Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Company Support Forums > Heads UP RC discussion
Heads UP RC discussion Heads up RC discussion and support. Monitored by Heads UP RC.
Old 04-02-2010, 02:29 AM   #126
Stevephoon
Stevephoon's Avatar
View Stevephoon's Gallery40
Thumbs up Scratch Built Typhoon Fuselage and Pocket Rocket
I've been meaning to post these here for a while, but better late than never!
My StevePhoon-3D
Balsa Fuselage with Typhoon 3D Wings and Tail,
Motor - PowerUp 400 SloFly.
ESC - PowerUp 20 Amp
Servos - 2 9gm SG90e (the really cheap ones!) The original Aileron servos are also still in use.
Flys great with a 1300 mAh 3s battery and a APC 10x4.7 SF prop. It's quite a bit lighter than the stock Typhoon with this setup.
Pocket Rocket scratch build from plans from pd1.
Motor - EMax CF2822
ESC - Mag8 TowerPro 18 Amp
Servos - 2 SG50 5 gm for Tail 1 SG90e for ailerons.
I was worried about how tight this motor felt, but it's been great. Very efficient with a GWS8040 prop and a 1000mAh 3s battery. It never spins as free while at rest as comparied to my other motors. Maybe the magnets are actually better??
Stevens AeroModel Daddy-O 525, Groove G-480
Mountain Models Firestorm, P-51, EVA Sport/Bipe, Dandy/Dandy Sport
Pocket Rocket, Stevephoon 3D, SSPR - Steve's Simple Pylon Racer
DJAerotech Chrysalis 2M-E Sailplane, Misc Foamy Combat Planes.....
Stevephoon is online now
Old 04-02-2010, 02:47 AM   #127
smokejohnson
smokejohnson's Avatar
View smokejohnson's Gallery22
Club: Independent
Friends: (108)
Sweet, the Pocket Rocket looks great.
smokejohnson is offline
Old 04-02-2010, 03:55 AM   #128
Airhead
Redneck Member
Airhead's Avatar
View Airhead's Gallery23
Globetrotter Pilot  Ambassador Award
Friends: (29)
Sweet....
i like the Typhoon job...
Bruce
AMA 873912
Project Globetrotter participant
If it ain't broke, I'll fix it till it is.
Airhead is offline
Old 04-02-2010, 04:01 AM   #129
Airhead
Redneck Member
Airhead's Avatar
Friends: (29)
Hey Fatcat,
Now thats a nice job... Can't wait to hear how she flies... and some more photos please....
Bruce
AMA 873912
Airhead is offline
Old 04-02-2010, 03:26 PM   #130
Fatcat1
Originally Posted by Airhead View Post
Hey Fatcat,
Thank you! I will post more pics and give a full flight report when I get a chance to fly. stay tuned!
I don't have the key to success..but I know how to pick the lock!
Fatcat1 is offline
Old 04-19-2010, 10:01 PM   #131
texasclouds
texasclouds's Avatar
View texasclouds's Gallery472
Friends: (12)
Default I'm a headsup fan now!
Low price + service is the deal maker for me.
PowerUp Outrunner 2712-12
Power Up 10A ESC
2S 800 mah PowerUp LIPO
Final Weight: 10 oz
texasclouds is offline
Old 04-20-2010, 04:17 PM   #132
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
View Voyager2lcats's Gallery58
Club: Not Now- Maybe Never
Friends: (33)
Nice!
Power Up 10A ESC
Final Weight: 10 oz
"Dum spiro spero." (While I breathe, I hope).
Voyager2lcats is offline
Old 04-26-2010, 10:08 PM   #133
wbuttry
wbuttry's Avatar
hey guys will a 3548 900 motor and 50 amp esc with 2 3s2200 in paralell with a 13/6.5 prop have enough power to fly a tower trainer with a 62 in ws and weighing about 5 pounds could you guys let me know
wbuttry is offline
Old 04-27-2010, 12:39 AM   #134
all_up_in_the_air
HeadsUp RC.com
Friends: (4)
I've actually used that exact set up (except for a different ESC) on a Tower Trainer, and it flew great. The only problem is prop clearance. You have to mount the motor a little high, and even then you won't be able to take off from grass unless it's cut quite short. You might consider using a 4S 3200 25C Lipo and a TP 11x5.5 prop, and you will have plenty of prop clearance, and even better performance.
all_up_in_the_air is offline
Old 04-29-2010, 12:33 AM   #135
dmmalish
r/c crash test "DUMMY"
View dmmalish's Gallery14
Club: http://www.facebook.com/home.php?#/group.php?gid=221090112030
Send a message via AIM to dmmalish
Thumbs up christian eagle
4248-06 powered christian eagle with 5cell 4000ma, 13x6.5 prop producing 850watts on the watt meter at WOT.
this is a glow conversion ( http://www.wattflyer.com/forums/showthread.php?t=44553 )
dimensions length is 38" wingspan is 41" weight 4.5 to 5lbs
Name:	christian eagle 008.jpg
Name:	christian eagle 006.jpg
dmmalish is offline
Old 11-17-2010, 02:43 AM   #136
smokejohnson
Club: Independent
Friends: (108)
Running the 2836-22 inrunner on my Stryker, works good. Using my RCSpeedo app I had an average speed of 75mph on honest runs and mid 80's in a dive. Not a speed demon but a good lightweight set up using an 1800mah 3S.
