Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Seaplanes E-Powered
Seaplanes E-Powered Discuss electric powered seaplanes here
Old 01-20-2009, 01:31 AM   #101
View CHELLIE's Gallery13
Friends: (281)
Thought you Guys might enjoy this, Enjoy, Chellie
Old 01-20-2009, 02:24 AM   #102
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
That was pretty cool Chellie!
I think I need a signature.
Larry
Larry3215 is offline
Old 01-20-2009, 02:25 AM   #103
benovisoff
aint crashin aint flyin
Club: AMA
Friends: (12)
very nice
benovisoff is offline
Old 01-20-2009, 02:41 AM   #104
larryross
certified FFF addict
larryross's Avatar
Send a message via Skype™ to larryross
That thing had a lot of power. I was surprised it didn't WOW sooner. Wish I could play with those expensive toys (not really) I'll feel bad enough if my cheap things ditch. Good show Chellie.
larryross is offline
Old 01-20-2009, 03:03 AM   #105
Friends: (281)
here is another one, turn down the volume, unless you like chinese music
Old 01-20-2009, 03:18 AM   #106
Friends: (281)
This is neet
Old 01-20-2009, 03:21 AM   #107
benovisoff
Club: AMA
Friends: (12)
cool. how's the bipe coming along?
Old 01-20-2009, 03:24 AM   #108
Friends: (281)
LOL Its coming along great, I need to get my behind out into the hobby room and do some more work on it rather than peck away on this key board Take Care, Chellie
Old 01-20-2009, 03:27 AM   #109
benovisoff
Club: AMA
Friends: (12)
alright, DO THAT!
Old 01-22-2009, 05:22 AM   #110
Larry3215
Larry3215's Avatar
Default Some good things some bad things some miscalculations
First the good things - I've started to add some color to the Polaris and thats working out fairly well so far. Lots more to do. The colored packing tape sticks well. A pass over by a med hot covering iron helps a lot. I still need to paint a lot of the blue foam with white which Im not looking forward to.
My cowling ended up looking pretty cool I think. Its tilted down a bit more than I wanted but it will do for now.
Now the not so good.
Ive been playing with various options for an air scoop in the front. I haven't come up with anything I like so Im just going to do something and live with it for a while - until Im inspired
I did some checking and decided where the two packs would need to go to balance properly and cut a new hatch in.
Thats when I got a good look at my speed controller Holly cow! The heat shrink is melted badly and the foam it was sitting on is also melted
Good golly molly I must be pulling waaaaay more amps than I expected. That got me to wondering how that could be so I went back and re ran the numbers through MotoCalc.
I must have pushed the wrong buttons the first time I ran the numbers or entered something way off because now Im seeing predicted amp values up near 80 amps! With no cooling air flow no wonder things got hot!
On looking closer I noticed that the efficiency numbers are down close to 50%! Thats why the motor is running so hot.
Obviously I need to prop down a lot until I can get a motor with a lower kV. I am running this setup waaaay over proped.
I should be able to get better performance on fewer watts by running the motor in a more efficient range. I definately need the ugly air scoop
Name:	IMG_4871 (Medium).JPG
ID:	91265 plastic dish soap bottle painted black on the inside - doesnt scratch off that way.
Name:	IMG_4872 (Medium).JPG
Name:	IMG_4873 (Medium).JPG
ID:	91267 melted the foam the esc was sitting on - Castles are tough!
Name:	IMG_4874 (Medium).JPG
Larry
Old 01-22-2009, 05:28 AM   #111
Friends: (281)
That Cowl looks Awesome Larry, good job, I like it
Old 01-22-2009, 05:49 AM   #112
benovisoff
Club: AMA
Friends: (12)
awesome. I just realized that this isn't the bipe thread. whoops
Old 01-24-2009, 08:31 AM   #113
Larry3215
Larry3215's Avatar
Ive made some good progress on the changes. I came up with a new idea for the air intake - its part of the new hatch. Looks a lot better than my other idea.
Im also getting some more color on it. I have some Coast Guard markings I'll be adding as well when its a little further along.
Its about ready to test fly with the 2P battery setup and a much smaller prop. The motor I want isnt in stock at medusa yet so I'll have to wait on the new power plant for a while. Im still waiting and a new spinner which will help the looks too.
Name:	IMG_4875 (Medium).JPG
Name:	IMG_4876 (Medium).JPG
Name:	IMG_4877 (Medium).JPG
Name:	IMG_4878 (Medium).JPG
Larry
Old 01-24-2009, 10:49 AM   #114
Friends: (281)
Thats looking Super Larry, keep up the great work, Chellie
Old 01-26-2009, 06:54 AM   #115
Larry3215
Larry3215's Avatar
The fuse is about done as far as dolling it up goes. I still have one wing to finish and it will be as pretty as I am willing (or able) to make it
If the weather warms up a little later this week Im going to try to get out to the pond to do some water testing. Its toooo coooold to chance getting wet now though!
Name:	IMG_4879 (Medium).JPG
Name:	IMG_4880 (Medium).JPG
Name:	IMG_4881 (Medium).JPG
Name:	IMG_4883 (Medium).JPG
Name:	IMG_4884 (Medium).JPG
ID:	91692 I should have printed the Coast Guard sticker on a white back ground. Oh well.
