Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > General Topics > Member Product Reviews > Aircraft Reviews
Aircraft Reviews Member based Reviews on ARF's and Kits Open for Business!
Comment
Review Tools Display Modes
H/L StarMax JAS-39 Gripen RTF
A Great Intro to EDF!
Published by K CLOSE
02-17-2009
Thumbs up H/L StarMax JAS-39 Gripen RTF
I bought the StarMax Gripen JAS-39 from Hobby Lobby as a RTF package. My hope was to get in the air with my first EDF using a plane I hadn't spent hours building in case things should end suddenly. To that end the Gripen has been fantastic. To be fair the Gripen was not the first EDF RTF I bought for this purpose. The first EDF plane I got was a huge disapointment, so when the Gripen was still on the way I researched the model here on Wattflyer. The search function didn't produce any threads, so I posted one in the EDF fourm. (See that orignal thread here - http://www.wattflyer.com/forums/showthread.php?t=39270 )
SHIPPING
The plane arrived in good order, boxed in the standard Hobby Lobby fashion of a heavy outer box protecting the inner. I tossed the box before thinking to write this review, so unfortunately I don't have any pic's of the parts "in situ" in the box. Everything was well packaged though, and none of the included parts had been damaged in shipping. During this initial inspection the plane was found have a few minor issues, however. The canopy was missing, and the included 11.1v 1300mAh battery was wired to it's Deans connector in reverse. I placed a call to Hobby Lobby who rectified the issues right away (I will touch on this again at the end of the review). They mailed a canopy to me, and they allowed me to re-wire the battery - with the understanding that if I damaged it in the attempt they would replace it. The battery repair was straight forward, and the canopy parts bag included a spare nose cone- BONUS.
BUILDING-
Really there wasn't much in the way of building , as it should be with a RTF. The instructions were a high quality book, that really could have consisted of just the one page that covered actual assembly. I made some changes based on what I learned from fellow Wattflyer bhatch21, and to my tastes.
ID:	94147 Click image for larger version
I'm a big fan of GWS glue, and use it when ever I want things really light, so the wings were glued on with that. Thanks to bhatch21 I turned the main landing gear around so they are farther forward.
Set up this way it needs the battery in the hatch to keep the nose gear on the ground, but it rotates nicely for take off. The nosewheel was installed 180* out, so I had to remove it and turn it round.
I removed the hard plastic conduit from the bottom of the plane. My reasons were that A) it seriously restricted airflow over the speed controller and B) I felt it detracted from the way the plane looked. I glued a thin birch ply cover over the R/X, taped down the wire leads and taped/rubberbanded down the speed controller.
ID:	94079Click image for larger version
I also lined the thrust tube with a thin glossy hard paper tube I made. Everything I had researched stated that smooth is best, and the stock area aft of the fan was very rough stryo. I was very careful not to change the shape or size of the thrust tube, just line it. I probably didn't do anything other than add weight, but it made me feel better.
The elevons were given a full 1/4" up reflex (or trim) for the first flights. Set this way the plane is nice and stable with little or no tendency to drop the nose.
The water slide decals that were included worked really well, and were a welcome relief from the more common stickers.
The included battery charger was redundant for me as I use a Hobbico, but for the purpose of this review I've used it a few times. It seems to work nicely, although a it is a bit slower then I'm used to.
The T/X is on par with a P/Z or similar item, maybe a bit nicer even.
FIRST FLIGHTS
I was pleased with the advice I got from bhatch21 and Angler-Hi about the maiden. Waited for a dead calm day as I always ry to do for a maiden flight. I was able to put a few batteries through the plane, as I have a bunch of 25/30C 1300mAh 11.1's. The roll outs did require a long runway area, and the JAS-39 needs to be flown off the ground. Don't expect to punch the throttle and watch the Gripen climb out like some models do, you have to lift it off. Provided you have the room that's not a problem though, and infact the models manners are very nice.
It is not a very fast jet, in fact most of my prop planes would smoke it. But as a first EDF I was OK with that, and I found the low speed manners invited experimentation (like my second time flying the Gripen) For once I found that everything in the Hobby Lobby video was stuff I could make the model do (not that those guys are misleading, just that they can FLY).
CONCLUSION
To my mind a RTF package really lessens the heartbreak when you stuff something into the ground when learning something new. I find where most find E-flight confusing, they find EDF's pure voodoo. Granted this JAS-39 is no ball of fire, but thats not the point is it? It is a stable, decent quality package at a fair price from a reputable vendor. I have to address Hobby Lobby's staff at this point. The first EDF RTF I bought was a disaster. H/B put it right and sent me the StarMax. When the Gripen was missing those few bits I was sure they would write me off as a cronic complainer. They didn't, and they were pure professionals from start to finish. I feel I owed it to them to state that.
