Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Aerial Photography
Old 10-22-2009, 04:54 AM   #1
Aero Ace Ace
Aero Ace Ace's Avatar
View Aero Ace Ace's Gallery25
1kW  1kW  AP Contest Winner  125mph Speed Demon
Default Lost and Found
I've posted a similar thread in RCGroups, but I wanted to share some cool stuff here too. About a week ago I lost a Funjet to radio interference. The fields surrounding our runway are extremely thick with brush. In some places it's like trying to crawl thru a chain-link fence. In other areas, reeds tower over you as you struggle thru thigh-deep water. I searched the area I thought the Funjet was lost in for 2 days, but I made very little progress. By the third day I had re-installed some new hardware in my Twinstar and sent her up with the camera. After the second sortie she returnd with several pictures that clearly showed the position of the plane; farther from the field than I thought, but quite easy to reach. the airframe was badly damaged, but I managed to fix it, and it is flying today.
Just this morning I searched an area suggested to me by another frequent flier. The brush was also quite thick there, and the pictures I took only had one clue. It turned out to be the airplane in question. If the wing had not been ripped off, I doubt there would have been a trace from the air. I think the plane is 100% repairable without too much effort.
ID:	111887 Missing party: Funjet
ID:	111888 AP platform: TwinStar
ID:	111889 Funjet found!
ID:	111890 Detail of area in question
ID:	111891 Could this be it?
ID:	111892 Wing at crash-site
ID:	111893 Fuse at crash-site
ID:	111894 Normally finders-keepers applies, but you can have your gross nitro plane.
Aero Ace Ace is offline
Old 10-22-2009, 10:27 AM   #2
View CHELLIE's Gallery13
100mph Speed Demon  Outstanding Contributor Award.
Friends: (215)
Hi Areo if your on 72 MHz, use a Berg receiver, and you may never ever have any Radio Interference again, they are in a league all there own, its all i use now, its like having a 2.4 radio, as your receiver will lock onto your transmitter, even if some one else is on your channel.use a small piece of scotch tape on all micro receivers to hold the crystal in place and tape the antenna to the receiver, lay it on the receiver and use some fiberglass straping tape, that will keep the antenna from ever wanting to pull out of the receiver, just incase of a hard landing, only use Berg crystals with a Berg receiver, I Like the 4L receiver, hope that helps, Chellie
http://www.bphobbies.com/view.asp?id=V457587
http://www.castlecreations.com/suppo...user_guide.pdf
Old 11-04-2009, 11:11 PM   #3
Aero Ace Ace
Default 3 more found!
Here's a few more I found! I've since recovered an electric F-35, a small electric model called a Mach 9, and an OS .60 powered Ugly Stick that is 100% intact. The pilot could not be happier! The Ugly Stick fell into some very thick reeds and never touched the ground, the F-35 was not as lucky, but contained several expensive undamaged parts. The Mach 9 was wing deep in soft dirt, when we pulled it out we were surprised to see the nose was intact! It needs a little work, but appears repairable.
Old 11-05-2009, 12:21 AM   #4
rdlb23
rdlb23's Avatar
View rdlb23's Gallery18
Holy Moly! That's just awesome! Every thought about joining the CIA and getting into image analysis?
rdlb23 is offline
Old 11-05-2009, 12:34 AM   #5
newjak
AMA Park Pilot Partner
newjak's Avatar
View newjak's Gallery3
Club: Central Delaware Parkflyers Association
Very impressive!! You guys sure loose ALOT of planes!
A.M.A Park Pilot Partner / Wattflyer Mentor
newjak is online now
Old 11-05-2009, 12:36 AM   #6
Lieutenant Loughead
475.96 hours logged...
Lieutenant Loughead's Avatar
View Lieutenant Loughead's Gallery35
Club: Flown 517 days in a row!
