| Heads UP RC discussion Heads up RC discussion and support. Monitored by Heads UP RC. |
#26 | ||
aint crashin aint flyin
Club: AMA
Friends: (12)
Oh john I almost forgot, those servos are from heads up. is the esc too? then the only thing not from jeff would be the plane
flying is not for birds, but for random household items that look like they can have airfoil.
#27 | ||
You can bury me after I'm done flying
Club: Just Some Friends
Friends: (28)
The Blue 5g servos are some I got from Jeff, the black 9g servos were some I bought several years ago from RCS-Sports.com
I'm fairly sure that the ESC is also one I'd gotten from Jeff too. Standing By, SJ |
Blue Skies, Calm Breezes & A Full Hanger
Makes Me A Very Happy Man
#28 | ||
Club: AMA
Friends: (12)
how can that motor have that much power and be only I think it was $9?
thats INSANE! I love it. I will make a tri-motor SS from those or maybe a pico stick? that would be nice
#29 | ||
HeadsUp RC.com
Friends: (4)
Originally Posted by smokejohnson
That's such a well done guide that I added a link to it in the 2409-12T and 2409-18T motor listings, as we sell these motors with the plastic stick mount.
Also, for anyone interested, we're now selling a nice Aluminum Stick Mount for those two motors. |
Jeff
Headsuprc.com |
#30 | ||
Club: Mullet Mauroders
Friends: (86)
Wow!! Thats on my Shopp'in list for sure!!!! thanks Jeff, Bub, steve
![]() Stick Motor Mount for motors with 10mm bearing tube Fits motors with 10mm bearing tubes, such as the 2409-12T, 2409-18T, Emax CF2822, and Emax CF2805. This aluminum mount has three set screws to secure the motor. The set screws require a 1.5mm Allen wrench. For use on models with 10mm sticks. |
Monkey Minion'air
#31 | ||
Club: Independent
Friends: (108)
#32 | ||
HeadsUp RC.com
Friends: (4)
The 2409-18 and 2409-12 have 10mm bearing tubes. The 2408-21, 2410-12D, 2410-08, 2410-09, and 2410-12Y have 8mm bearing tubes. Hope this helps
Jeff
Headsuprc.com |
#33 | ||
Club: Independent
Friends: (108)
Oops...I guess it has been too long since I had my 2409-12T out of the plane :o.
#34 | ||
Friends: (28)
Very glad to see your stocking those new mounts Jeff
![]() Lots better looking than what I was trying to do for sure ![]() Standing By, SJ |
#35 | ||
Club: Independent
Friends: (108)
I have a couple of Turnigy motors that I need to get that mount for. I hate firewall mounts on a foamie.
#36 | ||
Club: RC Dusters, AMA 3875, Sandwich, IL
Friends: (53)
- Kev
AMA 873921 RC Dusters Flying Club, AMA 3875, Sandwich, IL Question with Boldness. Hold to the Truth. Speak without fear. |
#37 | ||
Friends: (7)
Got a GWS A6 (at-6 Texan) on the build deck! Just outfitted with TP 2409-12T, POWER UP 32amp and some TP SG90 sub micros! Still setting up (the guy I bought the plane kit from forgot the hardware bag, should have it in a couple days).
From what I see, this thing is gonna be a rocket! I really appreciate the info and set-up suggestions on the website. Got the order in just a couple days. Thanks! Thumbs up to Heads Up! ![]() P.s. I rigged the motor mount like Smokejohnson did, really solid. |
I know that you believe you understand what you think I said, but I’m not sure you realize that what you heard is not what I meant
-Rob |
#38 | ||
Friends: (86)
Originally Posted by birdDog
Don't run any more than a 9/4.5 on that set-up and 8.5 will haul it like a bat outta ,,,,I use 9 4.5's one the Monkey Chopper, 8.45 three blade works well too! but watch the 8-10 sec WOT times an give her a a few moments to cool down before punch'in it again, I've pushed these set-up as far as they'll go on several planes, Have Fun ! bub steve
Monkey Minion'air
#39 | ||
Friends: (7)
I can't click it so I'll say it. Thanks Bub!
I was getting some pretty high readings on the 8x6. |
-Rob |
#40 | ||
Friends: (86)
Ah Shucks,,,,,I got some GWS part "trees" if you short on anything, That things gonna ROCK, bub, steve
Monkey Minion'air
#41 | ||
Friends: (13)
Here are two of my planes I have been flying for nearly three years. The Big Stick had a Kontronic 600-25 geared and the Tower 40 had a Kontronic 480-33 geared. Both had Kontronic speed controls. Lately I found out about Heads Up here on Wattflyer. To date I have had only three orders. I have now powered both planes with 4248-08 motors and Powerup 70 amp speed controls from Heads Up. There is as much difference as in night and day. Unlimited vertical. I am flying with 3700mah batteries and getting 15 min plus. Great service and fast delivery, You just can't beat Heads Up RC for products and service.
#42 | ||
Friends: (13)
I lost them when I did the edit.
