| Heads UP RC discussion Heads up RC discussion and support. Monitored by Heads UP RC. |
#51 | ||
r/c crash test "DUMMY"
Club: http://www.facebook.com/home.php?#/group.php?gid=221090112030
all but 3 in my fleet are powered by hurc my electristar is still stock and my e-flite 480 is powered by eflite 480 bl and my mini supersportster is powered by a himax motor and castle creations esc that is how it came when i bought it from fellow club member the rest of the fleet my hanger 9 ugly stik is powered by 4248-08 and 60amp esc from jeff, great planes spectra powered glider was just converted to brushless using 2836-10 and 30 amp esc it is like being towed up with a winch i figure i will now be able to fly this plane all day on one battery if i want to, i can get it almost out of site in less than a minute shut the motor off and hunt for thermals (my lawn chair flyer) I also have an e-flite asscent i just converted using a 2408-21 outrunner and a 15 amp esc same performance as the spectra i am in the middle of my next conversion it is a model tech 300 extra .25-.30 that i am converting to electric using 3530-10 and 60amp esc from jeff this will probally be a little under powered but should make a good scale flyer i'm hoping if its to slow then i may upgrade to the 4248-08 at a later time. and jeff has helped me out a lot by answering my questions each time before buying and has never steared me wrong. thanks jeff.
![]() here is a video of the .40 size ugly stik after conversion http://www.youtube.com/watch?v=YxdFtgHbFX4 |
#52 | ||
Club: Mullet Mauroders
Friends: (87)
Monkey Minion'air
#53 | ||
Club: Independent
Friends: (108)
Thanks Steve but that's the motor I flew on my Swift today and it worked great
#54 | ||
Friends: (87)
Monkey Minion'air
#55 | ||
Friends: (87)
Originally Posted by dmmalish
Is that a E-Starter cowl???I like it! bub, steve
Monkey Minion'air
#56 | ||
that is a cowl from a great planes mini supersportster i had it laying around slapped it on and it fit really makes it look fast doesn't it? i think it is going to be alot more fun to fly now compared to the brushed motor that was in it. and the motor looked like a tumor hanging on there without the cowl seeing as i hung the motor of the front instead of inside the way the brushed motor was mounted.
#57 | ||
Club: Independent
Friends: (108)
MS Composite Swift II (I will get pics of the mount soon)
EMax CF2805 20 amp esc 9 gr servos AR6100 Rx 7.4v 1250mah Rhino Using a TP 7x6E my numbers off the Wattmeter are as follows: 14.93 amps 6.46 volts 96.7 watts AUW is 11.5 oz |
#58 | ||
Club: Independent
Friends: (108)
#59 | ||
Some Assembly Required
Friends: (52)
Here's my latest plane with all the power system supplied by Heads Up.
It's an E-Flite Pulse XT 25e 52" wingspan. Motor: 3548-09 outrunner ESC: Power up 60 amp Servos: GWS 24 gram mini servos (4) Prop: APC 13x6.5 E Batteries: two 3S 2200 25C packs in parallel Still waiting for maiden |
Tom
#60 | ||
my stable with all POWER BY JEFF. supercub wing w/ sorta telemaster fuse homebuilt. 2410 with 20 amp esc and 3s 1600. maidened this morning.
starlet w/ same power system. and working my up to this f4c from Shumate plans. |
#61 | ||
All up weight is 17.1 ounces per my scale Flight performance is great pleanty of power for aerobatics and good vertical. Flgiht times are about 10-11 minutes leaving 35%-45% power left in the pack after landing. |
Why is it when I have a 12 of one prop I never break them, but when I only have one it breaks on the first flight.
![]() Current planes GWS Tigermoth 400, Slow Stick Video Plane |
#62 | ||
R/C Work and Play
Club: PaxAero
Friends: (4)
The ever-popular Slow Stick. First build was with a 2410-09Y, GWS 1147 prop, 20A ESC, Servo's and 3s Batt's ALL from HeadsUp.
