Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > For Sale & Wanted Forums > Basement Bargains
Basement Bargains Know of a good sale at your favorite online RC webstore? Or how about just one heck of a bargain that you came across on RC goods. This is the place. ** No commercial adverts please**
Old 07-29-2009, 03:56 AM   #1
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (52)
Default $10 PC Power supply
$10 shipped. Can't beat that.
http://www.smksuperstore.com/product....ashx?ID=33081
Tom
Grasshopper is offline
Old 07-29-2009, 05:50 AM   #2
groundrushesup
groundrushesup's Avatar
View groundrushesup's Gallery45
Club: Hill Country Wattheads
Send a message via AIM to groundrushesup
1kW
Friends: (20)
Originally Posted by Grasshopper View Post
I'm all over it. My current [NPI] 200W PC PS conversion is starting to sound a bit wheezy.
Thanks for the heads-up, good sir. I just ordered one. Now to dig up that box of sandbar resistors....
GRU
Everybody's Somebody at The Hill Country Watthead's Thread!
Stop in and see what we're up to!
Visit Our Youtube Channel, too!
groundrushesup is offline
Old 07-29-2009, 06:03 AM   #3
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
are these what are used to convert field chargers to ac power?
Rolling Thunder is offline
Old 07-29-2009, 08:14 AM   #4
View CHELLIE's Gallery13
Friends: (281)
Yes your right here is a link on how to do it, Its not hard to do, I made one from a old comp power supply, Take care, Chellie
http://www.marcee.org/Articles/PCPowerSupply.htm
Old 07-29-2009, 04:30 PM   #5
av8djc
Old Fart
av8djc's Avatar
Club: Several
2kW
Ordered mine today. Thanks Chellie!!!
Dave
AMA 494
Inside every older person is a younger person wondering "What the heck happened?"
av8djc is offline
Old 07-29-2009, 09:53 PM   #6
dbcisco
Like to build 'em
dbcisco's Avatar
View dbcisco's Gallery9
Friends: (7)
Just ordered one, my PC power supply just started acting up. Needed this.
dbcisco is offline
Old 07-30-2009, 01:05 AM   #7
Friends: (281)
http://www.wattflyer.com/forums/show...r+power+supply
A Little more info on converting a comp power supply and My Power supply conversion I cleaned up all those extra wires since that pic was taken
Old 07-30-2009, 01:20 AM   #8
dbcisco
Like to build 'em
dbcisco's Avatar
Friends: (7)
...I cleaned up all those extra wires since that pic was taken ..
Thanks Chellie. I was worried. Didn't want to loose you in an electrical accident
dbcisco is offline
Old 07-30-2009, 01:31 AM   #9
Friends: (281)
My Family members would not mind, Then They can collect on my Life Insurance Policy LOL Take care, Chellie
Old 07-30-2009, 04:25 PM   #10
av8djc
Old Fart
av8djc's Avatar
Club: Several
2kW
Chellie
I see an abundance of wires going into your plug-in box. That leads me to believe you parallel all 12v leads to feed the charger. I had thought any one lead for 12v +and- would do it but perhaps you only get the maximum watts out by paralleling all 12v leads???
Cute little light on top, looks really space age.
Dave
AMA 494
av8djc is offline
Old 07-30-2009, 04:42 PM   #11
smokejohnson
smokejohnson's Avatar
View smokejohnson's Gallery22
Club: Independent
Friends: (108)
FWIW I only run one set of wires out of the PS and it powers my chargers fine. I have a Triton and 2 of these that I run all at the same time.
