sensitivity.
Old 08-25-2011, 06:51 PM   #260
Larry3215
Larry3215's Avatar
Steve's recomended CG point is very nose heavy and therefore, very stable - which is exactly why you have the issues you are having.
As with most aero details - its a trade-off. To get what you want, you have to decide what you're willing to give up
You could go back in small steps.
I also use lots of expo to help with the sensitivity.
Keep in mind too, that I am using the ailerons as elevons PLUS a working elevator, so my big one has tons of elevator authority and is still a very stable flyer even at my rearward CG point.
I would move the cg back more if it wasnt too much trouble to get the packs further back
Larry
Old 08-25-2011, 09:45 PM   #261
surfer dude
surfer dude's Avatar
View surfer dude's Gallery17
Club: Tulsa unclub, any open air space above me
Globetrotter Pilot  100mph Speed Demon
Love it! It's so darn cute! Flys great!
I didn't hear, does it have an elevator, or elevons?
I've had the original kit version flying for over a year, and love it. I think I need to build that one.
Can you give us a snap shot of your plans, with dimensions if possible?
AMA 729929
ODB3 September 16th & 17th
surfer dude is offline
Old 08-26-2011, 05:26 AM   #262
Otto Dieffenbach
Check six
Thanx. It does fly great even at low speed in a Gym. I have ailerons and elevator separate but will probably play with elevons and elevator per Larry's comments. Also I'll play with CG. But make no mistake this flys well as is but I'm an old pattern pilot and love being upside down so I will work to make that happen.
Larry, on my Sea Dart thread sent me a link to plans for the Polaris. I took this and scaled them down to a 13 inch wingspan. Only changes were to make the step 3/8" and to raise the motor pod 1/4 to a half inch to allow prop clearance. I mounted the AR6400 flat to the bottom of the stab and boxed it in after wiring and linkage connections. I mounted 2 1.5g servos flat to the wing under the fuse top. It takes 7 Chevy's containers to build. You can get one good flat 6" by 6" square out of each container. My prop, as indicated is a 4.5x3 GWS but I forgot to add that I cut it down to 3.75 inches. So it is a 3.75x3 prop. Best and good luck.
Old 08-26-2011, 05:28 AM   #263
Otto Dieffenbach
Check six
I forgot to add that I started a Thread in the micros area with some pictures.
Old 09-29-2011, 12:49 AM   #264
Otto Dieffenbach
Check six
Default First water flight of micro Polaris XXS
First water flight of my micro Polaris. Need some suggestions on how to fix the s turning on takeoff. Best.
Old 10-20-2011, 02:10 AM   #265
John_
I'm thinking about getting the polaris for a sea plane. I saw one last week, and all the servos are buried in the foam. doesnt seem easy to get to servos, anyone rework this with hatches?
John_ is offline
Old 10-20-2011, 03:02 AM   #266
Larry3215
Larry3215's Avatar
Its just as easy to cut the hatches later - IF you need them. It is a foam plane
If you cut them ahead of time, the chances of a leak are much higher.
Larry
Old 10-20-2011, 10:35 PM   #267
surfer dude
I've been flying my Polaris for 3 years, never needed to see the servo's.
I put in good 9gm servo's, hxt900's, $3 servo's from Hobby King. They are cheap in cost, but I've used over 50 of these servo's, and never had one fail. I've striped them in a crash, but never in flight.
Larry's right, it's a foam plane, easy to make a hatch latter if you need it.
Not a single drop of water has entered my Polaris. The only hatch I have is my battery hatch which I tape all seams when flying off of water. The only other openings are the push rod guides, which I fill with grease to keep the water out.
AMA 729929
Old 09-27-2016, 01:38 PM   #268
momo5400
View momo5400's Gallery1
Default my polaris 180
https://www.youtube.com/watch?v=ItLaH9bkXEk
momo5400 is offline
Old 04-19-2017, 06:21 PM   #269
momo5400
Default giant polaris XXL on water
momo5400 is offline
Old 05-01-2017, 04:55 AM   #270
momo5400
Default polaris XXL measurement speed 103 km/h
momo5400 is offline
Old 05-02-2017, 10:43 AM   #271
momo5400
Default polaris XXL touch and go
momo5400 is offline
Old 07-05-2017, 02:42 PM   #272
momo5400
Default polaris XXL 200% reverse,looping and touch and go
momo5400 is offline
Old 07-22-2017, 07:12 PM   #273
momo5400
Default some acrobatics with my polaris XXL
momo5400 is offline
Tags
build , polaris , scratch , xxl
First scratch build Mac1z Scratch and Kit Built Aircraft 3 08-23-2008 03:21 PM
Begginer scratch build. spitace General Electric Discussions 64 09-01-2007 05:06 PM
Scratch Build CPP Murdock1 Beginners - Helis 0 07-02-2007 05:20 PM
First try at scratch build-F-106 tenore Electric Ducted Fan Jets 14 04-09-2007 09:29 PM
shuttle scratch build ericthetree Foamies 25 03-02-2006 03:53 AM
Page generated in 0.72705 seconds with 69 queries