#43 | ||
Friends: (86)
Monkey Minion'air
#44 | ||
Friends: (86)
Jeff set me up good with info on my Wings flight pack, 2410-12 , 10 amp ESC two cells 800mah ,5 gram tp servos, 20 mins flite times!!!!! Thanks Jeff!!! bub, steve
Monkey Minion'air
#45 | ||
Club: Independent
Friends: (108)
Jeff can you post the info you have for the 2805-28?
#46 | ||
HeadsUp RC.com
Friends: (4)
2805-28 Outrunner Brushless Electric Motor The 2805-28 is a 0.9 ounce 2800KV direct drive outrunner motor that works well on small pusher jets and flying wings, and for many applications where a high speed motor spinning a small prop is needed. The 2805-28 works well with both two and three cell Lipo batteries. Please check out the prop data below for help in choosing the right battery and prop for your model. I recommend using the Power Up 20A or 32A ESC, depending on what battery and prop you use. The timing of the ESC should be set to 'soft' (also called inrunner timing), and this is easily accomplished with your transmitter. Clear instructions are provided with the ESC. MOUNTING OPTIONS: A firewall mount that is secured on the motor with two set screws is included, and the motor can be mounted on the GWS Plastic Outrunner Mount as pictured below if your model has a 10mm stick. You will need to drill a couple of holes to secure the motor to the GWS mount. You will need a 3mm prop adapter or a 3mm prop saver to mount a propeller. The picture below is for reference only. The plastic mount is not included, but is available in our store. Propeller data for 3 cell Lipo batteries: The APC 5.5x4.5 prop produces about 16 ounces of thrust at 21 amps. Exceeds recommended maximum amps. Use with caution. The APC 5.25x4.75 prop produces about 15 ounces of thrust at 20 amps. Exceeds recommended maximum amps. Use with caution. The APC 4.5x4.1 prop produces about 14 ounces of thrust at 15 amps. The APC 4.1x4.1 speed 400 prop produces about 11 ounces of thrust at 12.5 amps. Propeller data for 2 cell Lipo batteries: TheGWS EP 7035 prop produces about 15 ounces of thrust at 13 amps. TheGWS EP 6030 prop produces about 13 ounces of thrust at 11 amps. The APC 6x4 speed 400 prop produces about 13 ounces of thrust at 13 amps. The APC 6x5.5E prop produces about 10.5 ounces of thrust at 15 amps. The APC 5.5x4.5 prop produces about 10 ounces of thrust at 12.5 amps. The APC 5.25x4.75 prop produces about 9 ounces of thrust at 12.5 amps. TheGWS EP 5030 prop produces about 9.5 ounces of thrust at 7.5 amps. The above data is a result of my own testing using fully charged Lipo batteries. 2805-28 Specifications: Weight (motor only) = 0.9 ounces (25 grams) Diameter = 1.1 inch (28mm) Total Length = 1.5 inch (38mm) Shaft Length = 0.4 inch (10mm) Shaft Diameter = 3mm Voltage = 7 to 13 KV = 2800 Current = 18 amp maximum for 30 seconds |
Jeff
Headsuprc.com |
#47 | ||
Club: Independent
Friends: (108)
Thanks Jeff
#48 | ||
Here is my Setup for a Mountain Models EVA sport. Using a 410-12D Motor with 9x5 GWS prop, and 1300 Power Up Lipo and 9 gram servos from Jeff. Rest of the electronics are a Spektrum AR6100 receiver and a Thunderbird 18 ESC.
Using the firewall mount for the EVA the motor fits great and only modification was shortening the prop shaft to use with the prop adapter to get a good fit with the cowl. Performance is great plenty of power for sport aerobatics, and decent vertical, even with a AUW around 19 ounces. 8-9 minute flight times with around 30-40% battery left on landing. Got a 2409-18T and components coming to put in a Lucky A.C.E next, should be a good performer as well. |
Why is it when I have a 12 of one prop I never break them, but when I only have one it breaks on the first flight.
![]() Current planes GWS Tigermoth 400, Slow Stick Video Plane |
#49 | ||
Friends: (7)
Jeff's Cool
-Rob |
#50 | ||
My SuperCub: 3530-10 ,PoweruP 40amp esc , Powerup 2250 lipo, Jeff 9 gramer servo's, GWS 11x7 dd prop, AR6200 2.4 ghz on a DX6i.....= one SuperCub!
![]() ![]() ![]() ![]() ![]() CF wing support and ailerons also. |
| Tags |
| heads , rc , set , show |
| Heads Up RC--2009 Web Store Front | max-nix | Company Discussions | 19 | 09-13-2012 11:32 PM |
| Thumbs up... to Heads Up RC! | Tinman | iTrader talk | 230 | 07-28-2012 12:12 AM |
| Welcome Heads UP RC to WattFlyer | Mike Parsons | Heads UP RC discussion | 69 | 03-16-2012 10:17 PM |
| *heads-up-rc specials* | aviatordave | Basement Bargains | 3 | 12-17-2008 02:32 AM |
| Rave for Heads Up RC | Gnascher | Company Discussions | 16 | 05-02-2008 01:05 AM |
