Old 08-20-2009, 07:33 PM   #1
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
Default Dry lead acid battery
A friend gave me 2 small lead acid batteries from his scooter that he said didnt work anymore.I removed the caps from the top & looked inside & they appear to be dry
My dad says he thinks you can fill them back up using muriatic acid like what they use for swimming pools.
Just wondering if this is correct.Thanks RT
Rolling Thunder is offline
Old 08-20-2009, 07:55 PM   #2
MustangMan
MustangMan's Avatar
WAA-08 Pilot
Friends: (15)
Sorry NO! Muriatic acid is Hydrocloric acid. Lead-acid batteries use Sulphuric acid.
Funny you bring this up. My dad tried this once. He was disappointed when the battery wouldn't take a charge!
MustangMan is offline
Old 08-20-2009, 08:00 PM   #3
Rolling Thunder
Thanks mustang man
Do you know can you buy sulphuric acid
Old 08-20-2009, 08:09 PM   #4
View firemanbill's Gallery67
Club: Smoky Mountain Aero Club
Friends: (64)
Thanks mustang man
Very difficlt to do... buying batteries would be cheaper.
President - Smoky Mountain Aero Club, Sevierville Tennessee
Old 08-20-2009, 08:32 PM   #5
MustangMan
MustangMan's Avatar
WAA-08 Pilot
Friends: (15)
Thanks mustang man
I don't know off hand. The first place I would try would be a battery specialty shop. There is a Battery Source store, which specializes in a wide array of batteries including golf cards and lawn tractors, about a mile from my house I would talk to first. They might be willing to sell you a "refill" of your battery if you brought it to them. I don't know what restrictions there might be on selling the acid outright. The other problem you face is that you don't know what state the plates are in. Filling the battery with fresh acid probably won't put the battery in correct chemical balance.
If the battery you have is a couple of years old and was let run dry, probably by over charging, then it's not worth much, even with fresh acid. The same battery is available for $35 new from here. Other comparable batteries are available from many sources I'm sure.
Old 08-20-2009, 08:52 PM   #6
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
IF the battery was allowed to just dry out, then you don't want to add acid to the battery.
Just the water in the acid has evaporated. You would just want to add distilled water.
If the battery is new, than it's OK to add acid.
If it was allowed to just dry out, you probably won't get much out of it even if you could bring it back to life. My suggestion would be to get a fresh one.
Helicopters don't really fly.......
They're just so ugly, that the earth repels them.
Heli Jim is offline
Old 08-20-2009, 08:55 PM   #7
Rodneh
Club: Moonport Modelers
First, fill it with distilled (not tap) water and try to charge it. Distilled water is often available in grocery or hardware stores. It used to be quite common as many houswives used it for their steam irons. The battery may not be salvageable but, when a typical wet cell gets low on fluid, you top it off with distilled water. You may also be able to get it (or even battery acid) at an automotive parts/supply store. Worth a try.
Rodneh is offline
Old 08-21-2009, 12:38 AM   #8
Rolling Thunder
well I filled it with water & I put it on the charger so we'll see what happens
Old 08-21-2009, 04:01 AM   #9
View CHELLIE's Gallery13
Friends: (326)
If it wont take a charge, dump out a little of the water and add some vinegar to the water, vinegar is an electrolite, that may help to bring it back, if not, the battery is to badly sulphated, and is a goner
Old 08-21-2009, 02:14 PM   #10
Matt Kirsch
Matt Kirsch's Avatar
I don't think any amount of liquid is going to help.
The battery in the picture is a sealed gel cell battery, or at least it appears to be. These have no liquid in them, and aren't supposed to.
Matt Kirsch is offline
Old 08-21-2009, 03:45 PM   #11
Nitro Blast
Nitro Blast's Avatar
View Nitro Blast's Gallery45
Frankenstein Build Contest Award  100mph Speed Demon  3kW  1kW
Friends: (67)
Those batteries have a 2 year shelf life.
Even if they have NEVER been used (unlikely) after 2 years, they are done.
I have over 9 years professional experience in personal mobility chairs, and motorized scooters. Cheap china batteries, as well as quality USA made batteries, I have direct knowledge of.
