Old 10-23-2009, 04:23 PM   #1
scotty123
Default Towerpro 40 Amp ESC
I'm having a bit of difficulty with my TowerPro 40 Amp Speed Controller.... it's this one
http://www.hobbycity.com/hobbycity/s...eed_Controller_
The instructions are not very clear, but I think I am doing it right. After programming, I get a beep when I connect my battery, then four beeps together, which should state the number of cells connected. I get four beeps, but have a three cell LiPo connected. The esc then drives the motor at a reduced speed. This is only if the three cell Lipo is above about 11.7volts. If I run the battery down a bit, then re connect, I get three beeps together, so the esc is seeing three cells and it performs great with no issues and full power...
I think the esc is faulty, but was wondering if the Auto detect for cell count could be altered , or maybe it is seeing NiMh not LiPo.
Any suggestions would be welcome , or a definate set of instructions so I can check them against mine.....
Sorry if the question is a bit long...
scotty123 is offline
Old 10-23-2009, 09:39 PM   #2
aramid
aramid's Avatar
I can't help you, but I can share your misery. I've got an 18 amp TowerPro, and I've never been able to find programming instructions anywhere which actually match the beeps from the ESC. I gave up and bought a better controller; hopefully you fare better.
aramid is offline
Old 10-23-2009, 10:18 PM   #3
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (69)
Aramid:I posted it here on watt-flyer a few years ago,, I'll see if I can find it, bubsteve
PS the 18's work GREAT ,, sorry you did'nt get the manual, ,,
Monkey Minion'air
stevecooper is offline
Old 10-24-2009, 10:54 AM   #4
scotty123
To be honest, when the Lipo has discharged a bit and the esc sees a 3 cell, it works faultlessly. Never comes down hot, never hot on a static test even pulling 40A constantly..
Just wish I could get it to work with a fresh Battery....
Old 10-24-2009, 04:33 PM   #5
MustangMan
MustangMan's Avatar
WAA-08 Pilot
Friends: (14)
I've not used the TowerPro 40 but have an 18 (or 25, I can't quite remember) that will register a fresh 2S as a 3S and will then shut down after about 30 seconds of running. Like you, I can run it a bit to drain down the battery slightly and then re-plug the battery to get the ESC to recognize it as a 2S. After that it works fine. I think I finally got exasperated with it and set it up for Ni batteries instead of Lipo. I just don't fly it to cut-off and have been happier with it since making the setting change. Have you found the programming instructions yet for the 40?
MustangMan is online now
Old 10-24-2009, 05:53 PM   #6
scotty123
Hi..
Yes.. There where some instructions that came with the esc and all settings seem to work fine.... I did question them after I discovered this anomaly....
I have contacted the shop as I got it from Flebay and his reply was, it is the first one reported as faulty...(maybe a standard reply me thinks)
but he did say he has used a few and to send it back for testing... I did question the instructions but am waiting for a reply from him..
I will send it back to him on Monday and update the thread with any results if that's of any use....
If I get a working one, I'll type out the full working instructions as well......
Interesting you set for Nicd, I wouldn't have even thought of that... does it just work the same..?
Old 10-24-2009, 07:35 PM   #7
MustangMan
MustangMan's Avatar
WAA-08 Pilot
Friends: (14)
Setting to NiMH mode doesn't affect the operation of the ESC, only how it determines the LVC point. Setting it to NiMH while using a Lipo is a bit risky in terms of Lipo battery life as the NiMH setting results in too low a cut-off point for safe operation of Lipo's IF your try to fly all the way to LVC. I quit flying when I find myself nudging up the throttle, or top speed at full throttle seems to fall off. Doing that, my Lipo's typically come down with an unloaded voltage of about 3.5 or 3.6 volts so they're well run down but not dangerously low.
Old 10-24-2009, 09:02 PM   #8
View CHELLIE's Gallery13
100mph Speed Demon  Outstanding Contributor Award.
Friends: (215)
here you go Aramid , hope that helps, Chellie
http://www.mock.dk/Manualer/ESC_TowerPro_30A_manual.pdf
Old 10-24-2009, 09:09 PM   #9
Friends: (215)
Hi Scotty Do yourself a big Big Favor and get the programing card, its only like $6.95 and it takes all the Guess work out of programing, Hope that helps, Chellie
http://www.hobbycity.com/hobbycity/s...ogramming_Card
Old 10-29-2009, 04:47 AM   #10
nipper
chellie and others, have any of you guys used the Turnigy Plush 40 amp or larger ESC,s ? are they good or not so good ?
nipper is offline
Old 10-29-2009, 06:06 AM   #11
aramid
aramid's Avatar
Nipper: I've got a Plush 40a, and it's been completely reliable and easy to use. A friend has two Sentry 60a controllers, and they've been equally impressive.
Chellie: Will the Turnigy program card really work with the TowerPro ESC? I've got that card, and never tried it because I didn't expect it would work.
aramid is offline
Old 10-31-2009, 03:00 AM   #12
Friends: (215)
Sorry, My mistake I was thinking Turnigy not Towerpro, i am not sure if it will work or not, Take care, Chellie
Old 11-07-2009, 10:14 AM   #13
scotty123
Well I must say that the shop I bought it from on Feabay have been great...
I was sent a very curtious email reply and great great service from them.. and sooooo cheap.
Not sure I'm allowed to post company names, but thank you Storm_Trade .
New one has arrived.. If any one would like the instructions for it (in my own words) that I have tried and tested please let me know..
Wanted FOUND-WTB 40 amp BL ESC & Power 10 or 15 BL Outrunner Emile_Beaulieu Motors and Speed Controllers for sale & WTB 1 04-16-2009 09:31 PM
Plettenburg HP 370-40-A2 & Future 40/160H ESC? Kirsty_Carnage General RC E-Heli Talk 0 12-23-2008 04:47 AM
For Sale TowerPro 2915-5T & Welgard 45A Advance ESC lesman Motors and Speed Controllers for sale & WTB 0 08-24-2008 03:27 PM
Wanted E-flite Power 10 & 40 amp esc crashnburn Motors and Speed Controllers for sale & WTB 0 04-26-2007 04:24 AM
Towerpro 65 amp ESC bleary Power Systems 2 01-13-2007 12:04 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Page generated in 0.38728 seconds with 46 queries