PROS:
Quaility kit with a realistic 2 hour box to air time.
Stable in flight manners, slows very well.
Good size, and pretty easy to track in the air for a jet.
Easy intro to EDF's.
CONS:
Foam quality is good, but could be better.
Not very fast out of the box if thats what your expecting.
Specifications
Wingspan: 22 3/4" Overall Length: 42 3/4" Wing Area: 312 sq in Flying Weight:20oz
Equipment Used:
Motor: included brushless Speed Control: included 25amp Servos: 3 included micros Battery:11.1v 1300mAh
Retail Price:
$200.00
Manufacturer
StarMax
Author review
Kit Instructions:
80%80%80%
8
Materials & Packaging:
90%90%90%
9
Ease of Build & Finish:
100%100%100%
10
Design & Appearance:
100%100%100%
10
General Flight Characteristics:
100%100%100%
10
Performance Capabilities:
80%80%80%
8
Average 92%
Member rating
There are no ratings to display
Experience Level Advised
Intermediate
References
http://www.hobby-lobby.com/jas-39.htm
Review Tools
Show Printable Version  Email this Page
Old 04-10-2009, 03:03 AM
max2112's Avatar
max2112 max2112 is offline
WG1 Pilot #2
Default Great review.
Job well done on the review, K Close.
How is she doing? Have you had the chance to really get to know the plane better?
John
__________________
Please call me John... I came up w/ Max2112 when I thought you all were internet predators after me LuckyCharms!
Old 05-03-2009, 06:43 AM
K CLOSE's Avatar
K CLOSE K CLOSE is offline
Huge Member
Thanks John, I tried to be accurate. The Gripen is still in great shape and I still really like it. As I've flown it more, I can say I'll will likely up the battery mAh for longer flight times. I also wouldn't mind more power for a steeper climb out. I've almost clipped a few trees on protracted take offs. That might be a weak battery situation tho'. It's currently my only flying EDF, and it's always a fave-rave with observers. All in all I still give the Gripen a full "thumbs up". I really like this little jet and I'll be sad when I stuff it ( which is somehow the un-avoidable fate of all my planes).
__________________
Project Globetrotter
Old 09-18-2009, 04:27 PM
K CLOSE's Avatar
Huge Member
Well, the end of August was the "stuff date". I was fooling around trying to stall it in towards the end of the flight. The cheap Lipo she came with has been getting shorter flight times with each use, and I knew I was pushing my time limits. Power cut out, she slid backwards. I was able to turn around and level off--right into a pricker bush. I mean a BIG pricker bush. She held up pretty well considering.
ID:	109419Click image for larger version
ID:	109420Click image for larger version
ID:	109421Click image for larger version
Maybe it's mod time.
ID:	110398 New foam sectioned into upper duct
ID:	110399 new foam sectioned into lower duct
__________________
Old 09-23-2009, 12:32 AM
Bombay Bombay is offline
Nice review. So would you reco this as a first time edf jet?
Old 09-25-2009, 07:01 AM
K CLOSE's Avatar
Huge Member
Whole heartedly! It is NOT a good first plane, nor would it be a good first step off rudder/elevator. But if you been flying low wing warbirds and wanted to go EDF jet, absolutely its a good choice.
Oh, and thank you.
__________________
Old 10-07-2009, 02:16 AM
chris123sc's Avatar
chris123sc chris123sc is offline
Dead on spot for the review. Have one of these myself, exact same arf. Put a berg 4 channel in mine and your review was a mirror of my experience. This is a great first edf, but no edf should be a first plane. Go with a trainer or slow stick type to learn. This one isn't that fast, but fast enough to lose track of if you're not used to speed at all. The large delta wing floats in nicely for landings. The only problem I've had was as you mentioned, doesn't do hand launches well at all and takes a pretty good distance to take off with the provided hardware. Would have saved myself some heart ache if this would have been my first jet.
Comment
« Previous Review | Next Review »
Currently Active Users Viewing This Review: 1 (0 members and 1 guests)
Review Tools
Review Review Starter Category Comments Last Post
Hobby Lobby / Starmax F-5 Lieutenant Loughead Electric Ducted Fan Jets 23 10-02-2009 02:15 PM
Any thoughts/tips on the Starmax JAS-39 Gripen? K CLOSE Electric Ducted Fan Jets 18 10-07-2008 05:23 AM
For Sale JAS-39 Gripen Jet RTF EDF joedoe Airplanes - Electric For Sale & WTB 0 06-15-2008 08:39 PM
StarMax F/A-18C!? VF84sluggo Electric Ducted Fan Jets 25 04-08-2008 04:58 PM
walkera 39 rtf timothysplante Micro Sized Electric Helicopters 2 12-12-2006 08:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Page generated in 0.46076 seconds with 39 queries
