Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Vintage and old timer models
Vintage and old timer models Discuss nostalgic vintage aircraft
Old 02-21-2009, 09:15 PM   #1
gittarpikk
CrazyBall Designer and OT
gittarpikk's Avatar
Club: Volunteer AeroModelers, Knoxville Tn
Default Begin Skampy (super lite) build
Ok, I have began the Redesign and build of an old favorite..the Ace Skampy .. originally designed by Owen Kampen and kitted by Ace. Was in the Dec 67 issue of RCM
There were several people who built it, some had good results, some , like me , noticed it flew OK (mine was heavy and snapped a lot and glided like a brick) but something was wrong.
There is another thread somewhere that a couple people are starting one. I decided to "fix" the problems an one of them is weight (all the sheet balsa) and the other seems to be the high angle of wing incidence and stab negative incidence. This was acceptible for Rudder only as it kept a positive inciudence needed to make turns without an elevator as in rudder only flying.Only problem I see is it created a sortof controlled "mush" on deasdstick as there was no throttle on the .020.. added to the weight, caused a snap easily. This one I am using rudder and elev (will cut them in later) a screaming .010 TD and maybe in the future convert to electric and throttle. Radio weight should be close to original actuator, reciever and batts but will have more channels. I have reduced the wing incidence to about 1/5 and the stab incidence to nearly zero.
This should cure the mush tendency as well as make it more of a floater as the all up weight is going to be less than 1/2 and maybe closer to 1/3 the original.
I am uploading the picts,You more experienced old timers will be able to easily figure it out from the pics. I will do a separate thread on the dowel edging later.
www.CrazyPlanesRC.com Designer/developer CrazyBall Design
gittarpikk is offline
Old 02-21-2009, 09:25 PM   #2
gittarpikk
gittarpikk's Avatar
Default picts added more later
here are some pics
ID:	94372   Click image for larger version
ID:	94373   Click image for larger version
ID:	94374   Click image for larger version
ID:	94375   Click image for larger version
Name:	Skampy bones.JPG
ID:	94377   Click image for larger version
ID:	94378   Click image for larger version
ID:	94379   Click image for larger version
ID:	94380   Click image for larger version
Old 02-21-2009, 09:29 PM   #3
gittarpikk
gittarpikk's Avatar
Default more pics
here are more pics
ID:	94387   Click image for larger version
ID:	94388   Click image for larger version
ID:	94389   Click image for larger version
ID:	94390   Click image for larger version
Old 02-21-2009, 09:35 PM   #4
pd1
Still Learning
pd1's Avatar
View pd1's Gallery69
Club: Cape Ann RC Model Club
Friends: (53)
Wow, pink balsa.
Looks nice.
Paul
pd1 is offline
Old 02-22-2009, 11:36 PM   #5
gittarpikk
gittarpikk's Avatar
Default Pink ain't that bad!
Originally Posted by pd1 View Post
Wow, pink balsa.
Looks nice.
Paul
Especially after its painted!....mebe I ought leave it pink...they say chicks are attracted to pink,,,,lol
Here it is on tha' scales
Old 03-02-2009, 01:40 AM   #6
gittarpikk
gittarpikk's Avatar
Default Skampy update
Here it is, painted minus trim, with all flying surfaces and cowl. 3.0 OZ Aileron tubes installed, all hinges will be dacron thread (yep , old school) .
When weighed with all surfaces TD .010, Berg receiver,2 servos and cowl was 4.8 OZ, minus LG and rec batt. I should be all up about 6 OZ well below the 8 OZ unloaded of the original..and have 3 channels
If I did an electric, would probably weigh in at 6 OZ full house!