Globetrotter Pilot  WAA-08 Pilot  100mph Speed Demon
Friends: (23)
LOL -- that sounds like the tree that eats Charlie Brown's kite. I would stop flying at that location.
www.KarglUSA.com
AMA #930992
Old 11-05-2009, 12:41 AM   #7
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (69)
Way cool!! bubsteve
Monkey Minion'air
stevecooper is offline
Old 11-05-2009, 04:54 AM   #8
Aero Ace Ace
There are a few tricks for finding what you're looking for, be it an RC airplane or a covert missile silo. Narrow down the seach area as much as possible. Don't fly too high while taking photos, higher than 50-75ft and the details become too small. At least one photo of your target needs to have some sort of landmark in the frame to guide you to the wreck.
In some cases the plane is smiling right back at you. The Mach 9 couldn't have been any more obvious. In one photo of the Ugly Stick, the maltese cross was visible. The Funjet is a color not found in nature in that area. In some cases you might only see a small piece of the plane, but if that piece is a sharp polygon in a color that doesn't match the terrain, it's definitely man-made.
Old 11-05-2009, 07:13 PM   #9
rdlb23
rdlb23's Avatar
I don't know f you have photoshop but there are some tricks you can use to highlight items that don't belong. Its frequently used to double check for fraud it the publication of scientific photographs.
You can desaturate/oversaturate certain color groups (photo 1), inverting the image will bring out some things (photo 2), or you can use increased contrast in black and white, by adding alot of red and subtracting blue or vice versa.(photo 3)
It seems like its no big deal because you already know where the plane is in the picture, but it totally works and you can get really good at it. I'm not good at it I just know about it, my friend is a graphic designer for a scientific journal in NY and she does these checks all the time. Shes got it super fine tuned and can find the smallest flaws in high resolution stuff...
As you can see from the pictures, sometimes things get highlighted that aren't crashed planes.
rdlb23 is offline
Old 11-07-2009, 02:34 AM   #10
Fangar
Bank Robber
Dude... I think you have discovered the Bermuda triangle of RC Fields.
_______________________
James
AMA # 20876
Fangar is offline
Old 11-09-2009, 04:56 PM   #11
Sparky Paul
Sparky Paul's Avatar
Looking at the terrain, there's probably things that go "rattle-rattle" when you walk thru.
I'd not go too far into that stuff myself, looking for a plane.
Sparky Paul is online now
Old 11-09-2009, 08:27 PM   #12
crxmanpat's Avatar
Club: Arizona WingNutz
Friends: (19)
Ace, you are the man with your recovery skills! I know that Gary is very happy you found his F-35.
This is Bennett Field in Las Vegas (well, Henderson really). It's right next to Sam K Boyd stadium where UNLV plays football. I have flown there twice now, but have been fortunate enough not to have had a plane go down in the "swamp".
I was there a few weeks ago at the Ace In The Hole electric fly-in, and watched the F-35 go in (I was taking video at the time as well). I went out with the owner and searched for quite a while. The weeds out there are so thick you could literally walk right by the plane and not know it. And believe me, I was carrying a big stick with me to herd off any wild critters I came across!
I'm working on a combo AP/FPV setup on a Slow Stick. I got my FPV mount from Blue Sky RC. I just need to get a decent FPV outfit, most of which will come from Range Video. No goggles yet as I have a video camera and laptop that will be dedicated to the system. Not real keen on flying true FPV right now, but that may change in the future. I just can't drop $225 on goggles right now.
My plan is to overfly the suspected impact area (not using FPV), and have an observer looking at the laptop screen. The camera will be pointed almost straight down so that planes can be spotted from directly overhead. If they see something of interest, I can then orbit the area, get a closer look, then send out searchers on foot once a plane is spotted. And if we spot something while flying low, I can then gain altitude so that the observer can get a good triangulation on the crash site.
I hope to put this plan to the test next year.
Pat Gagnon
Owner - Nico Hobbies
Your source for micro pusher jets!
crxmanpat is offline
Old 11-10-2009, 03:46 AM   #13
Aero Ace Ace
I have a few more planes to find far out into some extremely tall reeds. It's tough to see stuff in there from an angle so I have re-mounted the camera pointing straight down on a MPX Acromaster. The plan is to fly in a straight line starting from a landmark and re-create a path to the wreck from there.
I got a blip today, but with the angle the camera was mounted in, I couldn't figure out exactly where to look.