smokejohnson is offline
Old 07-31-2009, 05:34 AM   #12
Friends: (281)
Originally Posted by av8djc View Post
Chellie
Hi av8djc yes I paralled the yellow wires and the black wires as per the instructions, to make sure i would get the full amps from the power supply, and i belive the green wire is the load wire going to the lic plate light, to make the power supply work, I power up 2 Astro 109 chargers and 1 electrifly charger all at the same time, works great for me, and it was FREE Take Care, Chellie
Old 07-31-2009, 05:40 AM   #13
Friends: (281)
Please Someone thank me its showing 666 on my thanks and i want to get passed that Take care, Chellie
Old 07-31-2009, 06:05 AM   #14
Rolling Thunder
lol,oops chellie my bad.I always forget to do that
Old 07-31-2009, 06:09 AM   #15
Friends: (281)
Hi RT I needed to get passed that terrible number Take care and have fun, Chellie
Old 08-03-2009, 10:47 PM   #16
Rolling Thunder
I got my power supplier today.Now I just have to figure out how to hook it up-yikes
Anybody else got theirs & any pics of how they converted it
I was thinking cant I just use the alligator clips on my field charger & splice into the 12v DC line to power it.Along with a resistor
Old 08-03-2009, 10:55 PM   #17
dbcisco
Like to build 'em
dbcisco's Avatar
Friends: (7)
Should be here by Weds.
FedEx is taking longer to get it out of California than the post office can get parcels to me from China! Tracking info says it took three days to get from Anaheim to Bloomington, about 45 miles (45 min. drive). And then it sat at Bloomington from Fri. to Mon.
dbcisco is offline
Old 08-04-2009, 02:06 AM   #18
groundrushesup
1kW
Friends: (20)
You need to have a multimeter so you can isolate all the voltage rails. Put the 10ohm/10W resistor on one of the 5V rails, and mount it flush against the side of the case so it will conduct as much heat out as possible.
Heck, here's the best HOWTO I've found on this so far.
You can eliminate the other rails he uses if you just want one or two 12V supplies. I will build in the 5V so I can power my servo tester or receivers.
GRU
Old 08-04-2009, 02:26 AM   #19
Rolling Thunder
so you have to use the wires inside the box.you cant just splice into the wires that are outside the box.and i do have a multimeter,thanks-RT
Old 08-04-2009, 02:30 AM   #20
Friends: (281)
Here you go RT http://www.marcee.org/Articles/PCPowerSupply.htm
Old 08-05-2009, 02:58 AM   #21
Rolling Thunder
well I plugged in my power unit today and nothing.No power.its a piece of junk.good luck with yours
Old 08-05-2009, 03:11 AM   #22
dbcisco
Like to build 'em
dbcisco's Avatar
Friends: (7)
A PC pwer supply will not turn on just by plugging it in. An on/off switch needs to be installed. Normally the power supply is "activated" when connected to the motherboard and not by itself. Pin #14 "green wire"
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
See this site for details: HERE
dbcisco is offline
Old 08-05-2009, 03:16 AM   #23
Rolling Thunder
thanks I'll try it.it does have an on off power switch on the front
Old 08-05-2009, 03:24 AM   #24
Friends: (281)
Hi RT you need a small load on the power supply before it will start to work, i used a LIC. Plate Light assy. and i did not need to use a resistor using that light, a 1157 or 1156 or 1155 Light bulb will work well.
[Next choose a location on the PS case to mount the automotive light socket. Mount the light and connect it to a "Common" wire and to a +5 volt (yes plus five volts) wire. You need a small "load" on the +5 volt side of the PS in order for it to put out it's maximum voltage on the +12 volt lines. Some folks use a 1 ohm 25 watt resistor. E-zone is full of opinions on this but I find a small load works fine. If you are not getting slightly over 12 volts of output on the "posts" you can add a second light by connecting it to a "common" and a +5 volt wire. ]
Old 08-05-2009, 03:51 AM   #25
Rolling Thunder
it works!!
thanks dbcisco,I had the lightbulb hooked up the first time but there was nothing.Then when I shorted the green wire the light came on.Thanks all-RT
so I guess I have to leave the green wire shorted the whole time then
Using PC Power Supply to Supply Car Adapter w/ 12V DC theluckyone17 Batteries & Chargers 17 10-17-2010 05:59 AM
Sold 12 Volt PC Power Supply Grasshopper Batteries and Chargers Forsale/WTB 1 03-07-2009 06:22 PM
Question on using PC power supply Jetskeeter Batteries & Chargers 10 07-03-2007 06:26 PM
Question regarding using a PC power supply to run a Lipo charger... RSS Feed RCU RSS Feed 1 09-07-2006 09:04 PM
How do I arm this old PC power supply? Jeremy Z Electronic Builders Workshop 26 04-11-2006 01:48 AM
Page generated in 0.44172 seconds with 67 queries