Larry
Old 01-26-2009, 07:15 AM   #116
larryross
larryross's Avatar
That water bird looks great Larry. I love the scoop, but you're going to have make sure you keep it right side up on the water. Colored tape is cheating, but it sure looks good. Do you Corrosion-X your electronics? I haven't made much progress on mine, but I got the shop cleaned up (the center at least) and my build table is flat empty so the Polaris wing will be on the table tomorrow. I have spent far too much time finishing the small parts. If I keep at it I'll have it ready for final assembly and paint.
Later
Larry
Old 01-26-2009, 07:20 AM   #117
Friends: (281)
Thumbs up Sweet
Sweet Nice job Larry
Old 01-26-2009, 07:22 AM   #118
Friends: (281)
BTW where did you get the color tape at Larry ?
Old 01-26-2009, 08:29 AM   #119
Larry3215
Larry3215's Avatar
Thanks for the compliments! It turned out better than most of my attempts at dolling up a foamy
Im liking the colored tape. I got it from these guys.
http://www.fast-pack.com/colored_tape.html
Towards the bottom of the page is a package deal where you get 6 rolls for $9.45 plus $6.50 shipping. Comes to $16 for 6 rolls which isnt bad. You get to choose any colors you want too which is great. I got 1 roll of white, 2 red and 3 black.
The white doesnt cover very well at all unless its going over a white base so keep that in mind. The red covers fairly well but not 100%. You can see the lap lines. The black covers almost anything. So its important to plan your application so the darkest colors go on last.
I run a covering iron set to medium heat over the tape after its applied and that seems to make it stick better and smooths out some of the wrinkles.
Larry - I use CorrosionX on everything except the servos. I dunk the motor, rx, BEC, esc, servo leads, power conectors, etc.
Dont do the servos. The CorrosionX will kill about 1 out of 3 from my experience.
I dont worry about being upside down in the water and things getting wet.
I have deliberately run a rx, esc, servos and motors while they were completely under water with no issues after they were treated with CorrosionX.
When I fly my Capricorns on the water, the controller is under the wing and gets splashed all the time. I have had the Capricorn up-side down in the water for 20 minutes waiting for a breeze to blow it right side up again. The motor, controller and rx are under water the whole time. As soon as it gets right side up - Im flying again. I dont even wait to dry anything out. Its not necessary.
The stuff is truely amazing. The TV commercial they used to run showed them watching a TV treated with CorrosionX while it was on the bottom of a swimming pool!!
A few people have reported loosing esc's when they went into the water even after being treated with CorrosionX. I have never had any issues after many dozens of dunkings with several different controllers.
I can only assume they didnt get the stuff into every nook and cranny under the heat shrink.
The other possibility is they didnt shut off the throttle soon enough after the plane went into the water. The amp draw of a prop in the water is at least 20 times more than in the air. Its just like stopping the prop from turning and going to full throttle.
So if you dont shut down soon enough after hitting the water, your going to burn something up for sure.
I have occasionally had an untreated servo go nuts when it filled up with water but they have always been ok after drying out. More often than not its no problem.
Im hoping I wont get much if any splashing into the cooling inlet but I'll have to wait and see once I get it on the water.
The only problem that would cause would be a weight and balance issue if enough water did get inside.
I dont really have any choice anyway. With a 1000+ watt power system you have to cool it some way or you'll get melt down like I did on the maiden flights!
Larry
Old 01-26-2009, 08:38 AM   #120
Larry3215
Larry3215's Avatar
By the way - the air scoop is also my battery hatch.
Larry
Old 01-26-2009, 08:54 AM   #121
Friends: (281)
Thank you Larry, My Bi Plane needs some trim color Take care, Chellie
Old 01-27-2009, 02:17 AM   #122
Larry3215
Larry3215's Avatar
Hurray! The new Medusa motor Im after is now in stock! Should be here by the weekend if Im lucky
With the new motor and 2P packs I should be getting well over 1/1 thrust and a good bit more speed and runtime! Thats a combination I can always live with
Larry
Old 01-28-2009, 04:11 AM   #123
Larry3215
Larry3215's Avatar
Ok, its about all done and ready for the re-maiden with the new power system. Just need to get the new motor installed.
I cant decide if the fairings for the wing servos need some color or not....
Name:	IMG_4885 (Medium).JPG
Name:	IMG_4886 (Medium).JPG
Name:	IMG_4887 (Medium).JPG
Larry
Old 01-28-2009, 04:48 AM   #124
Friends: (281)
Yes they do, Make them PINK
Old 01-28-2009, 06:38 AM   #125
Larry3215
Larry3215's Avatar
LOL
Larry
Tags
build , polaris , scratch , xxl
First scratch build Mac1z Scratch and Kit Built Aircraft 3 08-23-2008 03:21 PM
Begginer scratch build. spitace General Electric Discussions 64 09-01-2007 05:06 PM
Scratch Build CPP Murdock1 Beginners - Helis 0 07-02-2007 05:20 PM
First try at scratch build-F-106 tenore Electric Ducted Fan Jets 14 04-09-2007 09:29 PM
shuttle scratch build ericthetree Foamies 25 03-02-2006 03:53 AM
Page generated in 1.44877 seconds with 88 queries
