Old 07-19-2009, 07:37 PM   #1
e-sailpilot86
Default A123 2300 mAh soldering bars?
I see that hyperion makes some, I found a site that has them listed but with no price, probably out of stock. (aircraft-world) Where have others purchased them from? Cells are going to be on the way soon.
e-sailpilot86 is offline
Old 07-20-2009, 06:08 AM   #2
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
I couldnt find any bars when I was building my packs so I used 12 ga solid coper electrical wire. I ran 3 strips between each cell for extra current handling and to lower the resistance.
I think I need a signature.
Larry
Larry3215 is offline
Old 07-20-2009, 04:41 PM   #3
Fast Guy
I use the large size battery bars for assembling any Sub-C NiMH or NiCd battery packs. They don't reach center to center on the cells but do reach with good coverage on the sodering buttons on the A123's. Built 4 packs like this and they have many flights with no failures.
Fast Guy is offline
Old 07-20-2009, 04:43 PM   #4
Matt Kirsch
Matt Kirsch's Avatar
Desoldering braid makes a great battery bar.
Matt Kirsch is offline
Old 07-20-2009, 04:48 PM   #5
Friends: (16)
mofosheee in another thread has used those "U" shaped copper hanger strips commonly used to hang copper pipe used in water pipes. Just make certain its pure copper, not some plated stuff, hammer it flat, cut it to shape, and solder away!
New 07-22-09
I just bought a package of these straps for 3/4 inch copper pipe at 10 pieces for $1.69, (made in China) Hammered flat, they measure 0.018 inches thick, 0.475 inches wide, and 3 inches long. Each piece can be cut in two, giving you 20 pieces for less than a dime each. The area of these straps is about equivalent to #10 wire.
I found that the straps I bought appear to be copper plated brass sheeting. A quick check with my high current power supply showed that each strap will have about a 0.01 volt drop at 50 Amperes, so a 6S2P pack would have about a 0.05 volt loss at 50 Amperes with five of these straps. FYI, watts equals volts X amps, or 0.01 X 50 or 0.5 watts, not nearly enough to cause any heat build up.
That voltage drop would be about 4 times less with pure copper bus bars, since the resistivity of brass is about 4X that of copper. So, take your choice, copper plated brass at your local hardware store, or pure copper straps that might be a little more difficult to obtain.
Take a look at the attached photo.
Old 07-20-2009, 08:02 PM   #6
e-sailpilot86
How easy/hard was it preventing the central vent from being clogged with solder?
Old 07-20-2009, 08:08 PM   #7
Larry3215
Larry3215's Avatar
Central vent?
If thats supposed to stay open - then I screwed up on all mine!
Larry
Old 07-20-2009, 09:02 PM   #8
e-sailpilot86
Uh oh.... Might want to fix that, even if it's with a tiny drill bit. Supposedly, if and when the cells do need to vent, it is not like a lipo going CATO, but it might pop a bit differently if it does get a bit under pressure.
I wanted the Hyperion solder tabs because they're great at keeping the central vent clear.
http://www.youtube.com/watch?v=vkDgoXikI_8
Old 07-20-2009, 09:14 PM   #9
Friends: (16)
larry3125
Central vent?
Interesting. I'm holding in my hand a two cell A123 pack built up by www.battlepack.com. Battlepack absolutely soldered shut both vents on the two cells.
Suspect that battlepack has been doing this awhile, so don't know just how important those vents are.
BTW, last year, I accidentally shorted out a cell on the Dewalt DC 36 volt batteries, burning a small hole right through one cell. All remaining cells are still in use, but that one cell with the hole in it went flat after a few months.:o I'd tried to solder it shut, but the case is aluminum so that didn't work. Tried to put a drop of epoxy on it to seal it up, but that epoxy slowly got a few bubbles in it, apparently from a very slight pressure inside the cell???
So, don't know if drilling a small hole in them would be a good idea.
Old 07-20-2009, 09:15 PM   #10
Larry3215
Larry3215's Avatar
I have directly shorted my packs three times now. Two times there was enough current flow to melt the solder at one of the cells.
The second time one of the cells did fail, but there was no "event" at all and no noise.
The cell went to zero volts and that was that.
I'll definately keep it clear next time!
Larry
Old 07-20-2009, 09:19 PM   #11
e-sailpilot86
Of course, having the cell vent clear assumes that it may vent at some point... I do not believe they regularly release gas like a lead acid. Keeping them clear is always a good idea anyway. That is why I do not like end to end soldering, not to mention the cells cannot be balanced when assembled that way. I purchased loose cells from battlepacks, they're going into a Maule and other models I already have. BTW, they are the new plastic wrapped cells that are slightly better than the cardboard wrapped ones. I think I'll make a parallel plug as well.