Old 03-02-2009, 01:59 AM   #7
pd1
Still Learning
pd1's Avatar
Friends: (53)
1. What did you paint it with?
2. When are you going to expand on the wrapping edges with a dowel?
pd1 is offline
Old 03-02-2009, 02:38 AM   #8
gittarpikk
gittarpikk's Avatar
Default Paint
Hi Paul
I used the Acrylic / Airbrush method with Yellow Acrylic from Wally World. I first prepared the surface with a mixture of DAP Light and final spackle with about 50% windshield washer fluid the first time then 50% alcohol the second time (windshield washer fluid is better as the DAP comes somewhat out of solution and sticks to the brush too much). I used 220 wet or dry used dry and then 320 and 400 to finish. I still have to put a coat of clear poly-water base yet after I do graphics.
I am thinking of trying a 3 D winners flag and 3 D pylon race number .I got in a hurry , did not wait on the weather to clear and succeeded in dusting everything in my pro sound room, shop and office with a coat of dust...Got so sick of it, decided to wait a bit till weather warms ( a few days) and I can open all doors and clean it all off and start finishing the Skampy, the All Star Bipe and the 2 2/3 Rumplestadts. Still got the supesized Chief, the Mach None and one other to finish.
I gots ta hurry though, when building weather arrives, gonna be vinyling the house, new windows/doors and starting an addition.... that's not gonna be long.
I think I'll be able to get the Skampy and the Allstar flight ready before I start the remodeling.
BTW, I discovered something I will have to figure out with foamcore . When a nice perimeter is used, any temp/humidity (not sure which) swings will cause it to warp (I don't think pure depron will do this) . I think also if a fast finish is applied to the foamboard surface after putting on trim perimenter, it does not warp near as bad.
Some I'm not real happy about that factor at this time. Looks like a bit of experimenting to explore all the variables is in order.
The Skampy surfaces were so small, it didnt affect it, but the Allstar warped ,and the Chief (larger yet)did as well.
Old 03-02-2009, 05:14 PM   #9
soar-ne
Omaha Ne.
Gittarpik:
I have found that by laying a straight hard balsa "spar" on the hingeline of the ele & rudder will pretty much stop the foamcore from warping.
Also some foamcore sheets are just more prone to warping that other, even the same brand. Must be just the way they were rolled out or the temperature wasnt just right when it was produced.
One of the mysteries of life I guess........
Great looking build by the way!!!!!
Bob
soar-ne is offline
Old 03-02-2009, 07:33 PM   #10
gittarpikk
gittarpikk's Avatar
Default I do that too
Hi, thanks for the comment, I start out with this and then also add the balsa spar on both the stab and the elevator...and same on the rudder and fin.... The Skampy's surfaces did not warp...but the larger Allstar and Chiefs surfaces to quite a lick
prior to hinge spars
Old 03-28-2009, 10:28 PM   #11
gittarpikk
gittarpikk's Avatar
Default Here is why...
I haven;t got to finish the Skampy yet.. I've been working on my flight box (my design) I decided to "practice" my airbrush techniques(this is my first airbrush job) on my filed box first.... then the Alstar Bipe, then last the Skampy since its so small. I will be doing the 3 D flag and ole #7 on the Skampy
ID:	97472   Click image for larger version
ID:	97473   Click image for larger version
Old 04-02-2009, 03:14 AM   #12
gittarpikk
gittarpikk's Avatar
Default Here is the Dynamic Duo!
I airbrushed the Skampy... not done just yet..
Tags
.010 , .020 , ace , owen kampen , skampy
SUPER Quick Delta Scratch Build CHELLIE Delta & Flying Wings 894 10-03-2011 07:36 PM
E-flite Super Airliner Build Thread SuperAirlinerfreak101 Electric Ducted Fan Jets 106 11-22-2009 05:55 PM
Formosa II SUPER-LITE!!!! stevecooper Foamies 69 01-27-2008 04:16 AM
Super Star EP build question fredz Beginners 3 11-17-2007 01:49 AM
E-Flite Super Airliner build firemanbill Electric Ducted Fan Jets 52 09-10-2007 06:27 AM
Page generated in 1.18558 seconds with 65 queries