![]() My latest build is the Slow Stick Boat. Upgraded the motor to a 2836-09 which gives all the vert. I could need w/ the slight addition in weight. Looks sharp too! ![]() ![]() Jeff has been great, and he's recently helped me outfit my new YardbirdRC F-22 (currently in the build) with a 2409-12T, 7x6, ESC, Servo's, Rx..... He's a one stop shop. Thanks!
#63 | ||
Club: Fallbrook R/C Flyers and Oceanside Quiet Flyers
Heres my Heads Up RC powered Ultrafly FW190. It got the Power Up 480 motor and the Power Up 40A ESC.
HZ Super Cub-Retired/ UltraFly FW-190A3/ Multiplex EasyStar/ Eflite SU=26M/ Ritewing TL50/ Blade 400 & MCX/ Pheonix Strega .45/ Nitroplanes Bobcat .75 / Hobbico Avistar 40/ AMA#1,000,000
#64 | ||
Club: RC Dusters, AMA 3875, Sandwich, IL
Friends: (53)
As soon as I get it built, I'll have my GWS Zero with a HeadsUpRC EMax motor toolin' around the field.
Thanks, Jeff! |
- Kev
AMA 873921 RC Dusters Flying Club, AMA 3875, Sandwich, IL Question with Boldness. Hold to the Truth. Speak without fear. |
#65 | ||
Club: ST CLAIRSVILLE RC FLIERS
I replaced the PZ servos with TP MG90 servos in my Stryker. I had to do a small bit of foam cutting and add extensions. So far they've worked really well. I like the idea of metal gears and I think these might be my servo of choice for future planes.
#66 | ||
My latest HURC conversion: T-28 equipped the 480Plus a Power Up 40amp esc, and Jeffs 2250mah 3s.
#67 | ||
Originally Posted by birdDog
Let us know how that setup worked for you. I'm a little concerned that the 2409-12T may not be enough for you. It will be fast, but verticals may suffer. I have a GWS T6 flying with the 2409-18T. I originally bought this motor for a GWS Formosa but put it in the T6 after retiring the 'Mosa The setup: 20.6 AUW; 2409-18T motor, GWS 1060 prop, 20A ECS, 3S 8C 1650 batts. The results: The T6 flies very good on the 1060 prop but the amp draw is at the ragged edge for my 8C battery (13 amps). After a hard session the battery can be a little warm. This setup gives very good performance on everythin except the verticals which die out pretty quickly. A little more power is in order for unlimited verts. Other Props: GWS 9050 is the minimum prop for the 20 oz plane. Flies, but very limited vertical. GWS9075 really rocked this plane but I only had one which I broke after only a few flights. Plenty of power and much longer flight times than the 1060. I really need to get some more ( incoming order Jeff ). On the Formosa: This motor rocked! At 16oz AUW and a GWS1060HD the plane was a demon. I'm currently building a new formosa that will be mostly Headsuprc as follows. Headsup 20A esc, Power Up 400 Sport motor, TP 9 gram servos. Should maiden in the next two weeks. Jeff, you're solid! Keep up the great work. You are my new supplier. I'd expect no less from a fellow Wisconsinite! ![]() 'Cougar |
'cougar |
#68 | ||
Redneck Member
Friends: (29)
Hey Jeff.
I've been a little out of touch lately. I couldn't find your store on E-bay. are you still on there? Thanks for any info....... |
#69 | ||
HeadsUp RC.com
Friends: (4)
Originally Posted by Airhead
I'm no longer selling on eBay. You can find my online store here:
Heads Up RC Have a nice evening! |
Jeff
Headsuprc.com |
#70 | ||
Redneck Member
Friends: (29)
Thanks for the quick reply Jeff.....
#71 | ||
Crasher of things built..
On my second order from Heads Up...and like others here you are now my new supplier.
