Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 08-15-2005, 04:18 AM   #1
Jason T
Electron Liberator
Jason T's Avatar
View Jason T's Gallery8
Default Pedal launcher video
This is a pedal launcher that I build from someone else's design. I did have permission to use their design.
In the video I am launching my Turn Left pylon racer. Its getting heavy from all the fuse repair work so this makes the launch a non issue. Even though this video is short I like sharing this stuff because "a picture is worth a 1000 words" so video has to be better.
Jason
http://www.atltaylor.com/files/turnleft_bungee.wmv
Jason T is offline
Old 08-15-2005, 04:39 AM   #2
Jason T
Electron Liberator
Jason T's Avatar
Okay, here is video from a different angle of the first launch. We were experimenting with the bungee tension and it wasn't enough on this launch and I almost lost the Turn Left.
http://www.atltaylor.com/files/TLbungee.wmv
Jason T is offline
Old 08-19-2005, 10:24 AM   #3
luc
luc's Avatar
lots of torque...
here is mine (in french but with pics and vid)
http://www.geocities.com/lucchev/bungee.htm
luc is offline
Old 08-19-2005, 12:58 PM   #4
Jason T
Electron Liberator
Jason T's Avatar
Luc,
Actually, the bad launch was just not enough tension in the bungee.
I have seen your video before. Nice job!
Jason
Jason T is offline
Old 08-19-2005, 01:32 PM   #5
luc
luc's Avatar
here is a vid of my sokol launch (around 130 mph...)
http://lucchevaillier.free.fr/sokol.mov
luc is offline
Old 08-19-2005, 04:22 PM   #6
Foamiesrfun
3D Flyer
Foamiesrfun's Avatar
View Foamiesrfun's Gallery47
Club: Paulding County Model Aviation
Send a message via Yahoo to Foamiesrfun
Dont think the dog was expecting that LOL,those are neat guys.
"I'ld rather be flying"
"B&D 1100 Cells and A123 2300 cells are my
best friends."
_______________
My Personal RC website:
http://chrissrcplanes.tripod.com/
Where I got my edge 540
http://www.fancyfoam.com/
My clubs Site.
http://pcmaviation.org/NewIndex.htm
Foamiesrfun is online now
Old 08-19-2005, 11:54 PM   #7
fdix
fdix's Avatar
Globetrotter Pilot
wow cool vids!
Did you guys some way calculate where to put the bungee hook or is the position not so critical?
fdix is offline
Old 08-20-2005, 05:35 AM   #8
Jason T
Electron Liberator
Jason T's Avatar
Luc,
Your dog almost keeps up with the launch.
Jason T is offline
Old 08-20-2005, 05:37 AM   #9
Jason T
Electron Liberator
Jason T's Avatar
fdix,
I did not calculate the position of mine. However, I did put it in front of the c/g. I think if you put it too far forward the launcher would have a tendency to pull it toward the ground and too far back (behind the c/g) it would be very squirely on launch.
The position of the hook on my Turn Left was TLAR (that looks about right) based on the above statement. For example, my hook is about 2.5" in front of my c/g and the hook is about 4.5" from the spinner. The TL fuse is pretty long.
Hope that helps. Maybe some others can chime in with how they chose the hook position.
Jason
Jason T is offline
Old 08-20-2005, 07:12 AM   #10
luc
luc's Avatar
The hook should be around 1/3 from the front of the plane to the CG.
The more aft and the steeper the climb, which is not really needed, as it is not a glider.
luc is offline
Old 08-20-2005, 01:48 PM   #11
fdix
fdix's Avatar
Globetrotter Pilot
Thanks to you both for the info!
fdix is offline
Old 08-25-2005, 08:11 PM   #12
mrstormy
Gents, where are good places to get info on bungee launching and planes. This looks really cool and I can't believe I hadn't seen this stuff since I started flying three years ago.
mrstormy is offline
Old 08-25-2005, 10:19 PM   #13
RichTheBikeRider
RichTheBikeRider's Avatar
Send a message via AIM to RichTheBikeRider Send a message via MSN to RichTheBikeRider
Default Launchers
Hi go to http://www.ezonemag.com/, there are plans to build one or two there also mine is plastic pipe I had a wood one but in wet grass it warped, I added safty stuff to mine when a kid almost got it from a friends launcher. I Lock the peddle and the bungie also make sure the stake is well set. I really like this style cause you can fly alone in safty.
