Old 08-04-2009, 04:01 AM   #1
glamabilly
Default 380 brushed to brushless conversion
I just got a plane with a 380 size brushed motor that runs on a 8.4V nimh battery. I have a bunch of 11 V lipo batteries that I have just hanging around. What kind of brushless motor and esc can I use in it. he plane is a sd piper j3 cub three channel.
thanks.
glamabilly is offline
Old 08-04-2009, 04:58 AM   #2
Bub Steve
Bub Steve's Avatar
View Bub Steve's Gallery86
Club: Mullet Mauroders
Friends: (89)
Go see Jeff at heads up RC,, bubsteve
2408-21 Outrunner Brushless Electric Motor & 18A ESC
The very popular 2408-21 is a 1.6 oz, 1400KV, 400 class direct drive outrunner brushless motor designed for medium to high speed park flyers. Best performance is obtained with the GWS EP8040 prop and a 3 cell Lipo battery, such as the Power Up 11.1v 1300 20C. This combination is often used on the GWS Formosa, Mustang, Zero, Spitfire and many sport planes weighing up to about 30 ounces. Producing up to 22 ounces of thrust, it far outclasses the 300 to 400 speed brushed motors it replaces. It is both lighter and more powerful than the typical 400 speed brushed motor. And with the included stick mount, it is often a simple drop in replacement.
The 2408-21 works very well as a pusher motor on delta models, flying wings and profile jets. I suggest using the TP 7x6E prop for some very nice speed. The Power Up 11.1v 1000 20C Lipo battery can be used to keep the weight low on these types of models.
The 2408-21 can also be used with 2 cell Lipo batteries such as the Power Up 7.4v 1300 20C. It will provide up to 15 ounces of thrust with the GWS EP1060 prop, and it is sometimes used in profile combat plane competitions with the GWS EP9070 prop.
MOUNTING OPTIONS: An aluminum stick mount with heat sink is included, along with two prop nuts and a washer.
A firewall mount is available in our store. Always check the tightness of all motor set screws and motor mount screws when installing motors. The motor set screws require a 1.5mm Allen wrench.
Rotating propellers are dangerous. Please stay clear of prop and wear eye protection.
Propeller test data using a 3 cell Lipo battery:
GWS and TP props fit the 3mm shaft on this motor perfectly - no adapter is needed. APC and Master Airscrew props require a prop adapter or prop saver for a 3mm shaft.
The GWS EP8040 is the most commonly used prop with this motor. It will produce about 22 ounces of thrust at 14 amps with a pitch speed of 43 mph.
Monkey Minion'air
Bub Steve is offline
Old 08-04-2009, 12:37 PM   #3
glamabilly
thanks, that was very helpfull.
Old 08-12-2009, 03:03 AM   #4
Dr Kiwi
Depending on what size prop you need - an ARC 28-37-4 would be good for direct drive, with 6" prop, and of course any larger size if geared. It is hard (if not impossible) to find a 28mm inrunner with low enough Kv for direct drive of, say, 9"-10" props.
Dr Kiwi is offline
What speed controller for 380 brushed motor? BIG4D Electronic Builders Workshop 5 08-12-2009 05:41 AM
Brushed to Brushless conversion Swiso Power Systems 6 09-02-2008 12:37 AM
380 Brushed motors ZL3VML Power Systems 7 06-24-2007 08:34 AM
brushed too brushless conversion chart ? simon8433176 Power Systems 1 02-12-2007 09:03 PM
Multi Motor Brushed to Brushless Conversion- PBY BeaverBob Power Systems 2 07-21-2006 02:45 PM
Page generated in 0.33192 seconds with 25 queries