Honestly, save your time by forgetting these dead puppies. Please recycle them properly.
SLA Batteries (Sealed Lead Acid) are not designed to be refilled. The 'filling' is actually a gel type electrolyte which allows the battery to be mounted and run at any angle.
Electricity... It's not just for light bulbs anymore.
GoProfessional Cases industry grade protection for your gear
Dinogy Lipos professional grade energy
Project Globetrotter Participant 7/09
Wings Across America Participant 6/10
Nitro Blast is offline
Old 08-21-2009, 10:58 PM   #12
Rolling Thunder
so would a new one of these make a good field battery for charging 3s2200 lipos?
are they made to be deep discharged?
Ive been using my car battery but dont want to do this anymore
Old 08-21-2009, 11:17 PM   #13
Nitro Blast
Friends: (67)
Actually no, it is not ideal. What is ideal, is you getting a new, deep cycle battery to use specifically for field charging. Although, I am sure that there are many who may not feel that is actually 'best'. Just like anything, there are a multitude of ways to accomplish the task.
One consideration is, how much electricity do you really need at the field? If you go flying with all packs charged, during a single day, how much juice do you really need? If you are really only charging 2, 3 or even 5, 3S 3300 packs then I'd just keep popping the hood of the minivan and be done with it.
Personally I charge a lot more, and just have a Optima battery that I've had for 4 years now. I charge it 2x a month or so, and just have it with me for all the power I need, or someone else may need down at the field.
Old 08-22-2009, 12:20 AM   #14
Louis
Louis is offline
Old 08-22-2009, 07:35 AM   #15
Friends: (326)
Hi RT get yourself a portable jumper battery, you can fly all day long with it,
http://images.google.com/images?hl=e...2&aq=f&oq=&aqi=
Old 08-22-2009, 08:07 AM   #16
Friends: (326)
here is one from Wal Mart $71.00
http://www.walmart.com/catalog/produ...ct_id=10928425
and here is one from pepboys in Victorville
http://pepboys.shoplocal.com/pepboys...PepBoys-090809
for $14.98
Old 08-22-2009, 09:47 AM   #17
slipstick
Outstanding Contributor Award
But most of those jump start systems have batteries of only 10-17AH in them. You'll be lucky to get more than about 4 or 5 charges of a 3S 2200mAh lipo out of most of them.
slipstick is offline
Old 08-22-2009, 03:02 PM   #18
Rodneh
What slipstick said plus, if you deep discharge any of these, you will soon ruin them. Do not discharge them below 11.9 volts under load or you will suffer some degradation and maybe complete failure. That goes for most Pb based batteries.
Rodneh is offline
Old 08-22-2009, 03:11 PM   #19
gfdengine204
gfdengine204's Avatar
View gfdengine204's Gallery6
Club: RC Dusters, AMA 3875, Sandwich, IL
Send a message via AIM to gfdengine204
Friends: (53)
I use a Husky Jump Starter that has 17AH capacity, and I have charged batteries during a full day at the field without any problems using my CellPro 4S, charging 3S 2200mAh packs. Only time I have encountered a problem was when using it to power two chargers at once. Otherwise, it works well for me.
- Kev
AMA 873921
RC Dusters Flying Club, AMA 3875, Sandwich, IL
Question with Boldness. Hold to the Truth. Speak without fear.
gfdengine204 is offline
Old 08-22-2009, 03:31 PM   #20
Nitro Blast
Friends: (67)
Originally Posted by Louis View Post
Which Optima are you using?
thanks
This one.
850CCA I can charge all weekend long.
As far as those battery jumpers are concerned, my dad Hircflyer, bought one from Harbor Freight. It sucked. Brand new, and the batteries were crap (probably older than 2 years). With some NEW, USA quality batteries, it works great and he uses it for all his field power, even when he's 'passing gas'.