Name:	2010-11-13 07.46.29.jpg
Old 11-18-2010, 08:55 AM   #137
View mclarkson's Gallery4
Outstanding Contributor Award
Here's my newest plane, almost entirely from Heads Up:
GWS Tiger Moth 400
2410-09Y Brushless Motor & 30 Amp ESC
GWS 1047 10" Slow Fly Prop
11.1v 1300mah 20C POWER UP Lipo Battery
9g TP SG90 Sub Micro Servos
Also using a leftover Spektrum AR500 Rx from another project, and 2.5" Dubro wheels from the LHS.
Old 12-08-2010, 05:49 PM   #138
trmcrft
ONEHANDRC
Club: Chain O Lakes Eagles
Default Ace 1/2A Pacer
Just about finished a vintage (1974) Ace 1/2A Pacer I found on RCU. Jeff came thru again with help on the motor size/type. 2830-11 installed.
Keep trying to find excuses to place an order with Jeff. Just can't help myself!!!
trmcrft is offline
Old 12-09-2010, 01:07 AM   #139
Stevephoon
Stevephoon's Avatar
trmcrft,
That's looking very nice! I have the 2830-11 in my MM Eva and it's a great motor. It's been through two flying seasons with zero issues. I'm using a PowerUp 20 Amp ESC and a GWS EP9050 prop as recommended by Jeff. It's a good setup with the EVA. It's actually a little too fast for that plane. I ripped off an aileron once because of high speed flutter.
Old 12-19-2010, 02:31 PM   #140
trmcrft
ONEHANDRC
Tested the Pacer setup Jeff suggested.
175W, 15A, 1800mah 25C lipo, 9 x 6 APC prop. Pacer will weigh 20-22oz AUW.
Should be ballistic!
trmcrft is offline
Old 12-25-2010, 08:23 AM   #141
Built this for my son's Christmas.
2712-12 outrunner
20A PowerUp ESC
5G TP SG50 servos
8030 GWS prop and prop saver
(The ruins of two Mini Super Cubs)
Old 12-30-2010, 11:14 PM   #142
trmcrft
ONEHANDRC
Default Finished-Ace 1/2A Pacer
Thanks Jeff !!!
CG Shock 3D and Fliton Rogue 3D are next in line for the HeadsUpRC treatment.
Pic files won't upload !!
trmcrft is offline
Old 01-06-2011, 02:56 AM   #143
trmcrft
ONEHANDRC
Default Pacer Pix
Still trying to upload pics. Any ideas why I can't?
'Upload of file failed' is the message I get.
trmcrft is offline
Old 01-08-2011, 12:30 AM   #144
trmcrft
ONEHANDRC
CG Shock 3D. HeadsUpRC 2830-09 motor, Power Up 3S 1800 lipo.
trmcrft is offline
Old 01-08-2011, 03:02 AM   #145
Yay! Glad you solved your upload problem.
Old 01-08-2011, 03:27 AM   #146
trmcrft
ONEHANDRC
ONLY on that pic! Still can't upload the Pacer! Even tried resizing it.
Finally! But too much backround clutter (airplanes!)
trmcrft is offline
Old 01-28-2011, 01:21 AM   #147
Wrench66
Ya' need to use mo rudda!
Wrench66's Avatar
View Wrench66's Gallery33
Club: Chino Renegades RC Flier's
Friends: (20)
Here's a couple of recent builds powered by Jeff's outrunners and props
Been there since the beginning for me, customer service is what got me...that's for sure
--Ray
ID:	142459 This one is a 37" wing span 20oz sport plane powered a Heads Up 2410-12D outrunner using a 9x7.5 GWS prop. This plane is very fast and aerobatic, I'm actually over propping the motor but it pulls the extra amps just fine.....Watt metered @ 21A on 3s
Name:	Tiger moth take off.jpg
ID:	142460 This GWS Tiger Moth fuse and scratchbuilt wing and tail assy runs an Emax 2822 outrunner with APC 8x6 prop. This is another setup that runs extremely strong on a 3s 1000mah battery.
Man, gravity is ALWAYS wanting something from me
Wrench66 is offline
Old 02-16-2011, 03:11 AM   #148
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery38
100mph Speed Demon  3kW  1kW  WAA-08 Pilot
Friends: (65)
Heres my hottest ticket now, thanks to Jeff at heads up.
Nitro Blast is offline
Old 02-16-2011, 03:46 AM   #149
LipoPilot
Flown A Lipo Lately?
LipoPilot's Avatar
Club: How Much Is The Cover?
Send a message via Yahoo to LipoPilot Send a message via Skype™ to LipoPilot
Scratchbuilders Award
Friends: (25)
Default I Use Jeff A Lot...
Some of my Heads Up R/C powered flying machines....
Thanks For The Airspace,
Lipo Pilot
My Website My Videos My Twitter R/C Liveshow
LipoPilot is offline
Old 02-16-2011, 04:28 AM   #150
I hate to post it, cuz it's not Jeff's fault at all.
Made entirely from scraps and leftovers, including
EMAX CF2805 2800KV motor
GWS 5030 prop
TowerPro 5G servos
PowerUp 10A ESC
Despite its ghastly looks, it's actually a sweet, fun plane to fly.
http://vimeo.com/19962267
Tags
heads , rc , set , show
Heads Up RC--2009 Web Store Front max-nix Company Discussions 19 09-13-2012 11:32 PM
Thumbs up... to Heads Up RC! Tinman iTrader talk 230 07-28-2012 12:12 AM
Welcome Heads UP RC to WattFlyer Mike Parsons Heads UP RC discussion 69 03-16-2012 10:17 PM
*heads-up-rc specials* aviatordave Basement Bargains 3 12-17-2008 02:32 AM
Rave for Heads Up RC Gnascher Company Discussions 16 05-02-2008 01:05 AM
Page generated in 1.57879 seconds with 80 queries