Old 07-20-2009, 09:25 PM   #12
Friends: (16)
e-sailpilot86
Plastic wrapped? Is that the transparent light green wrapping with A123 systems labeled on it?
That's how my two cells came in from www.battlepack.com.
Old 07-20-2009, 09:32 PM   #13
Friends: (16)
larry 3125
Directly shorted your A123 pack? Lets see, A123 rates their cells at between 0.01 to 0.015 ohms resistance, something I've verified with my 500 watt load resistor. Now, I=E/R or 3.3/0.015 or around 220 amperes out of that cell.
I used a Sears Craftsman #82369 DC clamp on ammeter to measure the starter current on my old Chev S10 pickup. That measured 135 Amps!
(That clamp on ammeter has DC ranges of 0-40 and 0-400 Amps, allows measuring current by just clamping its jaws around one of the battery conductors. I checked it against my Fluke 87V, its accurate to a percent or three!)
Old 07-20-2009, 09:58 PM   #14
e-sailpilot86
e-sailpilot86
Yes. Those are the ones I will be receiving. They all used to be like the DeWalt cardboard ones, the new ones have lower internal resistance, are a few grams lighter, and ship with the voltage in much tighter tolerances than the cardboard tube ones did. And mind you, someone on RCG (can't remember exactly... southern cross IFO avatar?) ran tests on the older style cells, with around 100 cycles, and didn't need balancing until a few cycles after 100. And they are still going strong. Future looks good for electrics, doesn't it!?
Old 07-20-2009, 10:51 PM   #15
Larry3215
Larry3215's Avatar
larry 3125
Directly shorted your A123 pack? Lets see, A123 rates their cells at between 0.01 to 0.015 ohms resistance, something I've verified with my 500 watt load resistor. Now, I=E/R or 3.3/0.015 or around 220 amperes out that cell.
The cell voltage at those loads was probably more like 1/2 that value - under 2 volts certainly, but it was still a LOT of juice! The heat shrink melted over all the terminals and like I said - it de-soldered one cell!! After that I went to 3 (up from 2) 12 ga copper wires between each cell.
Thats Charles (Everydayflyer) you're trying to remember. He is THE battery guy
And yes - it sure is looking good
Larry
Old 07-20-2009, 10:54 PM   #16
Friends: (16)
e-sailpilot86
Agreed, I've cycled 250 Ampere Hours through each of my 6S2P A123 packs, and they have the same exact performance as when new, last year. That corresponds to a measured 11 hours of actual in the air flying time on each of my three 6S2P A123 packs. And, those A123 packs actually wore out my Walmart Engine Starting Deep Cycle battery in only one flying season!
My Great Planes "Revolver" is running a Hacker A40-10S motor, pulling 62 Amps full power on a 14X10 APC-E prop, turning at 7850 RPM with a 6S2P A123 pack. Model has been tracked at 88 MPH, straight and level.
Old 07-21-2009, 06:59 AM   #17
e-sailpilot86
Everydayflyer, that's him. I find it amazing how many batteries he gets to go through AND how many times he uses them. He is the man when it comes to finding the good batteries to buy. And the charts and graphs.... perfect, why I don't do that myself... I should! I think I might be able to with my new charger, it only charges though, no discharging. (TME Xtrema...)
11 hours of flying... that is spectacular! I've had some of my lipos be not so good after even 5 cycles!
Old 07-21-2009, 08:20 PM   #18
Friends: (16)
e-sailpilot86
New charger can't discharge?
One of the past members of our club had a very nice gasoline powered (Twin G26?) Twin engine Model that he flew several years ago. Very shortly after take off, he lost all radio control. The model crashed full speed about 1/4 mile away. Total loss, even the two engines were busted up.
Cause, he had just picked up a new nicad battery charger/cycler. And, he used it on the new receiver battery. Problem was, he misread the charger instructions, and discharged the pack, rather than charging it. Took off with a freshly disharged battery. The model was worth well over a grand.
For Sale A123 cells, 2300 size JWilliams Batteries and Chargers Forsale/WTB 11 01-14-2009 05:25 PM
A123 / BlaCK & DECKER vpx 1100 mAh everydayflyer Batteries & Chargers 31 11-12-2008 05:36 PM
Hitec Neon problem in FMS - Bars 1-4 blank Wayne Miles Flight Simulators 2 02-18-2008 11:36 PM
Method for fixing brocken skid bars Tyrant Blaze Beginners - Helis 2 01-24-2008 10:58 AM
so who is flying the A123 / BlaCK & DECKER vpx 1100 mAh ?packs? EpoweredRc Batteries & Chargers 11 12-23-2007 10:55 PM
Page generated in 0.42003 seconds with 56 queries