Old 08-22-2009, 08:02 PM   #21
Friends: (326)
here is a Husky jump Starter for $39.97
http://images.google.com/imgres?imgu...a%3DG%26um%3D1
Old 08-22-2009, 09:59 PM   #22
capn chaos
capn chaos's Avatar
Club: no pack-lone wolf
Friends: (20)
AT the risk of oversimplifying....We buy mah by the ounce and we buy storage batteries by the pound/amp hour. Ever wonder why a 15 C lipo is so much lighter than a 25 c lipo....If you pay 60 cent a lb for a storage battery ie deep cycle battery you are getting 75% of the long term service life and amp delivery compared to $.80 per lb. I bought 550 lbs of batteries...2 8d and 1 group 31 battery and they lasted 6 years. I tried to save money and replaced the exact same batteries for 325.00. After 3 years they are "tired" and in need of replacement.
same goes for jumper packs. youll get twice the reserve out of a 25 lb jumper pack as a 12 lb unit. They will charge twice as much but you are still buying available amps by the pound.
If you want to get clever, buy a good AGM battery. hook up a battery combiner (diode protected charging circuit which will charge the battery while you operate your air craft carrier but will not discharge the cars battery while topping off your LIPOS. keep it in your trunk and protect the positive terminals from inadvertant contact. In a pinch you can hook jumper cables to it to jump start your car.
just my 2 cents worth......roughly 3mah
CC
capn chaos is offline
Old 08-22-2009, 10:06 PM   #23
Rodneh
It does not take a rocket scientist to be able to tell whether or not such a battery will do your job. Say it is a 17AMH battery. Just divide the current you will be drawing out of it into the capacity and you know how long it will work before a recharge. If you are drawing 2 amps and consider 80 % efficiency (probably a close approximation) you would get 17/2.2 or about 7 hours of use out of it. Now that is assuming the battery is brand new, in perfect shape, moderate temperatures and that you remembered to fully charge it before coming to the field. For small batteries and light use, yes, they work well but it will be very easy to get careless and ruin it by to deep a discharge or improper charging. I use one myself but on very small batteries and I watch the maintenance like a hawk. Many of the less expensive units do not have nearly 17AMH capacity battery either so be sure and check for that. Properly used, they can be a good thing, just be aware of the limitations.
Rodneh is offline
Old 09-26-2009, 09:44 PM   #24
mred
mred's Avatar
45 Minute Thermal Duration  30 Minute Thermal Duration
I just use a large lawn mower battery to charge at the field and have never had it run down on me even charging my 4S5000MAh batteries. It has 290 CA and cost $23.00 from my local parts house. I have been using it for 3 years now and all I ever do is put a little water in it and change it before I go flying just like my other batteries. Works for me and they are cheap.
Ed
mred is offline
Old 09-27-2009, 05:07 PM   #25
Red Scholefield
Batteries/Chargers
Red Scholefield's Avatar
Club: Flying Gators MAC - Gainesville, FL
WAA-08 Pilot
It is a matter of watt-hours. A 17 AH sealed lead acid battery has 12 X 17 = 204 watt hours.
The battery to be charged, say a 4S5000 Lipo has 14.4 X 5 = 72 watt hours. If your system is 80% effecient then you could expect to get (208 X .8)/72 = 2.26 charges (MAXIMUM)
Keep in mind that the faster you discharge a sealed lead battery the less capacity it can deliver. They are rated at the 20 hour rate. Check the manufacturers curves to see how much derating is required for higher discharge rates.
Red S. AMA 951
The Battery Clinic
www.hangtimes.com/redsbatteryclinic.html
The older I get, the better I use to fly.
Red Scholefield is offline
A123 packs outlast Deep Cycle Lead Acid Battery??? kyleservicetech Batteries & Chargers 6 07-16-2009 06:57 PM
Caring for Your Lead-Acid Field Battery stefanv Batteries & Chargers 14 02-14-2008 05:08 AM
Lead Acid cells and freezing temps rcproptester Batteries & Chargers 4 12-19-2007 10:50 AM
CellPro 4s charger and 12v lead acid battery charging issues... markm75 Batteries & Chargers 9 08-01-2007 03:22 AM
Lead acid help vaidya_ro Batteries & Chargers 4 05-03-2007 09:56 AM
Page generated in 0.61017 seconds with 70 queries