Old 11-10-2009, 04:16 AM   #14
crxmanpat's Avatar
Friends: (19)
Wow, that just goes to show how bad it is. Looks like just the tailplane in that pic. Would be almost impossible to spot from 100' up.
Pat Gagnon
Old 11-19-2009, 03:11 AM   #15
Aero Ace Ace
Default Found it finally
This one was the toughest to find once I was on the ground, but also the most rewarding. There is no damage to the plane, other than a completely discharged lipo. I flew it the next day! From the air, I thought I had spotted a Tiger II several people saw go down. It turned out to be an E-flite Extra-260 that I didn't know was back there. There was no name or AMA number on the plane.
I cleaned it up with a damp rag and shook all the insects out. I found a tiny scorpion, but his tail was broken off.
I've swapped out the rudder servo for more torque, and added a pilot. Hans may have become an ace in a BF-109, but he has become proficient in the Extra as well.
ID:	113626 See it?
ID:	113627 Still there after some strong winds.
Name:	ground wreck.jpg
ID:	113628 Now that I've found it, how do I get us both out of here.
ID:	113629 All cleaned up
ID:	113630 On the tip of a 12x6 prop.
Old 11-21-2009, 06:31 PM   #16
hillbille
hillbille's Avatar
View hillbille's Gallery7
WAA-08 Pilot
I'll be interested in seeing the pictures of the rightful owner getting that EXTRA 260 BACK from you. THOSE are the pictures I hope you post next! Nothing could be better than the smiling face of a pilot getting a lost plane back!! RIGHT?? RIGHT!!!
Hillbille
It isn't the mistake that causes the crash - it the time it takes to realize that it WAS a mistake!!
AMA884978
hillbille is offline
Old 11-22-2009, 12:31 AM   #17
Lieutenant Loughead
Friends: (23)
Well, I think it suffices to say that lots of pilots have lost lots of planes at that field, and I will NEVER fly there!
www.KarglUSA.com
AMA #930992
Old 11-22-2009, 04:43 AM   #18
Aero Ace Ace
It's such a nice field it's hard to fly anywhere else, especially since I live so close. I got in touch with the owner today and he'll be getting it back with his name on it.
Old 11-23-2009, 03:01 AM   #19
hillbille
hillbille's Avatar
WAA-08 Pilot
Great job!! Happy to see it all worked out for everyone!!
Lieutenant Loughead - The fifth picture of post #3 says a lot about going out in the area know as "the swamp"! Believe me when I say Aero Ace Ace takes his well being in hand when he venturs into that!! It is nasty!! The idea is NOT to go astray of the field!! LOL!!
Hey AAA - Post the picture of Bennett field you took before AITH. It shows the field and surrounding area. Like AAA said it is a GREAT place to fly.
Hillbille
AMA884978
Old 12-01-2009, 07:09 PM   #20
aero_k
aero_k's Avatar
I recently lost a plane in the woods. I've got a camera on the way, hopefully I'll be able to find it now! I've spent a few hours searching from the ground with no luck, but from the air might help. I'm just worried that now that all the leaves have fallen its buried for ever.
aero_k is offline
Old 12-20-2009, 11:53 AM   #21
Music-AMG
Music-AMG's Avatar
My daughter did... lol exactly what she does.. photo analyisis... this post will will self explode..
Music-AMG is offline
Old 12-20-2009, 05:23 PM   #22
w7mag
"Woop! Woop! - PULL UP!"
w7mag's Avatar
Now THAT'S funny!
(What a great thread, great stuff indeed.....)
w7mag is offline
I just lost my first airplane - UPDATE: PLANE FOUND! mikeyv Beginners 37 04-17-2009 09:14 PM
Lost PLane with FlyCamOne v2 found Crash9 Aerial Photography 27 04-15-2009 06:23 AM
Oh I'm so lost :p Giedi_Prime Beginners - Helis 19 03-07-2008 01:04 AM
Lost in field, what would YOU do? rcdaedalus Beginners 6 04-25-2007 09:22 PM
Lost Plane? RSS Feed RCU RSS Feed 1 08-27-2006 02:54 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.52852 seconds with 84 queries