Rich
RichTheBikeRider is offline
Old 08-28-2005, 05:16 AM   #14
Jason T
Electron Liberator
Jason T's Avatar
Here is another video of the pedal launcher with a little more video of the Turn Left.
http://atltaylor.com/files/TL-08-27-05.wmv (2.3MB)
Jason T is offline
Old 08-28-2005, 06:00 AM   #15
RichTheBikeRider
Looked OK to me like I said the only difference in mine is the rails slide in or out to accommodate landing gear. Our field is dirt and the city won't let us improve it. My hot liner spinner is repolished from landing, I also use carpet tape on the bottom to keep the paint nice.
Rich
Old 09-16-2005, 09:33 AM   #16
ericthetree
ericthetree's Avatar
Send a message via Yahoo to ericthetree
what diameter is the cord you are using for this launch system? thank you, ericthetree
ericthetree is offline
Old 09-16-2005, 02:38 PM   #17
RichTheBikeRider
For small planes 5/16 bungee for larger planes a second bungee set is added note the break is a 1" ID x 1 foot piece of split insulation foam wrapped with duck tape I'll take picks so you can see construction the whole launcher is made from parts you can get from Ace or Home depot, and a drill press and a file.
Rich
Old 09-16-2005, 02:43 PM   #18
Jason T
Electron Liberator
Jason T's Avatar
I am not sure what the diameter of my tubing is. Mine came from the tubing in a high-start which I think was 10 pounds tension. We cut two pieces about 20' long to double them up. My Turn Left weighs about 32 oz and it has not problem launching it.
Jason T is offline
Old 09-16-2005, 03:46 PM   #19
ericthetree
Thank you for the quick responses guys. Rich I would very much like to have some pics, I really like the idea of a rail type slide that is adjustable. pic is what I've come up with design wise so far. adjustable rate of ascent. I will probably make slide sides out of 1x2 pine board. Rich how long is the rail on your avatar pic.
Name:	plane launcher.jpg
Old 09-16-2005, 04:42 PM   #20
RichTheBikeRider
Wink Catapult
OK here are the Pic'sFor the catapult note it's designed for hi and medium stab's, weight up to 30 Oz. or so. You must spike it down in the rear by the release.
Rich
Old 09-16-2005, 05:02 PM   #21
RichTheBikeRider
Default Launcher
Here is the pic's of my launcher
Rich
Old 09-16-2005, 05:30 PM   #22
RichTheBikeRider
here is a pic of Zigi note the dammage you get when friends use the catapult and wiggle the ailerons in the catapult.
Rich
Old 09-16-2005, 06:04 PM   #23
RichTheBikeRider
OK I am going to give you a few pointers on the Catapult.
There are 1-1/2x1/8x8 aluminum under the plywood for strength. The arms that fit over the wing are for anti-blowback.
You need thick enough foam tape to prevent the ailerons on your plane from hitting the back of the launch box.
I keep the square tube lubed with pledge.
note the "Y" for the front legs could be made as a "U" instead. If I can awnser anyother questions just ask.
Rich
Old 09-16-2005, 06:28 PM   #24
ericthetree
thanks Rich, I like this design,I don't have any flying partners so I am in need of a launch mechanism.
Old 09-16-2005, 06:36 PM   #25
luc
luc's Avatar
look also at the ez one I use (in french, but includes pics and vid)
luc is offline
Storm launcher questions krl Foamies 3 12-24-2007 12:32 AM
Storm Launcher HELP. MarcTonk Foamies 20 09-07-2007 05:21 PM
Storm Launcher Rinyotsu General Electric Discussions 3 03-24-2007 04:50 AM
Storm Launcher stabilizer Rinyotsu Foamies 4 03-06-2007 12:54 AM
Storm launcher??? RSS Feed RCU RSS Feed 0 10-27-2006 06:00 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.68776 seconds with 79 queries