Modding a MPX Fox with the blue wonder and recommended bat ESC and Prop. I have a pair of Emax 2822's I use in my scratch builds (although I could use the wonder here as well). I have a P-40 on the way that I have yet to order up for....but I like to wait and order as much as possible form Jeff as being the genius that he is, he works the shipping and product mix to use USPS to every ones advantage. Good Business. Glad to see you rise above FleaBay......bet you make more $$ and less hassle. Keep up the good work my friend ...you have earned my business form here on in. Oh yea .....I paraded the MPX FOX thru the LHS and all the guys behind the counter were oogleing the gear...I have your 3 gram servos in there as well as the 3 cell 500mah and the wonder 10 amp esc...nice package....I sent them to your site...maybe they will order in some. Anyway looking forward to my next order....I love hitting that Priority Mail and my TOTAL shipping is $5.00!!!! No matter what I have ordered!! Great Idea Man. TalonOne OUT |
It is what it is......what did you say it is?
#72 | ||
Club: no pack-lone wolf
Friends: (20)
Closing in on final refit to Lanier Shrike converting all old glow to electric. thanks to Jeff at "Heads Up", tough act to follow. Unlike some I have dealt with, parts arrived before I forgot what I had ordered. I call it a platinum momnet. old and blond (grey). The Shrike has the 35-30-10 with 40 amp ESC and 2250 FMA 3S lipo 20 c. looking at somewhere around 20-23 amps according to Jeffs prop chart.
Waiting for carbon landing gear from HC and 4 gm wheels so that I may save a prop or two. Pictures below (I hope) show motor without aluminum cowl. Flashing is super light, malleable and can be removed and reinstalled without risk of damage. Target weight was 32-33 oz and with everything except servo linkages and landing gear, it sits at 1lb 14.9 ozs. could have saved some weight by getting rid of Bond but what the hey. Everyone is sold out of 10x7 APC props and cant seem to find GWS either. Added the red trim just to change the personality. Not sure if the pics show the intakes either side just aft of prop and the excapement behind canopy. intakes came from a Sams choclate chip cookie container...excapement from HP ink cartridge blister pack. Got plenty of those around. Hope to throw this up in the air soon... Thanks for all the help and input Next heads up project...ME 109.. 35-42-10...wil keep you posted. Hope to |
#73 | ||
New Flyer
Club: Tidewater RC
Friends: (7)
Motors, ESCs, & more are Jeff. Hope to maiden this weekend if I can resolve a rudder/steering issue & the weather holds.
Duct tape is like the Force ... it has a light side, a dark side, and it holds the universe together!
AMA 914683 The name is Dan |
#74 | ||
Friends: (7)
Running Headsuprc's 4248-08 in this Hyperion Extra 260 40E and having a blast! Very quiet motor for the $$$$
15 minute flight times of upper and mid throttle with 11x7apc and 4s 5000mAh Flightmax. 15 minutes takes the battery down to about 25%. Pulls a hair over 800watts till the battery settles down. Nice speedy setup! Thanks Jeff!
I know that you believe you understand what you think I said, but I’m not sure you realize that what you heard is not what I meant
-Rob |
#75 | ||
RDRC
Club: Raleigh Durham Radio Control AMA Club #733
New customer for Jeff @ Heads-up RC. I have 3 power sets recommended by him.
Albatross DIII 2836-11 32amp ESC TP 9X6 prop + 9G servos Replacing a Turnigy SK2826-1350 that was running hot. SPAD XIII (under construction) 2830-09 32Amp ESC TP10X5E prop + Elevator/Rudder 9G servos Dr.I Tri-Wing (backordered) 2830-09 32Amp ESC TP10X5E prop + Elevator/Rudder 9G servos |
Kevin
| Tags |
| heads , rc , set , show |
| Heads Up RC--2009 Web Store Front | max-nix | Company Discussions | 19 | 09-13-2012 11:32 PM |
| Thumbs up... to Heads Up RC! | Tinman | iTrader talk | 230 | 07-28-2012 12:12 AM |
| Welcome Heads UP RC to WattFlyer | Mike Parsons | Heads UP RC discussion | 69 | 03-16-2012 10:17 PM |
| *heads-up-rc specials* | aviatordave | Basement Bargains | 3 | 12-17-2008 02:32 AM |
| Rave for Heads Up RC | Gnascher | Company Discussions | 16 | 05-02-2008 01:05 AM |
